Results 1 to 14 of 14
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Aftermarket Valve Cover Gaskets
    Any brand you V6 guys have had good or bad experiences with? Wife's car is gonna need em. I use genuine audi ones on my B5, but I'm not sure about the quality difference of the aftermarket B6 ones..
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Audi doesn't make their own parts.
    They have other companies make them, with the audi VW logo stamped on, and then charge you 4x the cost or more.
    That said, elring and Victor reinz make the OEM gaskets for audi. So either of the two will be fine.
    Audi Club Bay Area
    Nov 10 2015
    Sudbury, ON
    I use Felpro for everything. ZERO issues, top notch items. 1/2 VW/Audi price also
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Yep. Used all of the above at some point or another.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Dec 14 2014
    PNW
    Quote Originally Posted by Furly View Post
    Yes, I understand this, I was curious about the quality of the aftermarket supplier parts, I've noticed/heard of some differences between genuine and oem suppliers for certain parts before.. but looks like you fellas haven't had issues with the aftermarket and oem suppliers gaskets. Thanks for the replies
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    I bought some Victor Reinz for my Infiniti and Audi, I haven't installed them yet. However, the quality looks extremely well and I don't see an issue with them.
    Aug 27 2013
    Philly
    FWIW, I used Victor Reinz on my 3.0 last time and the drivers side bank has just started to develop a leak near the oil cap on the inner portion of the cover. I torqued down the bolts a bit more so we'll see if this fixes it. It's also important to note that I had a PCV issue recently with a clogged valve. This could have lead to increased pressure, causing this cover to leak.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    this...
    Mar 01 2016
    Bay area
    I was just about to ask this question, good info knowing that I can buy these aftermarket.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by SJorge3442 View Post
    I'm not saying this is the case for you, but over-tightening can have the same effect as a failed gasket or under-tightened component. Over-tightening can just squeeze whatever gasket is there out of place, also causing a leak. We have a few items at work that have fairly low torque specs that seem way too low, but we found out that it was set that way to get a proper seal of components. Once we started checking the torque during re-assembly, leak problems after our repairs went way down.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    As long as you purchase a valve cover gasket with torque limiting inserts you don't have to worry about over/under tightening. The gasket should have metal inserts for each bolt hole. Once you tighten all the way down to the insert the gasket is properly compressed. Additional torque on the nut will not compress the gasket any further. If you keep tightening you will eventually strip the nut but you won't over tighten the gasket.
    If you purchase a VCG without the inserts just throw it away and get a proper gasket.
    Dec 14 2014
    PNW
    Im guessing these are found on genuine/oem gaskets usually vs a local auto parts store gasket?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by cjt671 View Post
    Not necessarily. Several years ago I picked up a VCG from AutoZone that had the inserts. They couldn't find a listing for my '03 B6 so I asked for a VCG for an '03 1.8T Passat. Worked fine.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    FWIW, the 3.0 VC gaskets have no inserts. The limiting feature is built into a collar on the bolts.
    Audi PN: 06B103831J
