Results 1 to 12 of 12
    Oct 19 2015
    WI
    Help troubleshooting B+O stereo
    I'm hoping someone here can help me in understanding whether my Band & Olufsen stereo is performing appropriately. I recently had the subwoofer replaced and it simply doesn't sound right to me. The bass just sounds "dirty". I'm hesitant to push it beyond 15-18 because of how it sounds. I purchased the car with tinted windows and am aware of the water damage that can sometimes be associated with window tinting and subsequent amp failure, so I brought it up and the dealer tells me the amp is in perfect working order. I don't know how to check that, but I'm open to learning if there is a way.
    So, I did the only thing I know to do and that's go into VCDS and put it through a self-test, while I recording the data along the way. If you aren't familiar, the self-test basically moves around from one speaker to the next, playing some white noise and providing the voltage of each speaker. All speakers produce sound (Yay!). The voltage bounces around pretty quickly, like 5-10x per second, so I captured the range in which it moved to see if that tells someone something.
    Speaker Lowest Voltage Highest Voltage
    LF Treble .6 1.08
    LF Mid .2 .32
    LF Bass .08 .16
    RF Treble .4 1.12
    RF Mid 2 .44
    RF Bass .16 .24
    LR Treble .4 .64
    LR Mid/Woofer .12 .2
    RR Treble .2 .4
    RR Mid/Woofer .12 .29
    Effects Left .24 .4
    Effects Right .16 .24
    Loudspeaker Center .32 .56
    Tweeter Center .52 1.04
    Bass Loudspeaker .08 .12
    Observations (remember, I'm no stereo guy):
    Voltage on the sub is lower than the voltage of any other speaker. It's also relatively stable compared to others.
    Some "like" speakers (Effects left & Effects right) have voltages that don't even overlap.
    Any audio experts out there that can help me with additional troubleshooting?
    Aug 29 2013
    Mt Pleasant, SC
    Quote Originally Posted by TheNuke View Post
    What did you replace the subwoofer with? Another OEM B&O subwoofer?
    I honestly have no clue what on Earth you are talking about here?
    The B&O amplifiers are located in the trunk. How would tinting the windows cause water damage to an amp located in the trunk?
    2013 Audi S6 Ibis White, Black interior, LED headlights, 20" alloy wheels, Carbon Atlas inlays, Audi side assist
    Mods Bel STiR Plus, Blinder HP-905, BlackVue dash cams (front and rear), Black Optics grill, Black window trim, XPel Ultimate film, Modesta BC-03 glass coating
    Oct 19 2015
    WI
    Thanks for the reply!
    Quote Originally Posted by subterFUSE View Post
    The dealership replaced the sub with another new B+O sub.
    :) When the original sub started acting up I did some research and found that a few people had issues where the tint shop they went to used quite a bit of tint solution/water/whatever when applying the tint film to the inside of the rear window, which drained down into the sub amp location and caused issues. Hopefully that makes a little more sense.
    Mar 26 2010
    US
    ... When the original sub started acting up I did some research and found that a few people had issues where the tint shop they went to used quite a bit of tint solution/water/whatever when applying the tint film to the inside of the rear window, which drained down into the sub amp location and caused issues. Hopefully that makes a little more sense.
    That was common problem causing amplifier failure on the B8 A4/S4 models.
    BMW M3 Competition X-drive
    Mar 29 2014
    Hampshire, UK
    Perhaps the easiest thing would be for another forum member, also with VCDS, to run the same test on their B&O system.
    You can then do a comparison of the result.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Sep 22 2013
    Norway
    Just as a sidenote, not to hijack, my amp has gone, well almost.
    If I ask the dealer to "reset it", it will work for 2 engine starts, after that I loose the front tweeters, and all bass.
    I dont know how to interrogate this with VCDS, does anyone have a clue?, the replacement amp is 4k USD here in Norway, and I cannot find any on ebay.(4G0.035.466)
    Kim
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by Soft View Post
    Kim
    http://www.ebay.co.uk/itm/Audi-S7-A7...IAAOSwu1VW4jSy
    Repair in the UK?
    http://www.ebay.co.uk/itm/AUDI-BANG-...cAAOSwVcFXPHi4
    This one has a slightly different part number, but if you look on Ekta, it's compatible with up to 2014 A7, so may be worth looking at?
    http://www.ebay.co.uk/itm/Audi-A6-4G...UAAOSwxCxT8ZVs
    Sep 22 2013
    Norway
    Quote Originally Posted by jkwelsh View Post
    Repair in the UK?
    Thanks for the effort! :-)
    But the amp that is struggling is the B&O Ice slave amp like this :
    http://www.ebay.com.au/itm/2011-2012...-/201298618046
    Non of the ones you link to will work
    I'll look into the repair option.
    Senior Member Two Rings FourRingThing's Avatar
    Jun 17 2011
    Charleston, SC
    what you are describing sounds like the speaker is out of phase with the others. you may want to look and make sure the + and - are connected properly. I had issues with that whole sub module vibrating, I crammed foam between it and the deck fixed it right up.
    2021 B9 S5, Black optics, Sorts Package, Black door handles, spoiler wrapped black, IE intake and inlet pipe, ECS Tuning strut tower support.
    (sold) 2012 C7 A6 3.0T Prestige, Innovation Package, 20" Sport Package.
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    I have a 2012 A6 with B+O and I honesty feel like it's missing tons of mids it's like nothing is there the car has 98,000 miles and I'm wondering if it's normal for B+O system to not have a whole lot of bass and the deck to be vibrating in the back of the car.
    Sent from my Moto X Pure.
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Aug 29 2013
    Mt Pleasant, SC
    Quote Originally Posted by FourRingThing View Post
    We should meet up sometime. I've never heard the B&O system in the C7 before and I'm very curious to see how it sounds.
    This is what's in my S6 currently.
    Jun 17 2011
    Charleston, SC
    Sound good I would love to check out your S-6 as well, your stereo looks impressive. I am into audio and home theater as well. Send me a PM and we can meet up, I have not seen your car around town.
