Results 1 to 4 of 4
    Veteran Member Three Rings notn41's Avatar
    Jul 09 2013
    2012 V Rod Night Rod Special, 2009 GSXR 1000
    Las Vegas
    How much hp can stock s6/s7 drivetrain/transmission/motor hold? 1000hp?
    I saw a video today that stated the rs7 can hold 1000hp no problem. How can our cars hold up. If we do turbo swap/race tune/gas etc. Can they hold same power levels? I wouldn't think so. I would think they would beef up the trans/motor/drivetrain on the rs7.
    2013 S7 Phantom Black
    Options:Innovation Package, Comfort Seats, Radar Assist
    Interior Mods: Atlas Carbon Inlays, Full leather/alcantara red stitch interior, Full led interior lights, facelift sweeping tail lights
    Exterior Mods: H&R Lowering module, 15mm spacers, Black OEM RS4 wheels 20", Stinger VIP, Milltek Valvesonic High flow catted TBE
    Veteran Member Three Rings BlueSVT's Avatar
    Oct 06 2013
    I don't think the "limit" is known... only because nobody has broken them, even on 750+HP stage 3+ cars. So yeah, they're strong!
    Let us know if you find that limit, LOL.
    Arguing with an engineer is a lot like wrestling with a pig... After a couple hours you realize the pig likes it.
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Keep in mind that the RS7 has the Tiptronic transmission where as the S6/S7 has the S tronic transmission. Depending the which version of the Tiptonic is used determines the rated torque for that transmission. I believe in the case of the RS7 it has the 8HP70 version which is good for 700 Nm of torque. The S Tronic has a lower torque rating than the Tiptronic hence the reason the Tiptronic is used in the RS7.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Established Member Two Rings TurtleHaste's Avatar
    Aug 29 2015
    I've had my Stage 3 - S6 on race gas plenty and have done a lot of testing. Also enough 4th-5th pulls. To load the clutches heavily with no slip of clutches yet. There is a place I know that I believe makes modified clutch packs, and I would say this might be the biggest weak area. Also, there is an engine cooling difference between the RS7 and the S6 but I don't think it has been shown how significant of an issue it may ever be. Given the proper supporting mods, I don't think there is a lot holding it back. Internals, and cam profiles are a little different but I doubt this should prevent RS7 stage 2 power levels from being seen on an S6/S7 properly modified and cooled. It will cost a decent penny to modify the fueling system to keep up with 700+ AWHP though. High-pressure and low-pressure pumps and of course another custom tune. But then again, you are talking non-OEM spec turbos in this case.
    2014 S6 Stage 3 (RS7 turbos) / Roc-Euro intake / Milltek downpipes + resonated Valvesonic exhaust / AMS turbo cooler / 034 Motorsport trans. mount kit / APR ECU/TCU tune
