Results 1 to 40 of 49
    Jan 03 2015
    2018 Camaro SS 1LE
    Fore those running 265/275 tires !
    Is there a significant advantage performance wise to run a larger tire than a 255 ?
    Can you really feel more grip, even less understeer ?
    A lot of guys seems to run larger tires for looks !
    I got new wheels, 19x9.5 i am ok with the look of a 255 on it but if a larger tire really improve the the performance, that's gonna be my choice.
    Thanks
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    I mostly run the 275's so it fills out the fenders more. Don't track the car but to date have no issues with it, and several sets later. Go big my friend! :)
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    This ☝️
    Sent from my iPhone using Tapatalklk
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    definitely for looks in my case.
    I run the 275 Goodyear Asymmetrics and they also have very large rim protectors, which make them look like massive 285s from the rear
    APR ECU Upgrade, JHM quickshifter, Milltek catback exhaust, Milltek 100 cell downpipes, JHM lightweight Clutch, Argon CF Splitters, KW V3 Coilovers.
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    Yep..fills out that fatty fender a little nicer.
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    275 vs 255 was a huge difference on my Supercharged RS4 in terms of spinning tires endlessly in 1st & 2nd or actually getting some grip.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Definitely go 275 on a 9.5 wheel. Use that extra rim width to your advantage, more grip
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    You guys running 30 or 35 wall width tires? I'm planning on going 265/30 when my new wheels arrive.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    I think a lot of people run 275/30. If you're set on a 265 width I would go with a 35 profile. 275/30 is already a really short sidewall.
    Jan 27 2013
    I am on 275/30/19 DWS-06, fits like a glove.
    Apr 24 2010
    ^^This.
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    275/30/19 on Michilen PSS. Really like the amount of grip the car has in corners, very predictable, still you can find the limit right when the car starts to understeer. Probably should play with the settings on the shocks some. Spins tire pretty easy in first still, and second on a hard shift.
    Oct 27 2011
    Atlanta, GA
    Quote Originally Posted by AvusPdx View Post
    Def 275/30 Michelin PSS
    Jan 03 2015
    2018 Camaro SS 1LE
    Quote Originally Posted by komseh View Post
    I would like a 265/35/19, the roads are so bad here, i am not sure about 30 sidewall.
    Still at stock Height and the 35 would fill the fenders a bit more.
    BUT i run Pss on my cars for the last 5 years. I spoke with Michelin Rep this afternoon and he told me than PSS in 265/35 was not recomanded for my car !!! There was specialy made for Mercedes, Porsche, and Cadillac ? He was not concern about fitment but these were not appropriate for Audi ??? What's that
    Jun 25 2009
    SC
    Quote Originally Posted by Laro73 View Post
    That's interesting, all the 265/35/19 PSS on tirerack are BMW, Merc, or Porsche specific. I'm not sure what that's about, but there's another member here(ven0m) running PSS in 275/35/19 on stock suspension without rubbing except during hard corning on the track. My next set of street tires will be in those dimensions as I really like the wheel protection it provides.
    Sep 21 2008
    new braunfels
    is anyone running a 275/30/19 on a STOCK wheel? according to michelin minimum wheel width is a 9.5" so I'm curious what they look like. - I feel like the 255/35s are slightly stretched and definitely don't protect the wheel or sit square.
    Oct 11 2007
    Suburbia
    I ran 265/35/19 PSS's for awhile while lowered on H&R's, they did rub quite a bit on any less-than perfect type roads.
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by zmw View Post
    Yes I have seen it done a lot. The 275/30/19 Michelin PSS tires have a rim width range of 9-10 inches according to tirerack so that is fine. Stock RS4 wheels are decent weight wise too at like 26ish pounds.
    Sep 21 2008
    new braunfels
    Well the reality is I'd want to go to a 285/30 which is nearly identical in height to the 255/35 but that seems like it might be a bit too wide - If I buy wheels I'm going to step up to 20s anyway, and then use the 19s for track duty.
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    275/35/19 Michelin PSS on 10x19 rims
    255/35/19 Verdstein winter tyres on 9x19 rims
    When I compare the two sets, the grip of the 275 Michelin is unbelievable.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Oct 27 2011
    Atlanta, GA
    Yes many of us are running 275/30 on stock wheels. Much more square
    Sep 21 2008
    new braunfels
    Quote Originally Posted by badbluers4 View Post
    Have a decent photo you can share? I've put 355s under my GT-R so I'm fine push the limits of tire size... I'd really prefer the 285/30 but 275/30 seems to be a bit easier to fit, slightly shorter than stock, while 20mm wider.
    Oct 27 2011
    Atlanta, GA
    Feb 17 2004
    2013 Audi S6
    (all pics with 10mm spacers rear, 8mm front)
    Never forgotten:
    2002 S4 Stage 3 Tip
    Sep 21 2008
    new braunfels
    spacers required or just for cosmetics?
    Quote Originally Posted by S4Per View Post
    Jan 27 2013
    275/30/19 DWS-06 with 8mm H&R HC spacer @ rear
    Feb 17 2004
    2013 Audi S6
    Cosmetics.
    Though with the spacers on I did have a tiny bit of rubbing that was taken care of by rolling the front fenders.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Dec 03 2009
    PNW, Washington
    Quote Originally Posted by Seattle squash View Post
    Your name and location listed confuses me as it does not match your license plate. Where you at?
    Dec 03 2009
    PNW, Washington
    Cosmetics.
    Whomever you sold it to curbed the wheels a little bit on the drivers side. Very sad
    Apr 14 2009
    san mateo
    275/30/19 hancook V12 800$ for all 4 installed :)
    Apr 24 2010
    This was with 12mm spacers in the rears.
    Jan 27 2013
    Quote Originally Posted by Peter1.8t View Post
    I used to be is Seattle, loved squash until I ruptured my L4, Dallas now but still a car freak! So yea, I stand corrected. I am currently in Las Colinas, Dallas, let me if you are local and we grab a cold one! :)
    Also, up in Seattle every 2nd month or so for work... So as much as I hate beer I might be game there too! :)
    Jan 27 2013
    Quote Originally Posted by denis silva View Post
    I used to run those, and good feel but I kept blowing out the side-walls, and/or de-laminating the steel belts inside the sidewalls.
    Apr 14 2009
    san mateo
    I ran these tires on my previous set of wheels and after about 3 years im going to my second set or V12
    Jan 27 2013
    Yeah, I might have had bad luck. Must have had 4 sets or more and probably had do warranty 25% of them... And always a bummer to me as I liked them. However maybe my setup combined with too high tire pressure caused it... Tend to be at around 42psi to give the sidewalls some help as these are not as stiff as some. On my other car, a BMW (same size 275/30/19), I never had issues with them though and still run them.
    Dec 03 2009
    PNW, Washington
    Ah I see. I'm up in Seattle myself, I was confused because I know a lot of local RS4 owners yet have never seen your car around.
    Junior Member Two Rings
    Nov 27 2012
    stage II RS4, stock SQ5
    seattle | tacoma
    Installed the ECS 10mm spacers all around on stock wheels / tires last summer, and have noticed a wee bit of rub. If I move up to 275/30/19 PSS, will it exhibit more or less rubbing?
    2007 Black RS4 | AMD supercharged | AMD stage3 clutch | EBC redstuff pads | SPC adjustable UCAs | 034 mounts: snub, motor, trans, rear diff carrier | Powerflex diff mount bushings | ECS 10mm spacers | GMG cat-back | K&N | intake de-flap | IM port/polish | 475awhp / 405awtq [AMD mustang dyno, 92F day]
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    I'm on my 3rd set PSSs on stock wheels with no issue.
    Ghost
    Jan 27 2013
    Quote Originally Posted by fitchbuck View Post
    Almost certain quite a bit more, at least front. I am on DWS-06 275/stock 19's and I had to loose my 8mm spacer in front, with fender screw removed, unrolled fenders. The PSS are wider so thinking you would have an issue. However, I am slightly lowered on coils to make my case worse. Back, I am thinking you are fine. Hope that helps. Quite a lot of input on the subject if you look around as we all try to pack as much in as we can.
    Apr 24 2010
    Roll your fronts. Should be 50-100 bucks well spent!! Just make sure your fender roller is legit.
