Results 1 to 30 of 30
    Jun 10 2008
    sf
    UPDATE:Automatic Shifter Stuck in P - Shift Button Won't Depress
    UPDATE:
    Car towed to Thursday, problem identified, part found in Houston or Toronto, did not arrive until Tuesday, second part determined necessary, arrived Wednesday, car picked up, good to go, with no wash, per usual because of the California "drought"
    "Selector Mechanism Release" - This I guess is that green circuit board underneath the shift boot. Somehow that failed and had to be replaced. This is rare so they did not have parts on hand...or in the country. This may have been listed as $495?
    "Clip and Housing" - After removal and replacement of the above, it was discovered this clip and housing were broken so they were replaced as well.
    Seems pretty crazy that an electrical component in your car could fail and not allow you to change gears even when using the emergency override. The whole point of the override is to change gears in an emergency!
    Yesterday I parked it at my garage and walked away. Forgot to leave the key for the attendant, he chased me down and I gave it to him. Get a call 3+ hours later saying car won't work. I check it out, hasn't moved since I parked it.
    - The car starts just fine - you can rev, no warning lights, radio works, Parking Brake Engages/Disengages
    - The car will NOT shift out of P--the actual shift button itself is pressed into the shifter and will not pop out nor can be pressed in further
    - Attempted the shift lock release (hidden under ash tray) to no avail - when car is off I can feel it softly bounce up and down and lock my key in ignition and when car is on it doesn't do anything
    - Did a quick scan of all three fuse boxes and nothing jumped out at me, didn't check brake lights but no warning of dead bulbs
    I know there are some security measures that may happen if the key gets too far away and what not but I don't understand this. It seems like a mechanical/physics issue. The shift button is stuck in the pressed position and will not pop out and I can not figure out how. Last resort is towing to dealer - but I can't even shift to Neutral!
    Apologies for posting to the wrong forum but 1. I'm assuming B8 S4 owners to be pretty knowledgeable 2. the Q5 forum is a graveyard and 3. every newish automatic audi has pretty much the same shifter.
    2012 Q5 3.2 6 Speed Automatic
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Pull out on the button. Your spring loaded pin behind the button probably broke.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jun 10 2008
    sf
    Tried that. Sort of.
    There is nothing to grasp on to pull it outs, so I tried sliding an eye glass sized screw driver by it. Didn't work and didn't want to be too aggressive with it either and damage the grip.
    Apr 05 2010
    Is the steering wheel locked?
    2020 SQ5 Quantum Grey
    2018 C43 AMG Selenite Grey
    2018 SQ5 - Sold
    2014 S4 - Sold
    2004 A4 USP - Sold
    Nov 23 2014
    North Carolina
    i think you have a different transmission, but that aside can you use tape? place tape on the end of the button and pull it out? i presume you tried whacking the shifter to see if it popped the button out that may have been caught on something slight? have you called your dealer service adviser and ask them if they ran into it before and have suggestions?
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Jun 10 2008
    sf
    Nope. Should have included that above. Power steering works and the wheel turns just fine. As far as I can tell literally everything is functioning just fine. Except I can't shift.
    This bothers me because I don't know if:
    - it's my fault for walking away with the keys, causing some sort of mysterious security feature to engage when attendant got in car
    - attendant's fault for doing something weird that somehow stuck the shifter
    - recent Audi service fault (one week ago) that just happened now
    - dumb luck
    I also feel silly calling insurance to have this towed to dealer if it's a quick fix.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Post the solution when you find out what caused it. Must say its pretty strange.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Jun 10 2008
    sf
    Unfortunately it sounds like the solution may be to tow it to the dealer which will be a challenge in itself. AWD vehicle stuck in park located inside a tight public garage.
    I have watched some of the videos for boot removal and it seems simple enough...except you are supposed to hold the shifter button out and mine is stuck in.
    Jul 12 2012
    Tried calling Audi roadside for suggestions?
    Jun 10 2008
    sf
    Not Audi Roadside.
    Called Service Advisor - "Jiggle it when pressing lock bypass" Nope "Tow it"
    Awaiting Local Service Advisor
    Likely calling insurance for a tow to local dealer shop.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    I am guessing the car is out of warranty if you have not contacted the dealer?
    Disconnect the battery and reboot the ECU? That might release the button if it were stuck due to an ECU issue, but not if it is physically broken.
    Jun 10 2008
    sf
    I am 3 months out of warranty. However I purchased it as a CPO and have the extended 2 year warranty ($85 deductible on almost all work). I don't know if this means I am eligible for Audi roadside assistance though.
    I thought about doing a battery disconnect but it was getting late and I was concerned about other issues than can arise with battery disconnect (radio keys, etc). I don't know enough about this car to start digging around too much.
    Oct 27 2009
    Miami, FL | Boone, NC
    Definitely sounds like the pull for the lock in the shifter broke. That's a purely mechanical thing (no car controlled immobilization safety features, etc related to it).
    I'd see if your dealer has a replacement knob in stock and try to replace it where the car is currently sitting, or maybe see if a tech can go over and do it (it's not a very involved process).
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 30 2015
    Sacramento, Ca
    Grab the end of the button with pliers (put a cloth around it to minimize scratches) and pull...it will come out. If the spring pin is broken, it's worthless so you'll need to go buy a new knob and replace it.
    Will
    Jun 10 2008
    sf
    on the phone with audi assistance right now trying to determine towing.
    if I have to replace entire shifter am I better off getting the cooler shifter (not SQ5 badged of course!) or replacing in kind?
    Dec 30 2015
    Sacramento, Ca
    I went with a Black Forest knob, but that took about 1 week to get. I geuss you could expedite shipping
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Is there enough of the button exposed to try sticking some Gorilla tape on it and using that to pull it out? That is some seriously sticky duct tape - might be worth a try.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Edit: nevermind
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Mar 28 2009
    Minneapolis, MN
    Unbend a paper clip so you have a long straight piece. Bend a small hook on one end. Slide that end in between the button, then rotate it so you can "hook" the inside edge of the button with the end of the paper clip. This is the method I've used to pull out the shift button on new shifters when installing or removing them. New ones usually come with a red piece of plastic wedged in there to keep the button out until it's installed. This may or may not work on a shifter that is already installed, but it's worth a shot.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    You should be able to remove the shifter knob and boot pretty easily to get at the plastic plunger. I know it only took me a couple of minutes to remove mine to change. I may be wrong, but assume you can still shift as long as you still have the plastic part intact ( the one everyone heats and twists).
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jun 10 2008
    sf
    Just got the call from the service center.
    "The electronic shift release mechanism failed and needs to be replaced. Shipping from Texas, could be a few days."
    Don't really know what exactly that means but according to them it's actually an electronic component that failed which is supposed to release the button; and is not normal and not carried due to the rarity of this happening. They will replace this component, but not entire shift boot (no idea which way is easier).
    I don't know if this means none of your above fixes would work (perhaps it's locked down and can't be pulled out), or would only be temporary (I'd have to pull out every time I shifted [story of my life freshman year]).
    Man I wish I could get another a5 for a few days with Audi On Demand but I'm getting surgery and can't drive for a couple days anyway :(
    Mar 10 2015
    New England
    Quote Originally Posted by kaizr View Post
    This is the S4 section so an A5 would be a downgrade for us, peasant!
    Glad they were able to fix it
    Deactivated Three Rings
    Aug 24 2015
    What happened in the end?
    Sent from my iPad using Tap,Tap,Tapatalk
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Did you look into the shift interlock override? Its location and how to use it should be in the owners manual. IIRC it's underneath the ash tray. This would let you shift the car without pushing the button in. It's dangerous because of how easy it would be to shift into R accidentally so, if you're careful, the car should still be driveable.
    Found a video:
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by amz View Post
    Found a video:
    his post indicated he tried that.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by BlownOne View Post
    how do you like that? are there any threads on here with a review? it looks nice, and i guess does NOT need the heat+twist?
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Aug 22 2014
    bloomfield,ct
    does a weighted knob make a difference in a DSG car? Except for the look?
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by jygesq View Post
    weighted knob really doesn;t make much of a difference on a manual car, but hell a golf ball would look better than my camry-esque selector in my car.
    [CENTER]Scott
    2011 S4
    Jun 10 2008
    sf
    UPDATE:
    Oct 27 2009
    Yea sounds like the mechanical button connection was the ultimate culprit. I'm thinking they thought it was the electronic component, replaced it and saw it didn't fix the problem, then replaced the "clip and housing," which sounds more likely to break.
    I believe the "Selector Mechanism Release" prevents you from shifting between gears at times. I.e. I couldn't shift out of neutral on my A4 unless stopped (and I could hear the actuation of the lock that prevented that). However, I do not believe this has anything to do with the button on the knob, as the depression of it felt exactly the same even when my shifter was locked.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
