Results 1 to 27 of 27
    Jan 03 2016
    Myrtle Beach, Sc
    Spark Plug Gap??
    2012 S4 B8 What is the correct gap? .032 or .028? car is stock
    Mar 21 2015
    nevermind
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Since he already made the thread might at well answer it for the people who do search.
    .28 is what I'm running, they're stock plugs from the dealer that were pre gapped.
    It works just fine.
    When removed at 30k it was .32
    Probably from wear? How many people actually remove new spark plugs to check gaps.
    Go with OE plugs
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by DGVR6 View Post
    It works just fine.
    Go with OE plugs
    I used the NGK 94460 (same basic double platinum plug as OEM at a lower cost). Also gapped to 0.028 (they came gapped to 0.032). From what I understand, OEM used to be 0.032, and at some point they changed it to 0.028. My factory plugs with 22k miles measured at 0.029 to 0.030 or so.
    Here is a link to some discussion plugs you can use and gapping them: http://www.audizine.com/forum/showth...1#post11330086
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Aug 03 2014
    Queens
    Quote Originally Posted by jran76 View Post
    Ahh.. I see. Since I have an early model (build date 7/10) then my car must've fell in that range before the revision.
    Previous
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    What kind of plugs did you have from the factory? Bosch or NGK?
    Aug 03 2014
    Queens
    IIRC NGK, same as the replacements I popped in a few months back.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Does .025 gap sound fine on a stage 2 car?
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by B8 S4 View Post
    Stick with oem plugs at: .028
    For dual pulley cars, one step colder at 0.028 gap. I'm getting these put on friday with some new coil packs. The Oem's were fine in cold weather but to be safe I'm running these during the spring/summer
    http://www.amazon.com/NGK-BKR9EIX-Ir..._detailpages00
    Feb 12 2017
    easton/PA
    So the gap for the plugs is .028 from factory?
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Just did my plugs at 40K. Factory gap was 0.28. I have a 2011, not sure on production date.
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Just swapped mine as well and the factory plugs were all between .028 and .030. Running .025(ish) with colder plugs now.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    My 40k plugs OEM came out at 0.032" and had no issues on Stage 2.
    I swapped in new Iridiums, same heat range at 0.028" with the dual pulley. So far, no issues, but I've yet to really run it hard and log.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Apr 12 2012
    Chino Hills, cA
    How is the 0.25ish doing so far? I am changing my spark plugs I have very similar set up compared to yours. Thanks!
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by Guest1 View Post
    No logs to back it but, working great for me. Whiped has been running the same plugs/gap and logged his results (I believe) and has had positive results as well.
    Apr 05 2016
    Portland, OR
    0.028" for stock plugs
    0.025" for the one-step colder plugs
    The one-step colder plugs definitely gave me better response uptop.
    I logged the one-step colder plugs at 0.028, 0.022 and 0.025".
    In the logs, they all looked pretty similar, however when you pulled the plugs and visual inspected them 0.028 was too big, 0.022 too small, 0.025 just perfect.
    Keep in mind this was for E35 gas, not sure how it changes things.
    Geoff
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    Quote Originally Posted by mrmomo313 View Post
    Gona need smaller gap than that with one step colder plugs and especially a dual pulley car I'd go 0.025
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Nice, thanks guys. Installing new plugs tomorrow.
    Oct 27 2010
    Michigan
    Quote Originally Posted by mrb5_supra_wrx View Post
    My logs looked good with .028 gap running APR stage two and the chipwerke when I was using them in the summer heat (both on the 179 and 194mm cranks). Little to no corrections on the 100 octane map.
    I switch back to OEM heat range in fall/spring with .028 gap
    Apr 12 2012
    Chino Hills, cA
    Thanks guys, gonna go with 0.24. Apparently on the apr site they suggest 0.24 plus/minus 0.02
    Apr 12 2012
    Chino Hills, cA
    Quick update: after running one step colder with 0.024 gap the car runs ...pretty much the same as before. Logs show no misfires or pulled timings. Don't really know what else to log here.
    However, my mpg went down the toilet, it's at around 8.2 to 8.8mpg. Does that mean the gap is too small? Should I run it for awhile and see if it readjusts? Advice appreciated
    My car is dual pulley 3.27 ratio, tcu tune, plm intercooler.
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    with the new setup have you been driving like a pissed off teenager? haha
    Jul 01 2012
    You're getting better spark but probably using more fuel if you don't like .24 I'd try .26 work it always go back to the stock .28 it's really your preference on how you want your car to run especially if you're worried about mpgs
    Jul 01 2012
    And if you're going off the mile per gallon counter the car uses probably need some time to adjust to the new Gap how long did you drive
    Apr 05 2016
    Portland, OR
    Best way to see how it is running is to pull the plugs and read them.
    The burndown on the backstrap says a lot about the gap size.
    Geoff
    Apr 12 2012
    Chino Hills, cA
    Ya admittedly I drove like a maniac to test it out lol. I only drove for like 30 miles.
    What am I looking for on the backstrap? When I pull them out I will post pictures.
    Aug 09 2011
    Brooklyn, NY
    So you guys are running a colder plug in the spring and summer and stock in the winter? (With the appropriate gap size?)
    '16 Audi S6 4.0TT Eurocharged ECU - Current
    '12 Audi A6 3.0T Prestige - 187/57 DP Eurocharged ECU /TCU - Trade
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
