Results 1 to 19 of 19
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Clutch or Transmission, Shudder under full boost hit with occasional slip...
    Background: Car makes north of 550whp, normal clutch activity and shifting UNTIL boost comes on.
    2nd gear pulls hard but it feels like a shuddering/tires breaking loose but they aren't. Sometimes is pulls great and nothing feels out of the ordinary.
    3rd gear immediate shudder/vibration followed by a "slip". If I feather the pedal after the slip it will pull like normal. Last night I could feel the vibration towards the rear of the car.
    If I pedal it, it may grab it may not or it will shudder.
    Mounts look good but would they cause a slipping issue if they were bad?
    Im use to a clutch just slipping, this is something that can be felt very noticeably and nothing is consistent.
    Any help is appreciated.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    What you're describing sounds like clutch slippage.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Agreed. Same here
    Sent from my SGH-M919 using Tapatalk
    May 22 2013
    Las Vegas, NV
    Well. .. not sure about the shuddering. Mine will slip into space sometimes but no shudder.
    Nov 23 2004
    NH
    Yea it feels like it's trying to grab. I guess I'll inspect it when I pull. Wonder if there is a way to test the transmission? I mean what could it be, it's quiet and no weird issues other than under full power.
    08 3.2 A3 DSG DD
    Feb 18 2013
    Louisville
    Could it be the driveshaft? Just throwing ideas out there
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Come on you noobs, the only slipping is going to occur at the clutch. I'm willing to bet the op is not running a full face disc
    Nov 23 2004
    NH
    southbend 6 puck stage 4 extreme. So the transmission going bad won't exhibit slip like conditions?
    08 3.2 A3 DSG DD
    Nov 05 2009
    Denver
    Automatic? Sure. Manual? No, there are gears meshing so ZERO chance of slip. Manual transmissions like to fail in a more catastrophic manner.
    Nov 05 2009
    Denver
    Quote Originally Posted by Zba View Post
    The shuddering is most likely just each puck sliding across the flywheel and pressure plate. A full face disc would not have the same feel.
    Nov 23 2004
    NH
    I kind of assumed this but needed confirmation. Thanks for the advice.
    08 3.2 A3 DSG DD
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    This...
    Nov 23 2004
    NH
    Damn you, making too much sense! Just need to hear it from others.
    08 3.2 A3 DSG DD
    Sep 11 2009
    NE
    my 6 puck slipping was butter smooth, no juddering or jarring... Anyhow, it is definitely a slip and perhaps some more extensive damage to clutch took place that makes it judder. How is clutch operating during normal conditions?
    Sep 11 2009
    NE
    Nov 23 2004
    NH
    It chatters bad on starts but it's not bad during normal shifting.
    08 3.2 A3 DSG DD
    Sep 11 2009
    NE
    Quote Originally Posted by Blue AWD View Post
    Sounds like you will need a new clutch to me.
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    what kind of flywheel? aluminum or steel? i believe aly ones will chatter regardless.
    Nov 23 2004
    NH
    Lots a LWFW but I've been on 4 clutches and this is by far the worst chatter. I thought it was just during break in but it never went away. I had this clutch rebuilt and before it didn't chatter like this.
    08 3.2 A3 DSG DD
