Originally Posted by
WinterRunner
I say Yay! I've had them on the car for almost 40K miles, not even a hiccup. I used Gasttalt's rear spring spacer to compensate for the reverse-rake look, all is perfect!
Thanks man, exactly the info I was looking for. Do you mind a couple of additional questions?
- Did you use the H&R springs listed under item# 50300? They don't use that number in EU, I found them under 29312-3 (They have 3 different versions -1 for A4, -2 for S4 and -3 for RS4)
- Do you know maybe what the spring rate is on these and what was the spring rate on the OEM springs?
- The 40k says everything about the quality, do you also drive through snow/salt?
- Can you share more detail on these Gasttalt's rear spring spacer? I would very much like to get rid of this reverse-rake look.
- Were adjustable upper links required to fix the camber at the front? I doubt since it's only a 0.75" and 0.6" drop.
- Do you maybe have any pictures of your car before/after the spring change?
komseh
I'd say just do the coilovers when you are ready, don't worry about half-measures before then.
Good choice on the clubsports btw, mine are due here early March. Zee Germans have been taking their time.
ZEE Germans! :P
Yeah I'm lucky with KW and H&R being stationed in Germany, postage over to Slovenia is 20€.
The springs in question are available in Germany for 160€ + 20€ shipping. That's not a lot to experience how the car handles at lower ride height and (hopefully) stiffer spring ratio.
And I already have a Hotchkis rear sway-bar on the way over from the States - so combining these two should make a noticeable difference in stiffness and handling.
singleframe
Few of us have gone with the KW HAS kit and had solid results. Check them out.
I also saw KW HAS coilovers but at the moment I'm looking to keep the DRC shocks.
HamidsVikes
Nay...
I went with that set up originally..
front end was not low enough...
I found out that B5 perches will lower the front end...
so switched the perches...
it was good for awhile till the shocks started to fail...
installed Beilstin shocks...
front was back up high again... B5 perches wouldn't work on these shocks...
so switched it that day with H & R coils...
should have gone with the coils to begin with..
would have saved lots of $$$$ and headaches..
you will have to replace the shocks down the road anywise, so just do it once with the coils..
only one install, and the set up is soooo much better than springs alone, and way better than springs with aftermarcket shocks...
its worth the wait!!!!
Thank you for sharing the negative experience! I'm aware that at any given time the DRC can fail and I will have to change to coilovers but for the time being that it's working I'm searching for a solution to get a bit more stiff ride and to close the gap between the fender and the wheel.
I would say that your bad experience with was due to bad-luck followed by some more bad-luck. I hope my experience will go more smoothly. *knocks on wood*
