Results 1 to 9 of 9
    Active Member One Ring IC Asmodai's Avatar
    Oct 03 2015
    Pennsylvania
    Tighten gas cap warning.
    Ok, so the day my "Tighten gas cap" warning came on but we pump our own gas here in PA so I'm sure I tightened it. I got to work and took it off and retightened for good measure, I drove home with no problems but that next morning the check engine light (or MIL? Is that right?) came on. Today I filled it up and it did the whole "no I don't want to start" when I tried to start it. I have an N80 on the way but I've read the Carbon Canister could be saturated with fuel how could I check if it is?
    Yes I was topping my tank off...it won't be happening anymore!
    Active Member One Ring Chappya4b5's Avatar
    Jan 04 2014
    2000 audi a4 quattro 1.8t manual : SOLD
    Ohio
    I just had the same issue about 2 weeks ago. Replaced the n80 and no problem so far. Hopefully that's all it is.
    Active Member Two Rings cradle's Avatar
    Feb 21 2015
    SC
    same issue here, its been happening to me for about a month ordered a N80 from ECS today and hope this fixes the problem, tired of it not starting when i fill up.
    Feb 15 2016
    Cambridge,Ontario
    so what exactly is the symptom ?
    so when the pump "clicks off" you decide to go back and keep filing ? so then you go back to start your car and it wont start ?
    i'm not connecting the dots with the loose cap thing.
    I imagine a loose gas cap mil is the evap system sensing a major leak ( like the n-80 stuck open ) so I think that may fix that issue.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Nov 15 2011
    Montreal | I sell in USD
    Its a small evap leak code you usually get, pretty common to be either the N80 or gas cap (There's a revised version)
    *****I sell in USD*****
    Feb 15 2016
    Cambridge,Ontario
    revised N80 ? or revised gas cap ?
    1976 Yamaha XS 360
    Oct 03 2015
    Pennsylvania
    Thanks fellow Audi fans for the info, it's appreciated.
    The symptom iceman, was a loose gas cap mil which went out and hasn't come back on. Now it's a check engine light, with a little more vibration while at idle and that not wanting to start after the fill up thing it did. On the topping the fuel tank off, yes your right after the pump clicks off I would go back and round up the $$ to the next 0.25...it's an OCD thing. However I've read from multiple sources here and elsewhere topping the tank off will cause
    Thanks again everyone.
    Sent from The Lands of Always Winter
    Feb 21 2015
    SC
    Replaced my n80 valve and fixed the issue when adding 5 gals
    Sent from my SPH-L900 using Tapatalk
    Oct 03 2015
    Pennsylvania
    Awesome, glad it worked!
