Results 1 to 10 of 10
    Active Member One Ring jmustaparta's Avatar
    Dec 10 2014
    Elkridge, MD
    2014 B8.5 S4 Brake Replacement Options (Pads + Rotors)
    Hello everyone,
    I own a 2014 B8.5 S4 with around 24k miles currently due for brakes replacement. I'm still using OEM Pads, front (3mm), rear (5mm) according to the dealer. The brake pads light comes on if I do any hard stop since last week.
    What are my options for replacing my brake pads and rotors (if needed):
    • No Track Use
    • Cold Weather (Maryland)
    • Daily Usage
    • Would prefer OEM stopping power
    Who makes the OEM S4 pads ?
    Anyone using AKEBONO ceramic pads in cold weather ?
    Anyone using the Centric Posi Quiet pads from Tirerack ?
    2014 S4 - DSG - Phantom Black Pearl
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I just replaced all 4 pads and rotors at 62K miles. I put on 4 all new OEM rotors, and Stoptech Ceramic pads. You could alternatively use Akebono, or Wearever Gold ceramic pads. Wearevers will be cheapest. Regardless, they will all stop well enough for street use. Brake dust and squeal will be gone!My Stoptech have the same stopping power, but initial bite is less than OEM. I noticed the difference for the first week . After that, I guess I just got used to the new feel. I live 50 miles north of Phila, so I have been driving in the cold with no brake issues.
    Mar 21 2015
    Akebono on factory rotors for me. No issues in MD. Daily use and no track. Love the no dust factor, that's the reason I switched.
    Veteran Member Three Rings BJYorko's Avatar
    Jun 02 2015
    Minneapolis, MN
    Live in MN (our weathers are worse than yours) and I use the Akebono euro ceramic pads. Most of the B8 and B8.5 audi guys I believe here in MN use them as a daily driver option. I love them. Yes, you will notice a slight decrease in initial bite, but after about a day of driving your mind will automatically adjust and won't even notice the difference as it is such a slight adjustment. Overall these are a great option and I will be replacing these with new akebono's once these pads wear out, but that won't be for a while. I highly recommend them.
    Current: 2017 S6 Prestige | Mythos Black | DS1 stg 1 | mods in progress
    Sold: 2014 S4 P+ | Phantom Black Pearl | DSG | Loaded | lots of mods
    Sold: 2010 S4 Prestige | Phantom Black Pearl | 6MT | loaded | lots of mods Link to Build Thread
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    ECS 4 lightweight floating rotors and Akebono Euro pads front and back on my car.Also front and rear ECS braided brakes lines... good stopping..no squeal and minimal brake dust..
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Dec 10 2014
    Elkridge, MD
    Thanks for the comments!
    I'm decided on the Akebono Ceramic Pads.
    Front: EUR1322A
    Rear: EUR1018
    Are these the correct part numbers ? I noticed the Rear pads set doesn't include the clip, is this a concern?
    I'm still undecided on rotors... I hate the way the OEM rotors look, specially how rusty they get. I'm currently leaning towards Drilled/Slotted rotors. Any recommendations ? The ECS 4 are out of my price range...
    Nov 23 2014
    North Carolina
    I hope those are the right numbers, that's what I put on my car last week.....
    as far as rotors. look at the ECS geomet rotors (come in both slotted only [my recommendation] or drilled and slotted), rock auto has the stoptech slotted and drilled (respectively) for a great price, and then there is always adams rotors so you can select your own design.....
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Jul 21 2004
    South Florida
    If you are set on getting some drilled or slotted rotors i'd also suggest the stoptech drilled. They overlap the holes which help prevent or reduce ribbing.
    Mike
    2018 Audi S5
    Gone-
    Senior Member Two Rings rockstar143's Avatar
    Oct 01 2013
    United States
    Just wanted to chime in on akebono and the google search for pertinent threads led me here...
    just swapped the fronts out to the ceramics and holy shit do they make a difference in almost no dust.
    I used to wash the car and drive to the store and you'd already see a haze of dust. Now, a week after a
    wash you can't really tell the wheels are dirty. Which is good because the car color doesn't show dust
    much either.
    Senior Member Two Rings Z06Corey's Avatar
    May 24 2019
    I swap all my car brakes out for ceramic. Other than a slight pause in grip compared to semi metallic when cold no performance difference. Check out rockauto.com for parts before buying as a price comparison.
    - - - Updated - - -
    Holy old thread...
    2019 S5 SB. Prestige, black optics, B&O, sport diff. 034 stage 2/2 ECU/TCU, 034 downpipe, APR intercooler, 034 transmission insert, 034 turbo inlet, CTS intake
    2017 R8 V10+
