Results 1 to 6 of 6
    Mar 01 2016
    Prior lake, MN
    2010 A4 B8 2.0T injector failure
    I recently bought a 2010 A4 with the 2.0T. Started running funny the other day, so i took it to my local mechanic and he diagnosed it as a fuel injector failure on cylinder 3. He also told me that there is a special tool to remove or install the new injector and that the dealerships would be the only place i can get this tool or service done. Is this true and if so does anyone know what this tool is?
    Thanks
    Established Member Two Rings irobb's Avatar
    Jan 30 2016
    VA
    Are you sure it's the injector?
    Read this thread:
    http://www.audizine.com/forum/showth...sue-In-Low-RPM
    Seems like cylinder 3 has all sorts of crap happen.
    2010 A4 B8 2.0T Quattro | VMR718 19x8.5 ET35 | 235/35/19 Toyo Proxy 4 | ST Coilovers | HPA K04 Hybrid + HPA Tune | CTS Downpipe
    Oct 24 2015
    Perth, WA
    My respray thread
    Junior Member One Ring
    Sep 02 2007
    forest park, ga
    I just did all 4 injectors. I didn't need any fancy tool. 3 of the 4 came out in the manifold when I pulled it off and a little prying on the metal injector housing freed it out of the block and the other 3 you could just wiggle and pull out of the manifold with your hand. It is just an oiled small gasket holding them in. When I went to install the new injectors I used a 19mm or so deep socket and a rubber mallet and again CAREFULLY tapped it in using the metal outside of the injector housing. Seated fine.
    Senior Member Two Rings helldriver's Avatar
    Oct 25 2014
    Cincinnati, Ohio
    My cyl 3 saga happened as follows, compression check, new injectors, carbon clean, plugs, coil packs, cyl 3 still misfiring, now the front end comes off to gain access to the timing chain guards, to remove cams and replace all valve springs and lifters and with only 78,000 miles, thanks audi!, good luck to you sir.
    2008 Audi RS4
    Active Member Two Rings root_to_the_a4's Avatar
    Jan 20 2016
    B8 Q7
    Woodstock, VT
    Quote Originally Posted by danteshors View Post
    ^second this opinion
    Bagged B7 A4
    SPF Rotiform
    Air Lift Performance
    AWE Tuning
    Unitronic
    The Root to the A4
