Results 1 to 34 of 34
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    FYI, Cost of replacing the ZF 8HP fluid and the 3 differentials oil
    I have 66K + miles on my 2012 A6 and have tracked the car more than dozen times. So I became concerned about the transmission fluid. I contacted ZF thru their web site to get their thoughts when I should replace the fluid. They responded with the following.
    For further processing of your request, we kindly ask for the following information:
    Since you drive your vehicle hard and you've modded it, I'd suggest changing the fluid every 20-30k miles. If you track it all the time you may want to do it even more often. Most people are changing the fluid in normal driving situations at 60k miles or 8 years..
    Please reply to this mail using the “Reply” button of you mail client – DO NOT CHANGE THE E-MAIL SUBJECT.
    For further questions or updates please contact ZF Services North America, LLC., telephone: +1 847 478 6868.
    Always provide your request ID when contacting us regarding this request, please.
    Kind regards
    Your ZF Service Desk
    ZF Friedrichshafen AG
    88038 Friedrichshafen,Germany
    So, I inquired at my dealer as to what the cost would to change the transmission fluid/filter and 3 differentials oil. Did not get a very concise answer but did get their cost for the fluid which was $51 a liter. In any case I decided to purchase the filter and fluids thru ECS tuning. I purchased the ZF's Lifeguard8 fluid(9 liters), Motul gear 300 75w90 oil(3 liters), filter and transmission fill plug. Total cost was $682. Shipping was free.
    I found local independent garage to the work saving $30/hour in labor. The actual labor time was just under 6 hours for $585. So the total cost was $1277 to have this work done, not cheap.
    I will be sending a sample of the transmission fluid out for analysis to determine it's condition.
    Prior to have the fluid replaced I was not experiencing any issues with the transmission but since I do track the track the car 2-4 times a year I was wanting to be cautious so that I did not have replace the transmission if I had catastrophic failure sometime down the road. Since the fluid replace I believe I am noticing a slight improvement in the smoothness of the shifting. Overall happy with the outcome but the analysis hopefully will determine how often I need to do this in the future.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    This is great information, IMO. I was thinking the other day that there must be some info on this. I don't believe in these "lifetime" fluids and will probably be changing them down the line sometime. It's interesting that they recommend every 60k or 8 years. You'd think Audi would put this in their service list somewhere. Thanks for posting this information.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Dec 05 2015
    Chicago, IL
    Thanks for posting this. Please let us know what you find out from the analysis.
    Oct 11 2011
    2018 A5 SB
    Transmission Fluid analysis
    So, here is the transmission fluid analysis.
    [IMG][/IMG]
    Dec 05 2015
    Chicago, IL
    Good info. Thanks for sharing.
    Active Member One Ring JRomulus's Avatar
    Aug 13 2010
    Chicago
    Thanks for posting this. I am coming up on 90k miles on my 2013 A6 3.0L and would like to keep this car long term. To me it only makes sense to change the ATF fluid. Here is the response I got from the local Audi dealer:
    "Here is the estimate for the transmission service. It is a fluid and filter exchange with new gaskets and hardware. It is $1345.00 to perform the transmission service. Again, I did speak with a technician and he does not recommend performing this service as the new fluid will act as a detergent and may cause damage to the internal gears."
    Didn't I see a picture somewhere of the pan having magnets that catch some of the metal bits? And what is with the "detergent" comment anyway? Thanks for any input.
    Sent from my SAMSUNG-SM-G870A using Audizine mobile app
    CURRENT: 2013 A6 Prestige 3.0T Phantom Black Black Headliner Innovation Cold Weather LED Headlights
    SUMMER:19" DWS06 225 40ZR19 WINTER:18" Pilot A/S 3 245 45ZR18 100Y XL
    INJEN SP3085WB SP Short Ram Air Intake EBC Ultimax Slotted Rotors - USR1845, USR1846 EBC Red Stuff Brake Pads - DP32086C, DP32082C
    MILES: 122,500
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by JRomulus View Post
    IMO it's always been a myth of the 'new fluid causing damage to an old transmission.' If new fluid causes the trans to fail it was probably on it's way out anyway. The thought is that the new fluid will cause some of the deposits to come loose and interfere with things and break the trans. I'm right around 52,xxx miles and I'm going to change the fluid in mine just for piece of mind. I've never bought into this whole "lifetime" fluid thing. Change your fluid and i'm sure your trans will be happy for it.
    Established Member Two Rings SHR's Avatar
    Apr 01 2012
    2013 C7 A6, 1998 B5 A4, 2011 Honda Odyssey, 2002 B6 A4
    Pittsford, NY 14534
    +1^ I agree 100% that changing the fluid is a good thing and shouldn't have any negative impact on the transmission, however there is a procedure that needs to be followed. You've got to ensure that you are filling it to the recommended level while the fluid is at a specific temperature range, and the only way to do this is with VCDS or a factory tool. I found a great post that includes everything you need to know to perform the transmission service found here, be sure to click on all of the links:
    http://carltonbale.com/audi-s4s5s6s7...hange-details/
    For context, while a completely different transmission, I purchased a 98 B5 A4 1.8TQA with 175k miles for my son, the car was pretty rough. I read all about the warnings to not change the fluid because I would surely ruin the tranny because of disturbing the metals and assorted repercussions. I did it anyway, and in fact I changed it out again after 10k miles just to flush it out. The first change found nasty black fluid with lots of crud in it. The magnets looked like porcupines and I could write words in the sludge on the pan. The second change at 10k was a different experience, the fluid was pretty dark but certainly not black, and there was no sludge, and the magnets did not have metal shavings that I could feel, I'm sure there was something there but nothing measurable. Its been 2 years since and the tranny runs perfectly.
    The outcome is that the 18 year old B5 shifts as smooth as my 2013 C7 with 60k miles and may shift better at this point.
    Regarding the cost which is the title of this thread, the OEM fluid is stupid expensive, I used the Blauparts kit for my B5 which was less than half the cost of OEM and haven't decided yet if I'll use OEM or Blauparts kit for my C7.
    I'll be changing out my C7 ATF within the next 6 months or so and I'll report back afterwards. I hope this info helps.
    Gone - C7 A6
    Gone - 2012 S4 | Phantom Black | Prestige | Titanium | Black Silk Nappa | 6MT | Sport Diff | Carbon Inlay | Full Front 3M Paint Protection | 3M Crystaline Tint 50% | Passport SRX | Bilstein Eibach B12 Prokit GTF 25.7 | Wilson Electronics Signal Booster | DIY and OEM IC Protection Screen | Piano Black Painted Dash Surround | BFI Spacers 10mm x 4 | Michelin Pilot Super Sport 245/35 19 |
    Oct 11 2011
    2018 A5 SB
    Further follow up since replacing the transmission fluid. I have put about 9K miles on the car since the change. The transmission is performing just fine. I have been to 2 track events and have experienced no issues with the transmission.
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by SHR View Post
    FYI this procedure is for the 7-speed S-Tronic, not the ZF 8-speed that is in your car.
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    I actually made a thread about this last year that if I can find again I'll post the link. I went through a ton of shit with AoA and spent hours on the phone with ZF asking questions and getting answers. Basically yes you must drain it and fill it. 60-80k is the ideal range. AoA only claims its lifetime to make the cars seem cheaper to maintain. It's total bullshit. I drained mine, swapped filters and all that jazz and it ran a lot better. Bad fluid doesn't lubricate and causes it to get too hot.
    PS only use LifeGaurd.
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Jan 09 2013
    UK
    Interesting, I too asked about the ZF and Audi UK say it is sealed and for the lifetime of the box and then try top put you off by saying the cost of the oil is £400/liter.
    Changed ATF and MTF fluids at around £100 + VAT each as part of my 40k mile service.
    Apr 01 2012
    Pittsford, NY 14534
    Quote Originally Posted by RRF985 View Post
    Thanks for pointing this out. Do you or anyone have the specs to change out the ZF fluid? I'm primarily looking for the temp range to check the level and the torque settings for the filter and pan bolts. Thanks again.
    Gone - C7 A6
    Dec 30 2014
    2013 A4 Prestige, 2013 A6 Prestige, 2001 Range Rover, 2001 BMW 330i
    United States, Show-me state
    Correct temp range to check ATF level is 35 °C to 45 °C (95 °F - 113 °F). Hot climate countries maximum 50 °C (122 °F).
    Filter is not secured with any bolt. I haven't done replacement so not sure exact mechanism of securing the filter, but it appears to be sandwiched by valve body and ATF pan.
    There are three steps to for securing the 12 ATF pan bolts (need to use new bolts):
    1. Install the new bolts by hand
    2. tighten to 4*Nm following AFT pan bolt tighten order
    3. tighten 45° additional turn following AFT pan bolt tighten order
    ATF pan bolts tightening order:
    Download this Q5 specification book and check the transmission section page 76.
    http://www.audiworld.com/forums/atta...-spec-book.pdf
    audi bug --------------------------------------------------------------------------- audi bug
    @ 13 A6 Quattro 3.0L TFSI Prestige Phantom Black - Innovation package, 20" Sport package, LEDs
    @ 13 A4 Quattro 2.0L TFSI Prestige Midnight Blue - Driver Assist package, S-Line package
    @ 06 A6 Quattro 3.2L FSI - traded @185k in 16.
    Apr 01 2012
    Pittsford, NY 14534
    ^ thanks audi bug, that's what I was looking for.
    Gone - C7 A6
    Dec 30 2014
    You are welcome!
    OMG, I realized I mixed ATF pan and ATF fan!
    And just edited
    Senior Member Three Rings dc2002's Avatar
    Jan 29 2007
    Roswell GA
    I did trans fluid and filter on my old B5 A4 and my old B7 S4 and the filter was just a pressure fit sealed with a rubber o ring/gasket in the trans where you shove the filter tube up. There is a lip that the filter tube "stops" at.
    Be careful not to dislodge the o-ring/gasket - I remember i did that on the S4 and it took me like 15 minutes to fish it out as it got shoved up the hole a ways and caused a minor freak out.
    All in all not a horrible job...hardest part was keeping the gasket lined up on the pan while starting the first couple bolts.
    I havent decided if i will do mine or go to an indy shop...i am sure the dealer would be outrageous.
    I am just at 50K now and will want to at least do the trans by 60K.
    Quote Originally Posted by audi bug View Post
    2012 A6 3.0T Prestige
    EPL Stage 2
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Did my 8 speed Tiptronic at 25k with filter and BG conditioner cost: $1,100 with oil report. Just did Lifeguard oil in transmission was $670 from Audi Dealer. Center diff and other are 90 weight oil? Can't remember the cost of those.
    It's preventative maintenance in my opinion, and that philosophy has served me well over many different platforms and engine types.
    Aug 13 2010
    Chicago
    Changed today at 90,000 miles. Half of which are highway. Only tracked once when new. Seemed pretty smooth on the way home from the dealer, nothing unusual. Will see how the results come back.
    https://www.dropbox.com/s/zu71jrlkat...Small.jpg?dl=0
    MILES: 122,500
    Dec 30 2014
    How many quarts of ATF was replaced?
    Can you list the part numbers and cost?
    Thanks.
    I am thinking about to changing them too.
    Aug 13 2010
    Chicago
    Thanks.
    Sure:
    https://www.dropbox.com/s/ebhcl2tvxl...00000.pdf?dl=0
    MILES: 122,500
    Dec 30 2014
    Thank you very much for the info.
    I am surprised to see that 8 quarts were used for ATF.
    Fluid capacity guide says 9 quarts for new fill and 4 quarts for drain and refill.
    If that is the case, 1st drain & fill yields 44% new oil, 2nd drain and fill 69% new oil, and 3rd change give you 83% new oil.
    Did you ask for two drain and refill?
    I will be doing maybe three drain and refill. I will drop the pan to clean it and replace filter in the 1st change, but 2nd and 3rd will be drain and refill only.
    Did you decide not to do fluid change for final drive and transfer case?
    Aug 13 2010
    Chicago
    They must have done 2 drains then. They had it for half the day.
    Will see how the fluid report comes back.
    Not at this time for FD and TC.
    MILES: 122,500
    Dec 30 2014
    I found a second source for filter kit.
    Pelican Parts has a filter kit from ZF (ZF 1087.298.368) for about the half price of Audi part (0BK398009A) .
    It also include a drain plug and a fill plug.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Full kit - $350 Blauparts used them before for B6 parts and oils
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    sub'd
    May 22 2007
    East Bay, Ca
    Very informative post - thanks!
    Junior Member One Ring
    Jan 07 2019
    New York City
    In case anyone's looking now, FCP Euro has Audi Genuine ZF 8HP transmission fluid for $34.xx a quart. They have several kits from ZF oil and filter to Audi brand filter and oil and other aftermarket manufacturers, but the Audi Genuine is on a really good sale.
    Sent from my LM-G710 using Audizine mobile app
    Sep 01 2016
    Sacramento, Ca
    Has anyone that is on the fence of actually replacing the fluid, just done a drain and fill and leave the filter? It seems like a much less amount of effort and you only take out about 4 quarts.
    Also when removing the filter was it very dirty/clogged?
    Oct 02 2005
    The Moon
    Quote Originally Posted by jrp916 View Post
    I personally did a drain and fill and after ~1,000 miles performed another drain and at that time replaced the filter.
    Reason being is you'll only get about 2/3rds the fluid out when performing this as a significant amount of trans fluid remains in the torque converter.
    I'd recommend this method if over 60k miles. Perhaps a bit excessive, but I prefer to error on the side of caution.
    Sep 01 2016
    Sacramento, Ca
    Quote Originally Posted by p3u View Post
    Do you recall how dirty your filter was when pulling it out? I’m wondering if this is suppose to be a lifetime setup from Audi is replacing the filter necessary?
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    FWIW Audi considers the trans fluid and filter "lifetime". ZF (the manufacturer) would beg to differ since I know they offer a service direct from ZF in Germany.
    https://www.youtube.com/watch?v=XbcUrDws0aE
    In the US there are likely far more traditional ZF automatic Audis out there driving around with 100k+ mileages who did NOT change their trans fluid and filter and are running just fine Do I personally believe it is a "lifetime" fill...no...but it also depends on who's lifetime. Lifetime of original owner...of track junkie...of little old lady...
    Like others if you plan to keep the car long term then a fluid and filter change is minimal. Dealers don't hesitate to do it if asked (paying). As others pointed out... saying it is "lifetime" likely allows for it not to be included in any service plans.
    I like to say the trans fluid/filter is expected to last the"lifetime" of the trans fluid/filter...whatever that might be. >50k but <300k maybe?
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Oct 02 2005
    The Moon
    Filter was filthy. The 60k interval that ZF specifies should be followed vs. Audi's lifetime recommendation.
    Sep 01 2016
    Sacramento, Ca
    Thanks! Sounds like I will be doing this soon. Looks like the Meyle filter is much more reasonably priced too.
