I am 7 gallons of 100 percent distilled water into this and although the water is coming out more clear than the previous time, I am still getting a light brown color coming out. Should I use an additive to help clean the engine, maybe let it set over night to really soak in and clean? Or keep doing what I am doing until clear?
Right now I am adding 100% distilled water to the engine, letting it idle until operating temp, topping off a few times and bleeding the air from the system via heater core. Then holding a 2k rpm idle for a few minutes, removing the lower radiator hose, and the last 2 cycles I have pulled the block drain plug...
