3" IC piping is overkill.
I dont think you want a 2.8 TB. the TPS can not be removed when it goes bad, forcing you to buy a whole new TB.
r.i.p.CASABLANCA B5 1.8t
r.i.p.BRILLIANT YELLOW B5 30V
PCV?Just dump it on the ground!
"You know you have a bad idea when Ford guys are making fun of you."
powered by
Hot Boi parts
99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
Next up E85, efr 7163 or gtx3071r?
01 allroad 2.7t 6mt, GIAC stage 1
1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
73 914 1.8T AEB + FWD 016 trans
AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
Budget Outlaws Youtube
http://www.914world.com/bbs2/index.php?showtopic=114780
powered by
Hot Boi parts
