Results 1 to 23 of 23
    Active Member Two Rings Cba71591's Avatar
    Apr 17 2013
    Atlanta
    Tires are making a really loud noise
    The tires on my 2015 s4 started making really loud noise these last couple months. First it wasn't bad but it got worse and worse. My car only has 11,000 miles and the all the tires are pretty much done and need to be replaced. I'm bringing it to th dealership today, I was wondering if anyone had a clue what it could be thanks
    2015 S4 Sepang Blue
    2010 A4 2.0T- Brilliant Black/Premium Plus/19" Avant Garde M368 sold
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    How do you typically drive? Like a grandma or like you stole it?
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by cadence View Post
    Honestly it doesn't matter how you drive it. The factory SUMMER tires just flat out suck. They get noisy and chopped up as the wear. Its normal with these tires. And replacement is between 10-15K. The noise will go away after replacement don't worry. If for some slim chance the noise is still there, its probably a wheel bearing. But that is like a 5% chance maybe.
    Apr 17 2013
    Atlanta
    Drive not that hard only every know and then when I'm in the mood. Just gave them the car at the shop should have a answer soon.
    2015 S4 Sepang Blue
    Nov 25 2015
    Miami, FL
    Quote Originally Posted by chaos2984 View Post
    That's true
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    +1
    I replaced mind at 15,000 and had it aliened. but get PSS
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Account Terminated Two Rings
    Jan 23 2016
    Hong Kong
    how do you typically drive? Like a grandma or like you stole it?
    hahahahaaa
    Nov 25 2015
    Miami, FL
    Just curious what tires do people typically have from factory? Mine came with Continental Sport contact and they've done a pretty good job so far
    Jan 23 2016
    Hong Kong
    Quote Originally Posted by Cba71591 View Post
    Pirelli 0 would be a better choice for you.
    Nov 25 2015
    Miami, FL
    Quote Originally Posted by pinalloy.com View Post
    Noted. I'll look into that next time I need tires
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    The stock Continentals are absolute trash...when I give my friends rides in the car, they point out how loud the tires are. I really notice it when I'm slowing down and coming to a stop. Just waiting for these to wear out so I can get some PSS...
    Established Member Two Rings Sailingtime's Avatar
    Mar 18 2015
    2003 Vw Jetta GLI VR6 BDF Turbo
    NYC ��
    I have the same issue with my stock tires. I had Audi check alignment and one wheel was off. However my stock 19" Contis, are very loud the tires sound like an off road tire at low speeds. You can try warranty the tires as manufacturers defect, I only have 7500 miles on mine and the noise is insane, the tread is starting to wear uneven, as well. My SA said to drive for a,while then we can start warranty claim with Continental. What a joke!!! I'm sure Continental is going to come up with all kinds of excuses as to why tire is so loud.
    Cheers good luck!
    2015 6Spd Daytona, Tech, Sport Diff, Napa , B&O, Black Ops, Carbon Inlays.
    Apr 04 2012
    MSP
    They will come back saying the tires need replacing. Don't buy tires from them.
    Apr 17 2013
    Atlanta
    They said it is the tires and will be going back next week when the service manager is there so we can contact Audi and hopefully get a new set for free
    2015 S4 Sepang Blue
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Don't get your hopes up for that...highly unlikely they will give u a free set of tires because they are noisy and need replacing on 11K. Do yourself a favor depending on where u live and get yourself a all season tire. less noise and will last longer.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Apr 04 2012
    MSP
    Quote Originally Posted by dizzlesizzle View Post
    +1 - very unlikely they will give you a free set... tires wear out. They will prob try and "give you a deal" on a new set. I wouldn't want another set of those tires either.
    I'd personally get a set of winter wheels and tires off Tire Rack (Atlanta gets some snow and ice - isn't it freezing rain there today?).... then some new summer tires for your OEM wheels. Swap them out each season.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I started getting a lot of tire noise from the rear. During my 55k service they rotated them and the noise went to the front, confirming it was the tires. Took it to Discount tire and they found the two that were on the rear had some slight cupping on the inside edge. Not really bad but enough to cause noise and they said it is due to the alignment specs on these cars much like BMW and Mercedes, they see it as well. They said as they wear more, now that they are on the front it would go away. It has been a few thousand miles and the noise is going down, seems to be louder on some road surfaces more than others.
    I have a lot of tread left on my tires so they said it was not worth replacing them, it would be a waste of money.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Established Member Two Rings 604bking's Avatar
    Feb 26 2015
    +1 on stock summer tires suck and make a lot of noise. My cheap Hankook V12 is much more quiet.
    2014 Audi S4 | Phantom Black | Technik | Sport Diff | Black Optics | Magma Red | Carbon | S-Tronic | RS Grille | Rho Plate | H&R Springs | H&R Spacers | 20x10 Vossen CV3 Matte Graphite....All show, no go
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    My 6 came with Pirelli P Zero . Grip is great but they are noisier than a room full of kitty party women. Plus always remember that the factory tires will wear out quick. Its explicitly stated on tread warranty that OEM tires are not warranted. Which is what AoA would relay to you. So like others said, dont get your hopes up. I ended up switching to PSS .
    Sent from my SM-N920P using Tapatalk
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    My stock tires were noisy too early on. I brought the car to the dealer with 7500 miles on it. They determined that the tires were defective, and they went half with me on a new set of Michelin Pilot AS/3's. They took care of the warranty work with Continental. Had I waited longer, I would've had to pay more, until the point where I would've had to cover the full cost, as the tires would've been at the end of their life expectancy.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    With 11k miles you're pretty much looking at replacement. Mine were replaced at 12k. Got Michelin A/S3 on now, and 12k miles on those, and they're holding up fine. Only issue really, is that they are very square, so it affects the fitment moreso than PSS, Conti's, Pirellis, etc.
    Edit: Forgot to mention, dealer couldn't/wouldn't cover any of the cost. They were replaced out of my own funds :D
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Senior Member Three Rings Li ls4's Avatar
    Jul 19 2014
    2011 s4
    Long Island
    i have the factory dunlops on mine and i have love them.
    Jan 10 2014
    San Antonio TX
    I just replaced my stock Contis at 12K miles, the worst tire I've had period.
    Running Pilot Super Sports now, they are better in every way.
