Results 1 to 40 of 47
    Jun 04 2015
    Albertville, MN
    Cleaning exhaust tips
    It's hard to keep them looking nice in the winter. I'm wondering what everyone uses to keep your exhaust tips looking nice? I have been using never dull when the weather is nice enough to clean. Is there anything better to use
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    If you have any build-up, #0000 Steel wool with any cleaner like Adams APC.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Brillo or SOS pads.
    May 03 2009
    East
    Quote Originally Posted by Dr GP View Post
    Brillo or SOS pads.
    ^If you enjoy scratches.
    #0000 Steel wool is a better option.
    Junior Member Two Rings
    Aug 31 2004
    PA
    WD-40 cuts the exhaust soot well in addition to using the steel wool.
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    P21S Polishing Soap. And watch this video. https://www.youtube.com/watch?v=O5-pAvgmJuw
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Mar 21 2015
    Quote Originally Posted by wbellinz View Post
    Going to try that tomorrow, thanks
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    I used brasso stainless cleaner from home depot and it worked great
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Active Member Two Rings charlesml3's Avatar
    Dec 05 2015
    Wake Forest, NC
    So I'm a huge fan of most of the P21S products. Especially their wheel cleaner. As I'm going around the car spraying the wheels, I hit the tips with the same wheel cleaner.
    After it soaks a bit, I find a brush takes the soot right off.
    -Charles
    2015 S4 Prestige. Sepang Blue with Nogoro Blue interior.
    Nov 28 2015
    Montreal, QC
    i prefer to use 0000 and a metal polish.. rather than an APC...once most of the build up is gone. i use a metal polish with a microfiber. Look good.
    Jul 02 2014
    NW indiana
    Get some Never Dull at your local automates store. Stuff is amazing!
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    Once they are clean use carbon collective's product to make it easier to clean. I just picked some up but haven't used it yet. Soot is supposed to wipe right off
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Oct 13 2009
    MN
    Bar keepers friend. Cheap and works well.
    Deactivated Three Rings
    Aug 24 2015
    Quote Originally Posted by b8audis4 View Post
    What a project. And that was only 1 side. I mean yea it looks nice when done but at the first WOT afterwards, forget it.
    Sent from my iPad using Tap,Tap,Tapatalk
    Nov 06 2013
    Ohio
    Quote Originally Posted by S4NJ View Post
    Absolutely, I would say you could get about 90% of that look in 1/4 the time though just with what everyone else recommends, or P21S Polishing Soap.
    Established Member Two Rings spy963's Avatar
    Jul 30 2014
    B8.5 S4 & 997.2 Turbo S
    Montreal
    2013 Monsoon Grey /S4 : 6MT : Unitronic Stage 2++ : 58.3mm/186mm : PLM Heat Exchanger : Sachs XTend Clutch kit : Eurocode TRUfit Intake System : Bilstein B8 Shocks / H&R OE Sport Springs : Custom X-Pipe w/ AWE 102mm Exhaust tips : 034 Transmission Mount : CR-15 Strut Tower Brace : AG black M510 19x9.5 : ECS CF Decklid Spoiler : CF Mirrors
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Quote Originally Posted by B-Time View Post
    This... steel wool and cleaner, then metal polish 1 & 2 after they look factory new and it takes less than 10 minutes for the whole ordeal.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Quote Originally Posted by CrownSeven View Post
    +1
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    Quote Originally Posted by spy963 View Post
    For those of us with plated black tips (AWE on my car) I haven't found any answers yet. Each of these suggestions seems to use abrasives and theoretically could damage plating right?
    My only solution thus far has been elbow grease and things like standard Meguiars gold cleaning wax. I know the heat of the exhaust burns it off but at least it seems to work pretty good.
    Would love someone to help me understand a better solution
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Established Member Two Rings LurkAllDay's Avatar
    May 27 2015
    Centreville, VA - MAIC
    Quote Originally Posted by TexasDfwS4 View Post
    +1
    +2
    Sent from my SM-T357T using Tapatalk
    12 S4 - GIAC Stage 2 w/ TCU tune - USP intake - AWE Resonated DPs - AWE Touring - 034 Trans Mount - CR-15
    Apr 04 2012
    MSP
    Any good cooktop cleaner will work...
    Mar 21 2015
    Worked great. Came out nice.
    Jul 14 2013
    British Columbia, Canada
    +1
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by kcobourn View Post
    why use a WAX/PROTECTANT when you want to CLEAN/REMOVE something ? use an APC simply and it should be fine. True an abrasive could damage the plating, but then since it's black, theres no need to scrub as hard than a shiny reflective metal.. so APC should do the trick just fine.
    Senior Member Three Rings Dominick's S4's Avatar
    Oct 04 2013
    2016 Audi Q5s 2016 BMW 340I M 2014 Jeep Grand Cherokee Limited 2007 Jeep Grand Cherokee
    Johns Creek, GA
    Adam's #1 and #2 is the best stuff out there... Cleans Chrome like magic.
    2019 RS3 - Black - Unitronic Stage 1+ ECU 93 and E85 tune and Unitronic Stage 2 TCU Tune, APR Intercooler, APR Turbo Inlet and Open Air Intake, IROZ DSG Catch Can and Engine Catch Can, ECE Poly DogBone Mount, P3 Gauge - E85 Content Monitor, Neuspeed RSe10 18x9 wheels Satin Black, MP4S 255/35/18. Best of: 1/8 mile 7.006 @ 102.28mph, 1/4 mile 10.828@ 129.78mph, 60-130 - 7.86, 1/2 mile 17.29 @155.59mph
    Senior Member Two Rings socalfun64's Avatar
    Aug 18 2014
    2004 Jeep Grand Cherokee, 2014 VW Jetta 2.5, 2010 VW Jetta 2.5
    Palmdale/Ca./United States
    Make sure not to ever use one of those green pads used in kitchens. They take the finish right off. Ask me how I know, lol. One thing cool though is I was able to order brand new replacement tips from AWE for just $50.00. They are beautiful!
    Mar 21 2015
    Quote Originally Posted by socalfun64 View Post
    I had a friend that thought he could use one of those on his paint and killed his hood. You got a deal on those tips. A guy the other day on here called to get a set and awe told him 300.
    Jan 04 2013
    2008 Acura MDX
    United States
    Quote Originally Posted by waxxonMTL View Post
    When stated this way yes, it does seem dumb lol. I had some laying around & figured why not see what happens? It did better than AWE's recommended soap / water routine.
    Regarding your recommendation is this what you're using & if so do you also have the AWE black tip setup?
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Quote Originally Posted by Bsimms View Post
    X2 this works really well.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Nov 28 2015
    Montreal, QC
    no i dont as i still have an awe chrome catback waiting to be installed, but as a detailer, this is what i would do if someone came with a black plated exhaust tip. I wouldn't certainly not use a wax to clean it, i can assure you haha.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I've cleaned them about 6 times over the past 3 years. Now I just leave them alone.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    I grew up hunting and Flitz worked really well on knives and guns.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Good chance it can be saved. Clear coat likely is pretty thin there but hit it with an orange pad and some Meguiar's 101 Foam Cut or 105 series and you'll know in a couple minutes. Once that works, hit it with some polish folllowed by an IPA wipe and and then I'd honestly use two coats of CQuartz or other ceramic coating to seal it up from there.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Mar 06 2015
    Columbus, Ohio
    I wash mine up with some old cheap microfiber and detail spray. Every couple weeks I use the same cheap MF Towels and some basic OTC metal polish. They come out brand new. Keep it simple.
    One thing I noticed that my old car had was about a 1/4 hold set back in the tip just after the pipe connected which allowed a good deal of the moisture from initial starts to drip out without staining the tips of the pipes. I don't think our cars have that but it makes me want to take a closer look at them to see if it's possible. They were far enough back that you couldn't see when walking by.
    Oct 14 2012
    Empty...for now...
    SE PA
    I have been using Eagle One Nevr-Dull for the past year on my chrome AWE exhaust tips and it works pretty well. If I had a fresh start with those exhaust tips (they were two years in service by the time I got around to using any kind of polish on them), I'll bet they would be as clean as the photo 14S4GWM posted. As it stands now, I can get the outside surfaces and outward facing edge of the tip wall relatively shiny so as to give the tips some definition, but there is permanent degradation of the surface on the inside of the tips to get it back to looking new.
    I think the big confusion comes from AWE making a statement that only soap and water is to be used, but I believe that statement was a blanket CYA which included their diamond black finish. Meanwhile we have all shown that regular off-the-shelf polishes will work on the standard chrome finish. I think the key is to start this polishing regiment right off the bat with brand new tips, to stay ahead of the carbon buildup and prevent permanent discoloration.
    SOLD 2015 Daytona Gray S4
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by SteveYem View Post
    Try hitting it with some no-fume oven cleaner after a drive home from work. Let it sit for 10 minutes then clean the inside with some steel wool.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Cheap Steel Wool pad and just use normal car wash soap (I think I'm currently using Miguar's Diamond).
    May 22 2013
    Boston, MA
    Collinite Metal Wax works really well. Fast, effective and easy to use even on the most filthy tips. I first learned about it here on AZ.
    2014 S4 | 6MT | Monsoon Gray | Black Nappa | Alu-optic | MMI | B&O | ADS | sport diff
    Aug 31 2004
    PA
    Glad to hear it worked well for you. I found out about wd-40's ability to cut carbon accidentally, but it's my go to now.
    Mar 21 2015
    It really was no effort. I had the wool already along with the WD. Didn't take much longer then a normal cleaning. It's my go to now, that soot sticks bad to the chrome. I'm curious to see if the WD will help fight the soot a little. Thanks again for the quick tip.
