Results 1 to 40 of 43
    Mar 14 2015
    San Juan, PR
    How to get more torque from rs5 ??
    I'm curious about the delta between horsepower and torque in the 4.2L V8 found in RS5s. Has anyone came with ideas of how to get more power in terms of torque out of these engines? (besides force induction/turbo/supercharging them). Thanks!
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Easiest way, trade it in for a Lamborghini...that's an Audi engine right ;-)
    Jul 10 2014
    DFW, TX
    Answer is no. Been discussed an infinite number of times. Just keep it above 5000 rpm or so.
    Here today:
    2024 SQ5
    2025 X5
    1975 Triumph TR6
    Mar 14 2015
    San Juan, PR
    HP numbers are great but torque seems so low. There are some 4 cylinder engines delivering those torque numbers, not to mention the RS 2.5 TFSI engine that has 3 less cylinders. 034Motorsports store claims that the REVO Stage 2 for the 4.2L engine produces 452-459 HP / 322-330 TQ. Have you seen anything better out there?
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Eventuri intake helps on the low end....
    http://www.eventuri.net/products/audi-rs5/
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Jul 28 2015
    Paddles
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Deiniel View Post
    HP numbers are higher than the torque because its a high revving engine .. the TTRS 2.5 Engine is also forced induction engine .. the RS5 has a Naturally Aspirated Motor.. you are comparing apples to oranges
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Mar 14 2015
    San Juan, PR
    Quote Originally Posted by doug97gxe View Post
    100% True! But still, big delta between hps and torque for a V8.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    The best you can do on a sensible budget is to improve the breathing. The Eventuri intake combined with a good free flowing exhaust will see an improvement in torque that is noticeable when you put your foot down from low revs.
    If you want to spend more then look at the Kline headers which remove the catalyst from the scavenge area (bare in mind this is an engine drop job) these will free up the bottom end even more and combined with a quality ECU map is as far as you can take it before you start looking at forced induction.
    A supercharger kit may become a reality if enough people show interest, that will transform the car into the car it should have been from the factory.
    Nov 10 2014
    Apex, NC
    only feels that way because it rev's higher .. think of the Honda S2000
    Present:
    Feb 27 2014
    Dubai
    Quote Originally Posted by Mojo31 View Post
    The engine is above 230lb ft at 3000rpm and climbs to approx 310lb ft peak at 6500rpm where it starts to tail off to 280lb ft at 8250rpm redline.
    Ita not a bad spread of torque for an NA engine.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    The high rpm, high performance engine design comes from motorsport. There are three ways to increase power output in an engine. The cylinder capacity can be increased, or turbo/superchargers can be fitted. Both of these increase weight and demand space. The third approach is to design the engine to run at very high rpms. That's what the RS5 engine is about and many other high-performance engines found in Ferraris, Lambos, the R8 and in motorsport such as Formula 1. The BMW M cars were the same, before they went turbo charged. There's nothing strange about the torque numbers vs. HP numbers for this engine. This engine delivers linear power the more you get on the throttle. If you don't like winding out an engine to make power, then this is not the engine design for you. One of the benefits of a high-revving engine is that you can stay longer in a lower gear. The RS5 makes peak torque at 4000rpm and has a 4000 rpm powerband. If you want to tear up the roads, just keep the engine between 4000 and redline. The torque is fairly flat above 4000 and the HP just keeps climbing linearly all the way to redline. It pulls like a freight train up there. Here's the torque/HP curve for reference.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Mar 14 2015
    San Juan, PR
    Quote Originally Posted by superswiss View Post
    Thanks! Please, don't get me wrong, I recognize this engine is great piece of engineering. Just wanted to know if there's some mod that can bring up the torque. I currently have a Stage 2 TTRS 5 Cylinder with 450 ft/lb of torque. I know they are very different cars and engines. Thank you all for the info!
    Jan 07 2013
    Yeah, being an NA engine, there isn't much. As has been said, you can improve the breathing to squeeze out a few more lb-ft and then there is that APR ECU tune, which supposedly squeezes out a few more, but that's about it. Short of retrofitting a super or turbo charger, there isn't much to be had.
    Established Member Two Rings HamadAJ's Avatar
    Aug 26 2015
    Abu Dhabi
    When is added a non-resonated cat-back exhaust, it increased torque slightly at lower rpms.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    The delta is large in the case of the RS because it's a high-revving, low displacement engine.
    Assume a car has a flat torque curve. The higher the engine revs, the more horsepower it will make. Most (many) V8s have a lot of displacement, and do not rev very high, and thus do not have much of a delta. The RS is the opposite.
    As superswiss said, the only real way to significantly increase torque is by increasing the displacement or adding forced induction. You could likely pick up a bit with a custom tune and exhaust (headers and all) but it's just not worth it.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 26 2015
    Abu Dhabi
    Kline headers can improve the torque by 20% which is pretty impressive but of course costs alot of $$$$$.
    Veteran Member Four Rings jkownz's Avatar
    Jun 15 2011
    2015 RS 5
    Quote Originally Posted by HamadAJ View Post
    between the headers, the engine drop and a custom tune, your looking at like 7k easy. thats with Kline headers, custom tune work and labor.
    MODS 2015 Audi RS5 / Custom Made Headlights / Full Xpel PPF / Tinted / Blackvue DR650G / Eventuri Intake / BLK 501GTR'S 20X10.5's All around / Storage Bins / Euro Folding Mirrors / Capristo Exhaust / A.W.E Non-Res Downpipe / CF Engine Cover / 034 Transmission Mount Insert / Apikol Rear Differential Mount Insert / 034 Rear Diff Carrier Mounts / Euro Tail Lights + Sweep Module / L.E.D Interior Lighting / Airlfit 3H Bag Suspension /
    Mar 14 2015
    San Juan, PR
    20%??? Thats like 63 tq. Are you sure about that number?
    Aug 26 2015
    Abu Dhabi
    Im not 100% sure, but thats what the representative from kline assured me. I wouldn't be surprised though, if you take a look at the stock manifolds, they are small and stunted with a huge catalytic converter right behind it. That pretty much suffocates the flow.
    This is the OEM headers, pretty ain't it ;)
    Kline vs OEM
    Mar 14 2015
    San Juan, PR
    Yep... OEM are horrible. Kline looks great. 63+ torque is great achievement. Still pricey $$$.
    Apr 26 2005
    Houston
    63 HP on headers? wtf.....how
    • eCode headlights
    • Eventuri intake
    Dec 19 2014
    United States NE
    How much tq increase? It's its almost the same sign me up!
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Lightweight wheels. Heavy OEM wheels rob power
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    Aug 26 2015
    Abu Dhabi
    Quote Originally Posted by chrissurfr View Post
    A completely free flowing exhaust = great power, especially when the stock header suck. it might be even possible to breakin the 500hp range if you combine eventuri intake+kline header+cat-back+ ecu.
    Sep 28 2010
    NW NC / DE
    So much +1 on lightweight wheels. I've offered 20x10 G25 that come in 10lbs per less than OEM. HUGE... @swoardrider
    Apr 26 2005
    Houston
    wuuut is a g25? I love the CHR but dropping another 8 pounds might be kinda nice
    • eCode headlights
    • Eventuri intake
    Sep 28 2010
    NW NC / DE
    @chrissurfr
    20x10 ET25 at 21.7lbs. Hit my IG, and you'll see them in 19x10 on the S5CooP SG RS. Mold forged race car ish.
    Apr 06 2014
    Ca
    Does the G25 come in 20x10.5?
    Established Member Two Rings Drew0u812's Avatar
    Apr 02 2014
    1998 3000gt VR4
    Poplar Grove, IL
    When compared to the Mustang flat plane V8, the Audi makes 6hp more and 6.5 lbs ft less per liter.
    It also makes 14 hp more and 2.3 ft lbs less per liter compared to the Lexus RC-F. Those competitive engines were also recently developed....Makes me think that Audi's V8's performance is not too shabby.
    2018 Audi A5 Sportback Prestige
    Feb 27 2014
    Dubai
    CCB's!! It's win win, better brakes and less than half the weight.
    Actually it's win win lose, all the above but pretty expensive.
    Aug 26 2015
    Abu Dhabi
    @chrissurfr
    What are your thoughts on BBS japan RI-D forged duralumin wheels? 17.4lbs for 20x9.5.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Sftuner View Post
    10.5 and 11, but not in 5x112.
    8================================================= =D
    Aug 28 2015
    Illinois
    I am completely happy with this engine and its linear throttle response. However, I would love to see the results of adding a cold air intake, Klein headers and a free-flowing exhaust. I don't think 500hp is unattainable but would be quite expensive. As others have noted, a set of lightweight wheels will provide immediate noticeable performance.
    Prism Silver RS5
    Apr 26 2005
    Houston
    is there a dyno sheet of the kline headers?
    that really is a huge claim they are making....
    • eCode headlights
    • Eventuri intake
    Apr 26 2005
    Houston
    https://www.flickr.com/photos/88568720@N08/14040788146
    dyno of headers....100 torque increase? um
    • eCode headlights
    • Eventuri intake
    Feb 27 2014
    Dubai
    Is this just the headers or was it Marz car in Australia when he fitted the headers and a supercharger?
    Dec 10 2011
    CLT | MKE
    Here's another one, more apples-to apples IMO. This shows a peak gain of 25-30 ft-lbs from the headers, which seems possible.
    Keep in mind the graph shown in newton-meters.
    -Hayden
    Feb 27 2014
    Dubai
    It actually shows nothing at all, my standard car on standard air box was making 410Nm so I'm confused what that graph above is telling us?
    Apr 26 2005
    Houston
    Quote Originally Posted by JamesRS5 View Post
    This was before he got the supercharger and blew the car up lol
    • eCode headlights
    • Eventuri intake
