Originally Posted by
BeerBrent
Will those shocks pair up nicely with Eibach springs? I'm looking to replace mine soon.
I would think it would be a great shock for Eibach Sport Springs, I had Koni yellow sport shocks on my 08 Passat that had the VW Driver Gear Sport Springs (30mm drop) and I think the Bilsteins in links below are every bit as good for a DD.
https://www.fcpeuro.com/products/aud...ttro-19-171623
https://www.fcpeuro.com/products/aud...ttro-19-171616
I took the Eibach sport springs off my 09 Avant after I bought it and put Avant S-Line OEM springs on with the Bilsteins, the Eibach sport springs lowered my Avant about 1/2" + in front compared to back and fronts were so low that my front suspension bottomed out a lot with my daily driving around here and crappy roads during winter.
Front
[IMG]
A4 Front by
Robert Prato, on Flickr[/IMG]
Back
A4 Back by
I had major problems getting the upper control arms disconnected from steering knuckle, you can look up my thread, so my suggestion is undo upper control arms at upper shock mount and when you re-attach make sure front suspension is loaded before you tighten nuts.
Also, you need short bump stops up front for sport springs if that is not what is currently in your Avant.
The Eibach springs had a nice ride, not bouncy, but I would figure out a 3/8" spacer under or on top of the front spring for a slight more ride height in front to level stance out out trim 3/8" off the rear upper rubber spring mount to lower back to make car level.
Have you considered coilovers ? If I were going lower than factory S-Line Sport Springs no doubt in my mind that I would use coilovers for the flexibility in adjusting ride height. The guy I got from S-Line springs from went with Vogtland coilovers which I know from experience is a good product at a fair price ($800 range) NGP (New German Performance) is where my son got his for 15 GTI.
PM me if you have any questions you want to ask off this thread.
