Results 1 to 21 of 21
Thread: Whining noise
    Established Member Two Rings Navyseal#6's Avatar
    Aug 17 2015
    Pennsylvania
    Whining noise
    I drove a few hundred miles today to the Arnold Classic and on the way home I was hearing a whining noise coming from the engine. The noise stayed the same while driving and when I slowed down or stopped it faded. Any idea of what it is? 2011 S4-68,000miles. Thanks
    Mar 11 2015
    DE
    The supercharger?
    Jk
    Only whining I can think of could be from a wheel bearing but you're saying it's coming from the engine?
    2013 P+ | DSG | SD | BO | Carbon Atlas | MMI/NAV | Nappa Leather | Supercharged Badges
    AWE Touring with Res DP Exhaust | H&R Spacers | Passport Escort 9500ix + Blendmount | Weathertech Liners | AWE S-FLO | H&R Sport Springs | EC Alu Kreuz | Forgestar CF10 | EPL Stage 2
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I would assume supercharger or the wheel bearing
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Jan 09 2008
    Winnipeg
    Wheel bearings are more of a growl than a whine. But if it was a wheel bearing type noise what about the inner CV joint on the axel...that might sound like it's coming from the engine area.
    One great way to tell is while driving put the car if neutral and let the revs drop while at speed. If the sound truly is engine related it should dissipate. If the sound only drops as the car slows then it's something in the running gear.
    Aug 17 2015
    Pennsylvania
    I put the car in neutral and the noise still there. When I have the car in park, there is no noise.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    If you have someone that could drive with you, have them listen from the outside at speed, e which side it's coming from, wheel well, engine compartment, etc.
    Actually before that, inspect your tires, make sure that there isn't some tread issue. Also look at the undercarriage for debris, wife had a branch stuck under there once that created wind noise.
    Also check the radiator, make sure you didn't get a bag or trash stuck to it. Had a buddy overheat an engine once due to plastic bag stuck to the radiator.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Aug 25 2015
    california
    Crank pulley? Ac?
    Grom
    Apr 04 2012
    MSP
    Record the noise and post it.
    Have you recently done any mods?
    Could be tires wearing out...
    Established Member Two Rings JKrups06's Avatar
    Jul 01 2014
    Chicago IL
    I had the same issue ended up being a wheel bearing. The sound happened going over 30 was correlated to speed. As I increased sound was louder and when I slowed down I heard the noise "whine" down
    Sent from my SM-G935T using Tapatalk
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by Navyseal#6 View Post
    So it's louder at speed, but still present when stopped in drive or in neutral, but in park there is no noise, correct? What if you are stopped in drive/neutral and turn AC on and off, does the sound change? What if you just rev the engine in neutral?
    Regardless it's not wheel bearings or axles isn't moving and still making noise.
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    clogged air filter, or screen, alternator or AC bearing, fan? can't think of much more since its still doing it while in neutral .
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    I have had random alternator whine on other cars I have owned jn the past. Could be that?
    Aug 17 2015
    Pennsylvania
    Tried reving engine in neutral and no sound. It seems as I start moving past 10mph the whining sounds starts and as I slow down it whines down. Tires are new, no wear. Revved the engine with hood open and no whining sound. As I was driving, I turned left and right, didn't change the sound at all.
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Maybe check for a small pebble/piece of gravel stuck in between the rotor dust shield. I had an issue like this when I drove through a recently paved hwy and it started as a whine, then became a god-awful rattle. Worth a check.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Maybe pop your hood and make sure one of these isnt in there?
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Senior Member Three Rings Moto One's Avatar
    Mar 26 2010
    C5 Z06 (going on 17 years)
    Tahoe/Truckee
    Not to be the bearer of bad new, but ours was making a noise that sounded like the power steering was low on fluid (almost not noticeable), but it turned out to be the Transmission. The last time we had this noise (witch I thought was just the supercharger spooling) was the trans going south, and just after having it's major trans service at 75K. Went in on Friday for 85k oil change, and it has been in our dealers service bay waiting for Audi to decide what to do, we on the other hand are driving a Q5 loaner (very nice by the way). Our transmission was replace last Dec. so we are under warranty. This S4 it's not doing much for us in the confidence department right now.
    Mar 07 2015
    Ottawa, Ontario
    The OP said there was no noise when parked and only while moving. As JKrups06 said, it's probably a wheel bearing or it could be driveline related.
    Aug 17 2015
    Pennsylvania
    I got it checked out today...Wheel bearing it is. Thanks for everyone's input, it's greatly appreciated.
    Mar 26 2010
    Tahoe/Truckee
    Good news for you.
    Mark
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Bad wheel bearing at 68k miles? That's little disheartening...
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Mar 26 2010
    Tahoe/Truckee
    Quote Originally Posted by Midnight_Rider View Post
    Better then third transmission.
    Mark
