Originally Posted by
Finder
I was referring specifically to the Kufatec harness for xenon headlights retrofit.
And I wouldn't compare a tail lights retrofit to a headlights one. There is A LOT more work and components involved with headlights.
Tail lights are easy, especially if you orders adapters. All you need to do is install them and then do coding.
I understand what you're saying about the retrofit from halogen to xenon headlights. I was making an analogy based on my past tail light experience.
I just finished sourcing Ecode headlights for my conversion from NA spec Bixenon AFS1 to Ecodes spec Bixenon AFS1 so I'm fairly aware of the differences. I spent over 4 months researching the subject. In my case, it will be plug an play as I have already coded out the amber corner markers. However, I will not be using the oem D3S bulb/igniter combo or it's ballast. Rather as a further extention of my ecodes install, I'll be sourcing D1/D2 xenon bulb adapters (they look exactly like the D3S igniter). I'll be fitting to those adapters a pair of Philips DL50 50W (Fatboy) D2S bulbs. To compliment those bulbs, I'll be using a D2S 50W ballast (true 50W). This conversion will elevate the normal 2800-3200 lumen output of oem D3S bulbs/ballasts to 5300 lumen. Combine that output increase to the ecode headlights which use a clear projector lens as opposed to the fresnel (opague) type used on the NA Bixenon projectors, andI should have an ideal set-up.
I believe I did mention that a headlight conversion is far more complex, involved and costly then a tail light one and that I made note of the various degrees of headlight conversions.
