I had my mag-ride / EDC recalibrated at Audi dealership today after suspension drop with new springs.
I did not do the re-calibration with my H&R springs some 8 months back, but read mixed reports that it was required. After installing the ED lowering springs last week I decided to get the shocks re-calibrated. I called 3 dealers, 2 of which said it wasn't required, while the other said it has to be done. I asked a contact in Germany who works at an Audi dealership, and he too stated it must be done. The cost was 1hr labour ($200AUD)
The logic is that the dampers need to know their 'zero' position when standing/static. After lowering springs are fitted, the dampers are too compressed to regain their factory 'zero' standing position. Whilst driving on the road the dampers cannot make the correct adjustments as they are unaware of the actual true 'zero' position as the correct basis point.
The results of EDC damper re-calibration:
- The car certainly feels more re-active to road conditions. Simply put, the damping is just better and more compliant.
- suspension feels smoother over bumps and bounce seems further minimised in conjunction with ED springs.
IMO worth doing if you have modified your ride height. This process could be done through VCDS if anyone had the security code for the 'Suspension Electronics' module, however no one seems to have it.
