Page 1 of 4 123 ... LastLast
Results 1 to 40 of 156
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Comprehensive list of OEM b5 a4 brake upgrades
    There has been a few threads lately in regardes to brake upgrades, so I figure I will try to compile a list of both front and rear upgrades so we have everything in one place for ease of future reference.
    This list is incomplete as of now, I DO NOT know what is required to run ALL of these setups on both pre-facelift and facelift cars. With the help of the rest of you guys, I hope to complete this list. If anyone has anything to add(part #'s, tips/tricks, other notable setups, etc.), post it and I will edit it into the 1st and 2nd posts.
    FRONT-
    D2 A8 BBK:
    B5 A4 Calipers
    D2 A8 312mm x 25mm rotors 8E0 615 301 R
    TT Carriers 1J0 615 125 A
    Requires new brake lines?N
    Boxster 986 BBK:
    Boxster 986 Caliper Rt 986 351 422 03
    Boxster 986 Caliper Lt 986 351 421 03
    TT Carriers 1J0 615 125 A or Apikol/PureMS brackets
    Requires new brake lines?Y
    Boxster S BBK:
    Boxster S Caliper Rt 996 351 426 11
    Boxster S Caliper Lt 996 351 425 11
    or
    B5 S4 321mm x 30mm rotors 8E0 615 301 AD
    Porsche 993TT BBK:
    993TT Caliper Rt 993 351 426 10
    993TT Caliper Lt 993 351 425 10
    or
    Apikol 323mm x 32mm 2-piece floating rotors
    or
    Mercedes Benz C230 330mm x 28mm rotors 203 421 13 12 *(machine center hub a few mm, and drill lug bolt holes to 14mm) (with corresponding brackets)
    or
    Volvo V70R/S60R 306 452 22 330mm x 32mm *(open lug holes with a 3/4" bit, and minimal grinding to uprights) (with corresponding brackets)
    Apikol/2Bennett brackets
    •Notes• A.K.A. Porsche Brembo Big Red/Black found on both 993s and 928GTSs
    Quote Originally Posted by Bordom View Post
    All 17z/18z calipers will bolt directly to the S4 uprights. No brackets required. You will need associated hardware for them to bolt on which is about $40 from audibbkparts.
    All 17z/18z calipers use the same SS brake lines as far as I know. They are a banjo fitting on the caliper.
    If you choose to swap to B5 S4 uprights instead of running the brackets. . .
    This is specifically for the conversion to S4 uprights:
    Aluminum S4 uprights: Requires a new straight lower control arm. This control arm uses a longer, thinner balljoint
    Steel S4 uprights: Regular control arms can be used. The A4/late S4 straight control arm has shorter, fatter balljoints
    Axles:
    All V6 axles will work for this application. Be cognizant of Auto/manual.
    The only 1.8T axles that work for the S4 upright conversion are the 01, as Audi switched to 82mm wheel bearings at that time.
    Unless you are 5-speed FWD (and installing S4 uprights). Then S4 axles actually do work.
    17z 330mm BBK:
    17z Caliper Rt Porsche 955 351 422 33/Touareg 7L6 615 124 H/Audi Q7 7L6 615 149
    17z Caliper Lt Porsche 955 351 421 32/Touareg 7L6 615 123 T/Audi Q7 7L6 615 150
    Mercedes Benz C230 330mm x 28mm rotors 203 421 13 12 *(machine center hub a few mm, drill lug bolt holes to 14mm, and need 2mm Apikol shim or steel washers)
    or
    Apikol 2-piece 330x32mm rotors
    Apikol brackets
    Confirmed fitment-Centric (Stoptech branded) 950.33005 brake lines
    17z 345mm BBK:
    17z Caliper Rt???
    17z Caliper Lt???
    rotors???
    Apikol brackets
    18z BBK:
    18z Caliper Rt 7L6 615 150
    18z Caliper Lt 7L6 615 149
    17z brake pads
    Mercedes Benz C32 AMG 345mm x 30mm rotors 203 421 09 12
    Apikol brackets
    B6/B7/B8 345mm BBK:
    *Requires B5 S4 upright conversion*
    B8 S4 Caliper Rt 8K0 615 124 G
    B8 S4 Caliper Lt 8K0 615 123 G
    B6/B7 S4 345mm x 30mm rotors 8E0 615 301 T
    B8 S4 Carrier Rt 8T0 615 126
    B8 S4 Carrier Lt 8T0 615 125
    Requires new brake lines?Y/N?
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Dec 13 2010
    FL
    REAR-
    C5 A6 255mm:
    B5 A4 calipers
    C5 A6 255mm x 10mm rotors 4B0 615 601 B
    B6 A4 3.0L carriers 8E0 615 425 G
    B5 S4 256mm:
    B5 S4 Caliper Rt 8D0 615 424 C
    B5 S4 Caliper Lt 8D0 615 423 C
    B5 S4 256mm rotors 8D0 615 601 D
    B5 S4 Carriers 8D0 615 425
    D2 A8 269mm:
    D2 A8 rotors 4D0 615 601B
    D2 A8 Carriers 4D0 615 425 B
    D2 A8 rotors 269mm *(2mm washer in between the bracket and the upright)
    •Notes• "Should be stated that C5 A6 calipers work, too (so you can get calipers and carriers from the same car, which helps a lot), the only downside being that it requires a different brake line due to the C5 using a banjo bolt at the caliper."-walky_talky20
    B7 S4 300mm:
    or
    B6/B7 S4 Caliper Rt 8E0 615 424 C
    B6/B7 S4 Caliper Lt 8E0 615 423 C -->grifrowl's B6/B7 S4 caliper D.I.Y<--
    B7 S4 300mm x 22mm rotors 8E0 615 601R
    Apikol/034 brackets
    May 17 2014
    Raleigh, NC
    Dont forget the b5/c5 V8/W8 Vented rear upgrade. its about a 12.5in vented rotor set up.
    I run it.
    Dec 13 2010
    FL
    Quote Originally Posted by rodgertherabit View Post
    I run it.
    PM me the info or post it here. either way, I will edit my post once I have the info
    Feb 11 2011
    Eugene, OR
    Rear - inexpensive option
    A6 upgrade (255 mm x 10 mm)
    A6 2002 3.0L & 2.7TL Q (C5) rotors 4B0 615 601 B
    A4 B6 (2002) 3.0L Carriers 8E0 615 425 G
    Stock A4 B5 Calipers & Pads & brake lines
    Works well with A8 front upgrade
    Jun 10 2010
    Quote Originally Posted by GrapeBandit View Post
    Porsche 993TT BBK:
    or
    Apikol brackets
    Requires new brake lines?Y/N???
    2Bennett also offers a 993tt kit over 330mm rotors.
    Brake lines are needed.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Dont the ATE G60's with 320mm x 25mm discs plus A6 carriers also work for front?
    Dec 13 2010
    FL
    Quote Originally Posted by RS4Avant2be View Post
    tnxadded
    are brake lines are needed for all 993TT kits?
    Jun 30 2008
    Erie, Pennsylvania
    I run it.
    This is the "D2 A8 269mm" option.
    Should be stated that C5 A6 calipers work, too (so you can get calipers and carriers from the same car, which helps a lot), the only downside being that it requires a different brake line due to the C5 using a banjo bolt at the caliper. A8 or W8 calipers won't work because the e-brake hookup is a bit different.
    Dec 10 2013
    Borden, Ontario, Canada
    Yes because banjo fitting on the calipers.
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Nov 06 2013
    Melbourne, Australia
    In need for rear brake, already got A8 front, this helps alot, thanks. Would these do ....
    Audi / A4 / 2001 / Sedan / Red / Automatic WAUZZZ8E12A10XXXX ALT059265
    Audi / A4 / 2003 / Sedan / Black / Automatic WAUZZZ8E53A38XXXX BFB033291
    Audi / A6 / 1995 / Wagon / Black / Automatic WAUZZZ4AZSN09XXXX ABC132614
    Just a list from my local wrecker.
    Dec 13 2010
    FL
    Quote Originally Posted by tymatk View Post
    the 2001 is good for the rear calipers.
    the 2003 should have the carriers if its a 3.0.
    the 1995 a6 has nothing for this brake upgrade.
    Veteran Member Three Rings Cactus Avant's Avatar
    Dec 15 2012
    Thanks for organizing this thread
    Jun 10 2010
    FRONT-
    Boxster 986 BBK:
    Apikol brackets
    Requires new brake lines? Y
    Boxster S BBK:
    or
    Porsche 993TT BBK:
    or
    or
    or
    17z 330mm BBK:
    17z caliper Rt Porsche 955 351 422 33/Touareg 7L6 615 124 H/Audi Q7 7L6 615 149
    17z caliper Lt Porsche 955 351 421 32/Touareg 7L6 615 123 T/Audi Q7 7L6 615 150
    or
    Volvo S60R 306 452 22 330mm x 32mm *(open lug holes with a 3/4" bit, and minimal grinding to uprights)
    Apikol brackets
    18z BBK:
    Rotors???
    Apikol 17Z adapters are supposed to also work for 18Z calipers.
    Brackets???
    My edits are bold.
    BIRA also offered a few options.
    The 993tt section should note that they are also known as Porsche Brembo Big Red/Black and are found on both 993s and 928GTSs.
    Active Member Three Rings 10kredline's Avatar
    Feb 03 2007
    San Gangster Valley, CA
    Don't forget, instead of the bracket/ tt brackets setup, there's also the S4 uprights along with s4 axles in order to use the s4 calipers and certain Porsche/Brembo if I'm not mistaken.
    Current - 2011 Audi S4 B8 : IE Stage 2 Single : IE DSG Tune : IE Intake : CTS 180mm : 034 Engine/Trans/Insert : ECS X-Pipe : H&R Sport Springs : Michelin PS A/S 4
    SOLD - 1999 Audi A4 Santorin Blue : AEB 1.8TQM: F21 Turbo : UM Stage 3 : 3" MAF : Siemen 630cc : CX Racing FMIC : SSAC Test Pipe + RAI J-Pipe O2 spacer+ SSAC Full Exhaust : U-Shape Intake+AEM Dryflow : 034 2.0T Coil Conversion : Southbend Stage 2 : ST Coilovers : Walbro 255 Fuel pump : APR Snub
    Dec 10 2013
    Quote Originally Posted by 10kredline View Post
    You can't use S4 axles if 5spd. V6 axles and 01 1.8T axles are what you want
    IG: 24_et
    Sold:
    RIP:
    Dec 13 2010
    FL
    My edits are bold.
    will add
    also, the bira.org site is down for a while. so im not sure if they are still making kits or not. any more info on BIRA?
    you guys want to get me a complete list and ill add to the OP.
    B5 S4 uprights, V6 or 1.8t axles. what else, I know theres more
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I think you would be best off editing the OP to clearly identify which upgrades can be done without swapping uprights/getting brackets.
    Then add ones which brackets are available for.
    Then add ones which bolt up to S4 uprights.
    Links to relevant threads for the upgrades would be useful as well.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Dec 10 2013
    Aluminum S4 uprights: Required a new straight lower control arm. This control arm uses a longer, thinner balljoint
    Steel S4 uprights: Control regular control arms can be used. The A4/late S4 straight control arm have shorter, fatter balljoints
    Axles:
    All V6 axles will work for this application. Be cognicent of Auto/manual
    IG: 24_et
    Sold:
    RIP:
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Confirmed fitment of Centric (Stoptech branded) 950.33005 brake lines for 17z/18z calipers, AND 300mm rear upgrade.
    2000 S4- Working?
    Dec 10 2013
    Quote Originally Posted by redline380 View Post
    You use the same lines for the 17z/18z front as for thw rear 300mm? This is news to me
    IG: 24_et
    Sold:
    RIP:
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You can use whatever you like, but I had trouble confirming fitment before I ordered. Those are admittedly a bit long for the rear, but they work.
    Maybe OP should also note that you have to brake the plastic holder for the parking brake cable when doing the 300mm upgrade.
    2000 S4- Working?
    Dec 10 2013
    Interesting. Thanks!
    You have to break it when replacing the parking brake regardless. It really does nothing
    IG: 24_et
    Sold:
    RIP:
    Dec 13 2010
    FL
    Im not aware of any conversion that doesnt need swapped uprights or different carriers/brackets to work.
    Jun 30 2008
    Erie, Pennsylvania
    I think he means adapter brackets. So you can do 17z by using A4 uprights and adapters, or you can swap in S4/C5/B6 uprights and bolt them on without adapters. Further, once you swap the uprights, more options open up (options for which A4 adapters do not exist).
    Jun 30 2008
    Erie, Pennsylvania
    Apr 01 2011
    B5 on jack stands
    charlotte
    on the 986 bbk (312x25) you can use the usrt mk1 TT brackets/adapters too. I bring it up because they're about 100 bucks cheaper.
    also, you can swap b8 s4 brakes/brackets with ( 345mm b7/b6rotor) on a b5 S4
    powered by
    Hot Boi parts
    Dec 10 2013
    REAR-
    B5 S4 256mm:
    Requires new brake lines?Y/N??? <-- Does not require new brake lines. A4/S4 lines are interchangeable
    Answer in bold red.
    Also, can you fix my horrid grammar in the first post? I didn't realize it was that mucked. Lol
    IG: 24_et
    Sold:
    RIP:
    Feb 03 2007
    Correct, Im using steel s4 uprights with v6 axles. But what I wasnt sure of is if the aftermarket brakes will bolt right up to the uprights or not.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Thats a nice list of upgrades. Ive already done the S4 rear swap and can confirm the A4 lines do work. Im planning on doing 17z upgrade in the front with the Apikol adapter brackets because I dont want to deal with swapping axles, uprights and control arms.
    1998.5 A4 1.8TQM My Build
    Established Member Two Rings Blur2u's Avatar
    Oct 01 2004
    San Diego
    I have the 17z setup with the apikol adapters, you have to grind a little bit to make it fit. Also if you're planning on running the Merc rotors you need to get a shim, i can't remember what size though, probably 2mm. Apikol sells the shim also.
    I'm planning on doing the S4 300mm rears soon also.
    Quote Originally Posted by xdewaynex View Post
    - - - Updated - - -
    Thanks for organizing this OP!
    Dec 13 2010
    FL
    Quote Originally Posted by demonmk2 View Post
    i forgot that you can use TT brackets on the boxster calipers. is this true for the boxster "s" calipers too? OP updated
    geez, now you want me to fix the past for you?
    Big thanks all who are contributing to the information in this thread.
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    These brackets here? http://www.usrallyteam.com/index.php...oducts_id=1893
    If the Boxster S calipers are compatible, I may just go that route. A few pairs are on ebay at this moment.
    Dec 13 2010
    FL
    no, those are adapter brackets to fit Brembo 4-piston calipers to Mk4 Volkswagen/ Mk1 Audi TT spindles.
    you need the stock MKI tt carriers that ppl use for the A8 312mm upgrade.
    TT carriers 1J0 615 125 A
    Jun 10 2010
    PureMS indicates that those cars use the same adapters as B5 A4s (link).
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I think I might have confused you, because Im talking about using the 986 calipers with A8 rotors, not my A4 calipers.
    Dec 13 2010
    FL
    didnt see that. thanks for pointing it out
    yea, my fault.
    you can use MKI TT carriers which can be sourced cheaper than CNC brackets
    Nov 06 2013
    You meant Rotors?
    Orange County, CA
    Good thread!
    Possibly eventually sticky this in the Tech FAQ forum.
    B5 Parts For Sale
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Great thread, wish this was put together 5 years ago.
    Out of curiosity, why don't people run B6/B7 S4 front brakes on B5 S4 spindles? Demonmk2 touched on it, although mentioned B8 calipers. Any reason the B6/B7 calipers wont work? Seems like a cheap alternative to get a big (345mm) setup up front.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
