Results 1 to 12 of 12
    Established Member Two Rings p310b's Avatar
    Jan 15 2016
    Indonesia
    P0192 - 002 G247 short to ground
    So finally I changed all py plugs and coil. The shaking is gone and while under WOT i got a heavy fuel cut arround 4000-5000 RPM. Does anybody have a problem with G247 before, or it could be something else?
    Jan 15 2016
    Indonesia
    Its after the FMIC that it doesnt tapper down as quick as before
    Also at 4160RPM my boost was spiking more than before and engine load at 160%
    My car ECU is stock with installed hpfp internal ,TP,DP, and FMIC , GFB DV+and pippercross air filter. I Just installed all the hardware before stage 2+ upgrade but it keep giving me problem. Before with TP and Dp it only spike arround 1780, Im on tropical country the atmospheric pressure is about 1000Mbar all year round.
    Jan 15 2016
    Indonesia
    Bump!!
    Jan 15 2016
    Indonesia
    Anyone??
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    I had some fuel cut issues at WOT 4k rpm and above. Do you have any codes? After replacing the cam follower these fuel cuts subsided.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jan 15 2016
    Indonesia
    Cam follower is brand new and recheck everything after the fuel cut.
    The only code i found is P0192 for G247 and havent found someone whith this problem, so before i purchase the new G247 might as well ask if maybe the problem isnt the sensor at all.
    Jan 23 2013
    Chicago
    Did you check the wiring to the fuel pressure sensor?
    Jan 15 2016
    Indonesia
    Yes I did physically, might get multimeter on Monday if I couldnt find the prob. Its just weird. I just want to know if theres anything I should look up with this code throwing up. Could a sensor cause you fuel cut?
    Thanks for answering!
    Jan 15 2016
    Indonesia
    Checked the wiring and everything is ok. Could it be something else before i decide to buythe G247?
    Oct 24 2015
    Perth, WA
    If the low pressure side isn't keeping up then the high pressure side wont either. May be look at in tank pump.
    My respray thread
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by Okedokey View Post
    Unless it's faulty that shouldn't be an issue. The stock low pressure pumps can handle stage 3 requirements. Unitronic only starts to recommend them above 450hp for example.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Jan 15 2016
    Indonesia
    Low pressure pump is new, been driving for couple of days an havent got an issue. Hope it wont come back.
