Results 1 to 40 of 58
    Jan 31 2016
    SoCaL (L.A. County / O.C.)
    Talking Brake Caliper Compatibility (Porsche Calipers)
    I know some calipers are interchangeable.
    However, I'm not sure as far as what year/model Porsche the B7 A4's are able to use.
    Here's what I'm looking at. Found a pretty inexpensive deal on these...
    OE (Left)
    Porsche 991 Front Brake Caliper Porsche Part No 997 351 421
    Porsche 991 Front Brake Caliper Sensor Wire harness
    OE (Right)
    Porsche 991 Front Brake Caliper Porsche Part No 997 351 422
    Would these be a direct fit?
    Minor modifications?
    Major modifications?
    Would not fit?
    UPDATE - Thoughts on post #51?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Fronts and rears will need major modification. Firstly, they would mount to the uprights without designing and building custom mounts. Then you'd have to figure out which rotors you can bastardize and modify to fit the bolt pattern, offsite, and centre bore. Then you need to sort out lines.
    Ultimately, you can make almost anything fit, but it depends on what you're looking to spend and get out of them.
    Cheers!
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Why not go with the tried and true Cayenne calipers?
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by AJacksA4 View Post
    Agreed. And I have a set, or two...
    Jun 17 2013
    jersey city nj
    Or go with true ons. A RS4 front BBK 8 pot calipers. No modifications what so ever. Even use the same brake hoses if you want.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by vce1232000 View Post
    Agreed; ultimately the best option. Also, the most pricey option as well.
    Jan 31 2016
    LoL.
    Thank you for your input and details guys. Much appreciated.
    See... if it were "MY" car, then yes, I'd slap on some pricey calipers. However, it's the wife's car and I get to mod it and drive it a couple times here and there.
    I don't want to spend too much on her car cause I still need money to continue modding mine. LoL.
    Just curious, but what are used Cayenne calipers running for a front pair?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by james12lucy View Post
    As you know the good aint cheap....lol
    Jul 04 2015
    Toronto Ontario
    Yessir. That's why I think the 17z/18z swaps are the best bang for the buck on a B6/B7 A4.
    Jun 17 2013
    jersey city nj
    I with you on that one. As stated above tried and true. I got my RS4 for a real good deal. Thats how I ended up with them. If I didnt I would go with the 17z also
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by BaByBoiGsxR View Post
    LoL.
    Thank you for your input and details guys. Much appreciated. See... if it were "MY" car, then yes, I'd slap on some pricey calipers. However, it's the wife's car and I get to mod it and drive it a couple times here and there. I don't want to spend too much on her car cause I still need money to continue modding mine. LoL.
    Around $450 for 17Z (330mm), and $550ish for 18Z (350mm)
    For what it's worth, there is a bracket available from Apikol to mount the 996/Boxster S calipers but it doesn't really make any sense to do, for a few reasons. One, it's made to work with OE 321mm rotors, so you don't get better fade resistance over stock. Two, the calipers are tiny compared to the 17Z/18Z. And three, you don't really save any money over the Cayenne calipers once you factor in the cost of the brackets.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 17 2013
    jersey city nj
    I dont know how true this is but. Ive in a few places that the 17z\18z can grab rather hard and trip the ABS computer putting into fail safe mode
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I had 17z an never had any abs problems. you can get 17z from advance auto as remans for like 210 each including core
    Sent from my SM-N920P using Tapatalk
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Jan 31 2016
    Quote Originally Posted by LINDW4LL View Post
    Between the two options... I'd go with the 330mm. The car is used mainly for daily commute. No track or racing.
    However, based on your explanation on the brackets, I might as well do the Cayenne swap... right?
    If that's the case, I'll keep an eye out for them. Just a few weeks ago (before I knew about the calipers), I saw a Cayenne being parted out at a dismantling yard.
    Jun 17 2013
    jersey city nj
    A FYI on the Cayenne caliper mod. You need to modify different rotors then stock.
    Another option to explore http://www.audizine.com/forum/showth...ild-BBK-thread
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    you gotta order the jhm bolt kit for them as well
    Jun 27 2011
    Wait so you want "cheap" porsche brakes for your wifes car? does she drive agressively or is it just for looks?
    My point being the stock brakes are actually pretty damn good. Just get some S4 carriers, 345mm s4 rotors, Tyrolsport stiffening kit, stainless lines, and some good pads and call it a day. Brembos aren't going to make a huge difference except at a show or on the track. And if you want some flash, paint the calipers.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Apr 12 2015
    '06 VW TOUAREG (V8), MTN Bike
    FALLON, NV
    I may have to do some research as to how much this "kit" will cost. Still have all original OEM on mine @ 70K. Thanks for the info
    I'M THE ORIGINAL OWNER OF '07 B7 A4 2.0T 6MT Q (62K): JHM 91 OCT STG 2 | CARBONIO INTAKE | 034 REAR SB | JHM TP | JHM DP-Y | B6 S4 CB
    Jun 27 2011
    Quote Originally Posted by MISKIE View Post
    No worries. brembos are "better" there's no disputing that but the only real reason to get them on a daily driver is for the look. And frankly they do look pretty beastly so I definitely get it. But from a performance standpoint you're better off doing what I listed above and spending the extra on better tires. Getting decent Max Perf Summers was the best performance upgrade I've done on my b7 aside from the 034 rear sway. I have Sumitomo HTR-ZIII. They're still a budget tire but they have loads of grip and handle excellently in the wet and cold. Can't ask for more in a $100/ea tire. I've yet to really find their limits on the street.
    -CP
    2017 Q7 3.0t
    Dec 10 2011
    CLT | MKE
    Honestly, a good set of aftermarket pads with the stock rotors is more than sufficient for the large majority of people here. Lines if you want a bit better pedal feel during hard driving, and new fluid is always good if yours has not been changed in the last 2-3 years.
    -Hayden
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    I am most likely gonna go with q5 calipers. There are 4 pot brembos and use a 345mm rotor. I was gonna go with the 17z but they only use a 330mm.
    Jun 17 2013
    jersey city nj
    LOL... to show off that SBK rite
    Nov 15 2011
    Montreal | I sell in USD
    Why not 2013+ Q5 calipers?
    2.0T Q5's use 320mm
    3.0T/3.0Tdi's usd the 345mm
    *****I sell in USD*****
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by klrider44 View Post
    I meant 345mm. Axis has it right. I would think the q5 option would be better than the 17z and should allow you to use a 17 inch wheel. The 18z calls for an 18 inch wheel.
    Jun 27 2011
    If you got it, flaunt it, bruh!
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    17Z all day
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jun 17 2013
    jersey city nj
    SBK= Small brake kit
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by vvenom800tt View Post
    17Z all day
    How much improvement over stock are the 17z's? The only reason why I would want to go with the Q5 brakes are because they are 345mm instead of the 330mm rotor on the 17z. Do you think it would be worth it to go Q5? There is a pretty good deal on a pair of 17z's I would like to hop on if it wouldn't be worth holding out for the Q5's. Just trying to get some opinions?
    Dec 04 2011
    Kansas City, KS
    Its a big improvement, i had Stoptech street pads before which are fine, but im running yellow stuff pads with these and they stop very well. Its an improvement for sure. You can definitely feel it.
    17Z will be at least $400 less
    Who cares about the 15mm rotor difference when you have calipers that are this huge, plus, 330mm rotors are lighter than 345mm rotors, which is a good things since its unsprung weight.
    Aug 20 2014
    Doylestown PA
    What rotors are you using? Also do you think it is worth it to use a two piece rotor. Jhm sells a two piece rotor for the 17z kit, but they are $715 for a pair of front rotors!!!!!!
    Jun 27 2011
    Improvement in what? Over OEM...
    -CP
    2017 Q7 3.0t
    Apr 12 2015
    FALLON, NV
    Damn you all AZ Audi experts!!! So many mods I want to do but not much "moolah" coming in
    Learning a lot though so when I do get the "moolah" I'm ready
    Dec 04 2011
    Kansas City, KS
    I think they are ML320 Rotors, just had to open the center bore 1mm.
    2 peice rotors are a waste if youre not tracking your car, i paid $100 each for my stoptech slotted from rockauto.com
    Jan 31 2016
    Yes and.... yes. LoL.
    The wife drives aggressive at times but I definitely do when I drive it. I love the car. It's night and day difference between my car.
    Are S4 carriers a type of bracket?
    What size are OEM A4 rotors?
    I think because I'm so used to always having large brakes since '07 with my cars, I'm not used to "smaller" brakes and always seem to have the urge to upgrade.
    I'm definitely going to consider going the S4 route if it saves me money and performance is improved.
    Just for kicks, here are my two other setups...
    Upgraded to C55 AMG brakes. Powder coated gunmetal.
    Probably a poor choice in color. Couldn't really see it from far away.
    Lesson learned from the "hard to see calipers" on my white car, so I went a little "louder"...
    I like upgrading brakes so much, that I even had my bro's calipers painted for his birthday last year...
    Sorry, don't mean to post too many pics. I just like this stuff.
    Nov 15 2011
    ^^I like that amg
    Stock rotors are 320mm, you can use an S4 caliper carrier to move the caliper further and then run S4 rotors (345mm).
    You will still have the same single piston caliper but will get rid of the heat a bit better.
    Jan 31 2016
    Cool. Good to know.
    Definitely considering it.
    Mar 24 2013
    Oakdale, CT
    Lesson learned from my white car, so I went a little louder...
    Makes me miss my SL55. That thing had monster 8-pot calipers up front (4 pads per caliper) and something ridiculous like a 14" rotor. (Edit: It had 14.2"/360mm front rotors)
    -Adam
    Jan 31 2016
    SL55? Very nice. Were you in any of the Benz forums?
    Mar 24 2013
    Oakdale, CT
    MBworld with the same username.
    -Adam
    Jun 27 2011
    You need beefy brakes to stop a car that weighs over 2 tons...
    -CP
    2017 Q7 3.0t
