Results 1 to 14 of 14
    Veteran Member Four Rings s4boost's Avatar
    Jan 08 2008
    Franklin/TN
    Dsg adaptation vag com
    Does anyone know how to do this? Is there any risk in doing it?
    My transmission seems to be acting strange. I was going about 30mph today and floored it. It kicked down to 2nd at about 4,000rpms and felt like the clutch was slipping or cutting power until it shifted into 3rd. I'm thinking I may want to do the adaption if it might help
    2012 S4 Ibis White S Tronic Prestige APR stg 2+ V3 CTS Turbo Intake
    2002 Silver S4 6MT Premium Package Stg 3 -SOLD
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Did you hit the kick down button under the pedal? If so it's kinda an emergency acceleration mode and it does slip for a few
    Sent from my SM-G928V using Tapatalk
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Jan 08 2008
    Franklin/TN
    Quote Originally Posted by theswoleguy View Post
    Yes I did. And the transmission overall just feels quite clunky at times and seems like it's losing its bite when accelerating from a stop. I'm curious if the adaptation will have any effect
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Sure it wasn't just Traction Control Kicking in? I have a problem with TC kicking in, light flashes and it will bog the car at times, especially at anything below 45mph. I was concerned at first too but I can easily repeat the issue. Once I put the car in sport mode (TC Button 1 time) no issues. Full power fun!
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Dec 07 2014
    Mn
    If you run a scan with your vag com then clear all dtcs even if there aren't any. I heard that resets some adaptations.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Dec 19 2014
    Virginia
    I've done it before about a year ago it worked for me I have a thread that I posted the link on awhile ago .
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Aug 12 2013
    Lexington KY
    I'll say I try and go in and look at codes and clear them once a quarter. The car learns how you drive and when you live in more metro area, that's a lot of stop and go traffic. I feel like after clearing the codes, the car's much more responsive and has a lot more giddy up. Just by erasing that learned behavior, I feel like it really makes a difference. After clearing the codes, I try and make it a point to flog on her a bit to get the new behavior a lot more aggressive.
    Jan 08 2008
    Franklin/TN
    Quote Originally Posted by pdqgp View Post
    Pretty sure it isn't tc, I never see the light flash if it is
    Quote Originally Posted by brianc21 View Post
    I did this
    Senior Member Two Rings trevor51590's Avatar
    Dec 18 2007
    '21 S4, '21 Q5
    '25 RS6 Performance | Daytona Gray/Congac/Black Dinamica | Executive | Black Optics | RS Sport Exhaust | RS Driver's Assist | B&O
    '21 Q5 Premium Plus | Navarre Blue | Nav
    '21 S4 Premium Plus | Daytona Gray | S Sport | 034 Stage 1
    --Gone but not forgotten--
    '23 RS5 Sportback | '18 A4 Premium Plus | '18 Q5 Prestige | '13 S4 Premium Plus | '11 S4 Premium Plus | '06 A4 2.0TQM | '99.5 A4 1.8TQM
    Jan 08 2008
    Franklin/TN
    So I ran 2 of the options in auto trans>basic settings> Then clutch engagement adaptation and distance calibration. The car seems to shift much smoother with less oddities. It did make a number of strange sounds and jerks like it was running through the gears and lightly slipping the clutch.
    Feb 20 2006
    NC
    I will have to try this, I hate when you floor it and it slips the clutch.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Dec 19 2014
    Virginia
    Quote Originally Posted by scottycs View Post
    That's normal behavior unfortunately it's just trying to find the proper gear I always shift down to the proper gear then take off.
    2010 s4
    Gone:
    Feb 20 2006
    NC
    just reset mine, car feels better :) maybe its just in my head.
    2021 BMW M340i
    Jul 31 2012
    Scotland
    I just reset the DSG adaptions on my car, as described in this thread and I'm pretty pleased with the results.
    "Faults" (aka, "minor irritants"): felt like lazy shifting (almost like a slush box). 4th to 5th RPMS would wobble a bit, especially if backing off the throttle and (something I've seen on AZ posted a few times) going WOT from 40mph+ ( 6th or 7th) gear in "D" and getting 3rd there was a really noticeable delay (easily a second) before the power actually came on and the car accelerated.
    -lazy shifting much improved, snappy again
    -4th to 5th Jury is out. Still does it on a manual shift but seems gone if I let the box do its own thing (I only ever use D and S, so I don't care)
    -and the big win: the acceleration delay when WOT to 3rd has gone. Car picks up great.
    'box had no stored faults before adaption or after test drive. Fluid had to be <60°C or it wouldn't complete, as noted above.
