Results 1 to 33 of 33
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    Exclamation Did I just ruin first gear?
    Alright so im going to get flamed for this but i do not care as i need to know whats going on. So the other night i decided to launch my car (quattro 1.8T 5 speed) From 4500 rpm after i dumped the clutch it kinda just surged then took off after that everything was fine, or so i thought. so i went on at home washed it and parked it. i came back a couple of hours later and started it up then started driving, backed out of the drive way then put it into first now when letting out the clutch and starting to move there is a weird noise kinda like straight cut gears. the whine noise only happens in first gear. the noise never happened before i launched so im assuming i messed something up. the noise is really noticeable when coasting at high speeds and putting it up against the first gear lockout mechanism. in the video im going about 50 mph while holding the clutch in and putting the gear lever up against 1st gear lockout mechanism, no i know that there is no need to do this ever and in the video it looks as if im forcing it into 1st but im not its only slight pressure. The car drives completely fine and the only thing that has changed is the 1st gear gear whine. can someone please help identify whats going on?
    https://youtu.be/TsdBqvM1a2I
    Aug 27 2013
    Philly
    this is what my 3.0 sounds like in reverse. Sorry that doesn't help, just stating some facts.
    Jun 27 2011
    That is the sound of $$$
    To an extend that whining is normal, it's your synchros working. It generally shouldn't be too loud though.
    And that crunch isn't good nor is it normal. If that happened after dumping the clutch (hint, that's never a good idea) then I think you know your answer regarding what's wrong...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It sure sounds like you cracked or chipped 1st gear. Sorry!
    And for the record there is no “1st gear lockout”. That high pitched whine that you hear is the sound of you shredding your 1st gear synchronizers as you attempt to speed the gears up to an equivalent engine speed of 20,000+ rpm.
    STOP DOING THAT!!!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Correct me if I am wrong, but if he was launching the car, the gear would already be engaged. There should be no wear on the synchro because is wasn't being used. There transmission was still, which is what makes me believe he has a clutch issue. Yes, the tranny is shocked by popping the clutch like that, but everything was probably already engaged.
    Now, if he we in neutral, revved up to 4.5k, then did a quick sequence of jamming it in gear and popping the clutch, I could see some internal issues. But that isn't the way people launch cars.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Dec 28 2006
    Western Maryland
    Yes you are correct. He launched it with 1st gear already engaged. I suspect the extreme “hammering” from dropping the clutch damaged the already engaged gears. Just because they are already engaged doesn’t prevent them from being damaged by excessive force.
    The synchro wear to which I am referring is when he attempted to put it in 1st gear at 50 mph.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Missed that part. Yup, that'll do it! Lucky for him it didnt catch.
    2000 S4- Working?
    Jun 27 2011
    Dropping the clutch from first puts a HUGE amount of pressure on the gears. Since they're helical cut they tend to push each other apart also so chipping gears isn't uncommon with modern transmissions when they're subjected to shock loads like that.
    Also what old guy said and I was alluding to, that whirring/whining is the 1st gear synchros spinning up to try to mesh the 1st gear with the car speed. And since first gear tops out at 30ish mph you're wayyyy over revving the transmission and synchros. You should stop doing that.
    -CP
    2017 Q7 3.0t
    Dec 05 2007
    Quoted for pure silliness
    Mar 04 2015
    Champaign, Illinois
    Thanks for all the replies, I learned my lesson! No more launches for me
    Also thanks for not flaming the shit out of me
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Sounds like a chipped or broken tooth. Replace the fluid and see what comes out. You don't want debris floating around in your gearbox.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Jun 27 2011
    Quote Originally Posted by cschuster View Post
    Yep. I would do that for sure.
    -CP
    2017 Q7 3.0t
    Mar 04 2015
    Champaign, Illinois
    So about 1 month ago i replaced the fluid would it be ok to drain it, filter out all the metal pieces, then just reuse the fluid after filtering it? or do i have to buy new fluid?
    I also have a magnetic drain plug in if that matters
    Also would i be able to feel it if 1st gear is chipped or something? wouldn't it not grab for a second? how can i know for sure without pulling the trans?
    Jun 05 2013
    Lexington, KY
    Depends on the kind of filter you have. Something in the micron range? Sure. Just spend the 35 bucks and replace it - way easier.
    Sent from my Nexus 5 using Tapatalk
    2011 TTS
    Mar 04 2015
    Champaign, Illinois
    sorry for the lack of knowledge but i was unaware that it even had a filter is that something im supposed to replace?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You dont have a filter. That guy (I hope) thinks you have an auto because he didnt read the thread.
    2000 S4- Working?
    Jun 05 2013
    Lexington, KY
    Quote Originally Posted by 123lilc View Post
    There is no filter in a manual trans. There are a few magnets inside the center diff housing, but no filter. I was talking about filtering the fluid outside of the trans. You can assume that 1 or more teeth are either chipped or broken. No way to tell the exact damage until you take it apart. To get to 1/2 gears, the whole trans has to be disassembled.
    This is what that shaft looks. Biggest gear is first.
    2011 TTS
    Jun 27 2011
    In that case, maybe just drain it into a clean clear container and just see if there is any floating debris and inspect the drain plug for any large metal flakes.
    -CP
    2017 Q7 3.0t
    Jun 30 2008
    Erie, Pennsylvania
    For the price of a 5-speed transmission, I wouldn't bother even doing anything about it. It will quite likely make noise for the rest of it's life, and nothing more will come of it. If it blows up, get another transmission. The 5-speeds are a dime a dozen.
    Draining the gear oil and either replacing it with new oil or filtering it would be a good idea. Replacing the drain plug with a magnetic version would be wise.
    Aug 26 2005
    Filtering the used trans oil is not practical, IMO. A magnet won't catch any copper based alloys used in the synchros and bushings.
    Vorsprung durch Technik
    Mar 04 2015
    Champaign, Illinois
    so basically if everything still functions i can still drive it correct?
    just change fluid and ill be good to go correct?
    (ovioulsy with no more launches ad going easy on first gear)
    Established Member Two Rings 2000blk1.8t's Avatar
    Jan 26 2014
    Livingston
    I second what walky said. I'd run it until something happens. If it does totally fail, you might still be able to take off in 2nd to atleast get you home.
    Oct 29 2005
    10speed
    San Francisco, CA
    I did this to 4 or 5 transmissions. For some reason it only happens after launching hard in 1st. You have plenty of time left but I'd get a spare lined up.
    - Clint
    Jun 30 2008
    Erie, Pennsylvania
    I always just launch in 2nd gear. Problem solved.
    Jan 06 2009
    As already stated nothing will self destruct. My 6spd has been doing this for 130k kms. I do have a spare if and when it really fails...
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Dec 05 2007
    Your logical reasoning is impractical and unwanted here, Keith. Stay in the B5 section where you belong, you non-mechanic. Why do people even listen to you?!?!
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Seems like OP might have $$$ shifted. 50mph and forcing into 1st, did you bounce off the rev limiter?
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Dec 28 2006
    Western Maryland
    To be fair to the OP, he stated that he didn't actually push hard enough to engage first gear. He just pushed against the synchro enough to hear gear whine.
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    I don't think he knows how to properly use a manual gearbox.
    Nothing he did in that video was ok imho
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by vwblackb5 View Post
    No. He launched it hard in first. As I said, I did this to probably 4-5 transmissions. It happens when you launch really hard.
    Quote Originally Posted by f1torrents View Post
    He was trying to mimic that sound to show everyone...
    - Clint
    Mar 04 2015
    Champaign, Illinois
    Exactly! Thank you!
    Jun 26 2007
    New Jersey
    No. He launched it hard in first. As I said, I did this to probably 4-5 transmissions. It happens when you launch really hard...
    On your V8 swapped B6 or when you were first learning how to drive a manual car?
    Oct 29 2005
    10speed
    San Francisco, CA
    I did it on my black B6 both with a K03 and GT35R, why?
    - Clint
