Results 1 to 17 of 17
    Established Member Two Rings evilpulse8's Avatar
    Mar 10 2014
    B8 Avant Prestige A4, B7 A4 revo stg 2(sold), B5 S4 vast stage 2(sold) B8 A4 Avant Sline
    City of Industry
    Did PCV delete and not happy
    Hey guys, I recently did a pcv delete(no catch can) on my B7 2.0t FSI and I've been reading on some posts that some people are having large exhaust smoke coming out while in WOT. I seem to be getting it only once when I go WOT and then it's fine until the next day and I've noticed that it misfires when that happens as I hear a loud backfire(catless DP with electric cutout) and lately my oil has been disappearing, I would guess that it's being dumped into the intercooler as I'm starting to hear a little flutter when I realease boost
    Anybody have any experience on the pcv delete kits? I'm going to revert back to stock. Anybody recommend any additional parts or why maybe I should keep it???
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Why did you do a pcv delete in the first place?
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 10 2014
    City of Industry
    I thought I had a bad pcv so I decided to remove it because I was only doing 14psi with no leaks found. But after I realized my revo tune reverted to stock after I unplugged my battery to add a secondary battery in the trunk
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Ahh lol. Ok.
    Well, here's a pretty great pcv thread http://www.audizine.com/forum/showth...stem-explained
    I never was in favour for the block off plates. I just recently ( week ago) put a catch can on, and in fact retrieved some loss of power. I was under the impression that a block off plates causes the vapours to find other ways to escape, IE: Seals. But I have no experience with them
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Keep the stock system. Ive experimented with many aftermarket products, and nothing else will cater your needs to pull vacuum out of the crankcase as well as the stock pcv solution. Sure, it will not filter the vapors as well, but at least you will have vacuum at idle. When i put in my 034 catch can, i could hear the the blowby gases / pressure resonating in the airbox.
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jun 27 2011
    As an aside, I find it irresponsible of places like bsh selling those block off kits and advertising them as "fixing the stock PCV". They don't fix shit! They only cause more problems.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 10 2014
    City of Industry
    Yeah very true, I was really mislead thinking it would do good but I guess not. Never had such a bad oil consumption till after I installed it, minimal oil light turned on 500 miles after an oil change from the vw dealer.
    What a waste of $85
    Sep 10 2014
    Detroit
    Quote Originally Posted by Denio24 View Post
    Hmmmm, I thought the 034 kit was the way to go. Functions just like the stock deal but filters out junk.
    I had mine not dumped back to the drain, and upon taking the bottom plug out for the first time, it caught a lot of fuel/water.
    I bought it to replace the BSH kit, as my car didn't seem to like it at all.
    Jan 23 2013
    Chicago
    Its not a bad system, and i believe the ecs one has better hose routing design, but to me a vacuum on crankcase is more important than some carbon buildup if you dont drive your car like a grandma.
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I have this pcv kinda delete fix and it work well in terms of
    power. No smoke, no noise and no lost of oil. I know that some oil goes back in the turbo and the IC , but no that much.
    http://www.golfmk6.com/forums/showthread.php?t=80623
    Envoyé de mon SM-G903W en utilisant Tapatalk
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Jun 26 2008
    Chicago, IL
    Why not just buy a hose and loop it back. Ode to carbon buildup
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Mar 10 2014
    City of Industry
    I got a check engine light caused by my WOT pulls. Got a P0340 code, I'm not sure if it was due to the low oil. Checked my dipstick and no oil on the dipstick and no low oil warning icon. I reverted back to the stock PCV and check engine light went away but I'm still getting crazy misfire/backfires with smoke on WOT @ 5-6K RPMS. Does it take time to go back to normal?????
    This all started when I did the PCV delete
    HPFP and Cam guide were done 12k miles ago
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    No oil on the dipstick? That doesn't sound good...
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by evilpulse8 View Post
    Did you remove any of the coil connectors for access ? Sounds like you may have disturbed something while you were in there
    Mar 10 2014
    City of Industry
    Yeah I actually unbolted the fuel pressure sensor(I think) but didn't pull it all out since I was making a mess of fuel
    Mar 10 2014
    City of Industry
    My car is working fine now for driving about 500 miles after reverting back to stock definietely feel the same I power I had when I first did the revo stage 2
    Established Member Two Rings brax's Avatar
    Aug 17 2004
    01 S4 Stage III+ b8.5 S4 etc etc
    chas sc
    bump.... can anyone help code out my egr/pcv system? im getting 3 codes now after the delete, i have my ecu dumped via bdm -- b7 med9 audi 2.0T thanks!
    <img src=http://pictureposter.audiworld.com/70700/sig_st3.jpg>
