Results 1 to 13 of 13
    Established Member Two Rings Kelz's Avatar
    Nov 10 2012
    Cincinnati Oh 45215
    recover bricked ecu
    flashed the wrong year tune through maestro 7, the ecu was out of a 2003 my car is a 2002, so i not thinking flashed a 2002 amb base tune onto the ecu. . . . flash went through fine but the end result is a ecu that does nothing at all. does anyone know the procedure for fixing this situation?
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    boot mode flash with mpps or galetto
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Nov 10 2012
    Cincinnati Oh 45215
    how do i accomplish that?
    im going to google it but if you have a direct link it would be greatly appreciated
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Oh I didn't realize that that wasn't an obvious answer. Sorry for that.
    You need an additional cable and software unless the maestro stuff has boot mode functionality.
    You'll have to gain access to and open up the ecu, remove it from the case, plug it back into the car. Disconnect the negative cable, turn the key on.
    By now you should have your computer and software and what not connected to the car and ready to go. Make a probe of some sort so that you can ground pin 24 on the eeprom. Ground the pin, connect the negative cable, count to 5, remove the ground.
    Go back to the computer, click write and select the file for your ecu. HOPEFULLY it writes. If not you'll have to start over from disconnecting the battery cable.
    I hope this helps.
    Nov 10 2012
    Cincinnati Oh 45215
    are the cables on ebay worth a nickel???? that seems to be the only place i an find this cable and software.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Find one of the MPPS v13 auctions that is close and cheap and comes with software. Theyre pretty much all the same. Same with the galetto ones.
    example: Click
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    One should never be flashing an ECU without a backup or means of recovery.
    But the mentioned software will work just fine in bootmode. Use a 10K resistor to boot it in case you slip.. You don't want to physically fry the ecu. No recovering from that.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Quote Originally Posted by f1torrents View Post
    Are you using a 10k for grounding boot pin?
    Apr 27 2012
    Guelph
    Yep. Just incase you slip.
    You dont want a direct short to ground on one of the pins next to it.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    That's not a bad idea. I usually use the pad away from the eeprom depending on the ecu.
    Nov 10 2012
    Cincinnati Oh 45215
    so once i reflash the stock firmware i will be able to flash the correct tune into my ecu? do the cables come with the correct firmware or do i have to source it elsewhere?
    or do i still have to send it to euradyne?
    and i agree i should of been more diligent in the process of flashing and double checked before i hit okay on the computer.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Quote Originally Posted by Kelz View Post
    What's done is done, now to fix it.
    Unfortunately the cables wont come with anything but the software necessary to operate them.
    Is the correct file for your ecu from eurodyne a .BIN file or is it some other proprietary file type?
    If its a .BIN you can directly flash with the mpps or galetto. If its something else, you will need to flash with a stock .BIN, make sure the car starts, then flash with the maestro software.
    The 2002 A4 1.8t should be an 518 F ending part number on the ecu case sticker, the 2003-2005 should be 518 AK. Which one is yours?
    I can help with the stock bin for either one if you need, did the maestro software not prompt you to save a factory image of the ecu?
    Apr 27 2012
    Guelph
    2002 - F
    2003 - AL
    2004 - AK
    2005 - BC
    2003-2005 are all compatible/cross flashable
