Results 1 to 14 of 14
    May 01 2012
    Cerritos, Socal
    Spark Plug torque spec
    its that time again to change my plugs. was wondering what the torque specs were for our cars. cant find it anywhere online or on here.
    2 finger special?
    thanks
    *nm. found a vid online
    28nm + 90 degrees
    '14 RS5 Suzuka Gray | Akrapovič Exhaust
    Jan 02 2016
    Lakeville, MN
    When I was researching I found it to be 22ft lbs. That's what I torqued mine to even though it felt pretty tight for a spark plug, however there are crush washers on them so that needs to be taken into consideration. I'd say you're right on, 28nm = ~20.5 ft lbs.
    Feb 20 2006
    NC
    hand tight plus 90 degree
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    On all of My VWs and Audis I have always done 22ft Lbs. The plugs always come out without destroying threads but don't loosen on their own causing a compression leak
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by ihkskim View Post
    2 finger special?
    thanks
    28nm + 90 degrees
    That is the torque spec for the Bosch plugs. DO NOT tighten the NGK plugs to that spec. They are more like the 22 lb/ft mentioned above.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Mar 26 2010
    US
    From NGK: Aluminum: 18-21.6 lb. ft.
    NGK 94460 PFR8S8EG, Thread Size: 14mm
    http://www.ngk.com/product.aspx?zpid=29891
    https://www.ngksparkplugs.com/about-...g-installation
    BMW M3 Competition X-drive
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    haven't done mine yet and was planning on doing it this spring...do the factory plugs need a special tool like the BMW's 20 or so point spark plug?
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    May 01 2012
    Cerritos, Socal
    Quote Originally Posted by jran76 View Post
    ooo thanks for that info. i got the NGK's lol
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Another reminder, it's best to change the plugs when the engine is cool. The aluminum head expands much more than the steel spark plugs. Torquing down a set of plugs in a hot and expanded head will cause the head to contract on the plugs once it cools. This could lock them into place or snap when trying to remove later on. Lastly, 22 ft*lbs like everyone said.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    May 01 2012
    Cerritos, Socal
    Quote Originally Posted by vwblackb5 View Post
    just 22lb or 22lbs plus 90 degree?
    Nov 19 2011
    Rhode Island
    does a regular spark plug removal socket work? My older BMW needed a special tool from BMW to get the OEM ones out.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    NGK's are 22 lbs and nothing else.
    Bosch are 28nm PLUS 90 degrees.
    Quote Originally Posted by dizzlesizzle View Post
    Yes, regular spark plug socket works fine.
    Nov 19 2011
    Rhode Island
    Cool thanks for the reply.
    Jun 26 2007
    New Jersey
    22 ft*lbs and that's it. I hope you're using a torque wrench. It will click at that setting.
