Results 1 to 17 of 17
    Oct 24 2015
    Perth, WA
    Where is the trunk release button in the cabin? DIY to retrofit?
    Hi guys
    I cannot for the life of me find the trunk release button in my A4 B7 sedan. After researching it, it appears they don't have one. I think that is simply weird. Is there a way to retrofit the trunk release button back into the door panel. I would assume running two wires to the trunk switch from the drivers door would achieve this. Has anyone tried this, got a DIY or am I just going crazy?
    It would be nice to intall this I think.
    https://www.ecstuning.com/Audi-B7_A4...onic/ES442146/
    Cheers
    My respray thread
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I'm not sure on a B7, but on a B6 it is on the drivers side door card at the back of the little cubby/slot/cutaway. I would have guessed it to be in the same place but you sound like you're saying it's not.
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    Quote Originally Posted by MacFady View Post
    Same spot. Back of the cubby on the driver's side door card. There's 4 switches there. Gas door, Trunk release, and a button that disables the alarm setting when you jack the car up, and then a blank (at least that's how my B7 is).
    Oct 24 2015
    Perth, WA
    Not on mine there isnt. "(
    My respray thread
    Sep 04 2015
    Clear Lake, TX
    Quote Originally Posted by Okedokey View Post
    That's weird...how do you open the gas door? Usually the buttons are in the same spot...
    Aug 10 2011
    330i ZHP
    Do you have factory B7 door cards or have they been swapped with something else ie: is it possible the wiring etc. is just tied off inside the door?
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by drmonkey View Post
    Gas door for me unlocks when the car doors are unlocked and locks when the car is locked (there's a little pin which moves with the door locks)
    But yeah I'm the same and don't have that button inside. Not a big deal for me though.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Sep 04 2015
    Clear Lake, TX
    Quote Originally Posted by shahk62 View Post
    You do have the button on the remote though, correct? Your B7 may just handle all the "doors" from the remote rather than having buttons on the inside as well.
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    2007 here..mines on the door.
    Nov 15 2011
    Montreal | I sell in USD
    Op : I have the whole unit from a B6 S4 if interested. Trunk and tilt button with trim.
    Google image:
    *****I sell in USD*****
    Jul 14 2015
    Sydney
    I have a trunk button and the door lock/unlock ones. But unlocking all doors unlocks the trunk as well.
    Oct 24 2015
    Perth, WA
    Thanks guys, yeah, it unlocks with the doors etc, but Id like a boot release button (not unlock but release). Seems a DIY is coming :)
    My respray thread
    Jul 14 2015
    Sydney
    If you're getting that should definitely look into the ECS trunk opening struts (can't remember what the actual name was) so that when you release the trunk will actually open.
    Oct 24 2015
    Perth, WA
    Too expensive.
    My respray thread
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    That blank spot was for memory seats. Only available on the top of the line models (3.2 trim) for some reason.
    B7 S-line 2.0
    Nov 15 2011
    Quote Originally Posted by seandon_792 View Post
    B7 S-line 2.0
    Jun 27 2011
    B7 S-line 2.0
    That's not true. Memory seats are a whole other insert.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
