Results 1 to 40 of 66
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    PCV install with intake manifold in place?
    Found some DIY info on the b7 rs4 but it was not clear, assuming I found the right one, if it could be done with intake on? Anyone have any good info on that? If so it would be great, or if there is another DIY out there for the RS4.
    Thanks.
    Senior Member Two Rings AWD Addict's Avatar
    Nov 06 2013
    Livermore, CA
    I'm interested in this as well. Out of curiosity, why are you planning to replace the PCV?
    Jan 27 2013
    To see if I can eliminate the 1 court top off mid oil change interval. And if I take the oil cap off while car is running there is major vacuum and car stalls, which I understand is a sign of failed PCV correct?
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by Seattle squash View Post
    Yes, that means the rubber diaphragm has failed.
    The PCV valve can be removed with the IM on. Take the intake elbow off, the PCV cross over tubes, throttle body, move the brake booster hose up out of the way, loosen the passenger side SAI valve which is bolted to the rear timing cover which will allow you to uncouple and push the SAI tube back out of the way so that you can then start removing both t30 screws that bolt the PCV to the intake manifold. After removing both bolts, you can get the PCV valve removed from the intake manifold, but don't pull it straight out, you have to lift it up enough where you can remove the oil drain back tube that is connected to the bottom of the PCV.
    2017 Camaro SS 1LE
    Jan 27 2013
    Quote Originally Posted by FWP! View Post
    Great, thanks for that feedback. So would you say about an 1/2 hour job or so? Thanks and got a new one ready to be installed.
    Oct 31 2005
    Ashburn
    It's a bitch to get to if you have sausage fingers lol! I have taken off/on twice and its a little bit of a pain. I'd say 45mins is about right haha!
    - Instagram: @Sinister_rs5-
    Veteran Member Three Rings evolution2147's Avatar
    Mar 25 2012
    AZ
    What oil are you running? I have been using mobil1 on my s4 and rs4 and have always had about 1-1.5qt loss and the yellow MIN oil light would always come on about 3k miles into the change. I just switched to castrol 0w40 and am at the 5k mark and have had no issues yet.
    Also every VAG car I have seen seems to stall out when the oil cap is removed. Not too sure why but i think its normal.
    Jan 27 2013
    Hmm interesting. Pennzoil ultra/platinum 5w-40. Similar for me except I just check and add slightly at 2.5k and never have the light come on. Thanks.
    Apr 07 2012
    Montreal Quebec
    Hi Seattle, i seem to have the same issue with my PCV... Is it a fact the the vacuum leak is directly associated to a defective PCV.... I do blow out a significant amount of smoke only when i start my car in the morning so i was thinking of eventually swapping it out....but after checking the oil cap my car definitely stalls...:(
    Oct 12 2008
    NW Washington
    What's the part number? Ty
    Oct 11 2007
    Suburbia
    I have to try this out.... What is the mileage we tend to see the failure?
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Oct 31 2005
    Ashburn
    As per JHM website.
    OEM Part Number is: 079103464F or 079 103 464 F
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by WinterRunner View Post
    It varies but I would personally do it every 40K to 50K at least.
    If it were my car then I would take it apart and clean it or better still replace the PCV every time that I do a carbon clean. However they are pricey at like $250ish.
    Oct 11 2007
    Suburbia
    So my car doesn't stall per se, but it definitely falters some, like lowering the choke on a snowblower or mower. I think I might have this done. Would it stall out within seconds? I took mine off and it was sputtering for 20-30 seconds before I replaced it, but never stalled.
    Apr 07 2012
    Montreal Quebec
    Hi winter... Was it tough to turn the oil cap while the engine was running followed by a vacuum sound?
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    JimmyBones,
    Have you experienced a decrease in oil consumption after replacing a PCV on an S4 or RS4?
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by CoreyRS View Post
    JimmyBones,
    Yes on the B6/7 S4s, the RS4s, the low revving 4.2 FSI V8s, and the 5.2 V10 FSI engines. The B6/7 S4s use a different style PCV that sucks as well. The RS4s, low revving 4.2 FSI V8s, and the S6/S8 V10 all use similar PCV valves but the angle of the drain nipple is different.
    Oct 11 2007
    Suburbia
    Quote Originally Posted by Al Sline View Post
    Yes, I mean it is under vacuum right? Either way I'm having this done, should also help with consumption issues (not alot, only about a quart every 5K).
    Mar 11 2008
    B7RS4 & e46Ms
    Our crankcase is not under vac (or very little vac basically). There's a breather from the intake elbow to the valley that flows metered air into the crankcase that then flows through the PCV into the IM. If the PCV diaphragm is torn, it will change the flow characteristics and actually create vac in the system since the breather can only flow so much air. Removing the oil cap introduces unmetered air into the system, and if that PCV is torn, it will take all of that air into the IM, hence the stalling. If your PCV is okay, it will bog a bit, but shouldn't stall. That being said, the idea of removing your oil cap while the motor is running just sounds like a bad idea...hope you don't have any sand/debris around your oil cap.
    FRRG AZ Ring
    Oct 11 2007
    Suburbia
    Well it bogged but didn't stall at all, even after 30 seconds. It is squeaky clean, I make sure of it everytime I add oil. Thanks for the detailed explanation. I think I'm going to have the PCV replaced anyways, as it's higher mileage (near 90K).
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Just to add to what people said, you'll need a pretty slim ratcheting torx bit driver/wrench to get to the screws holding the pcv in.
    Aug 07 2009
    Ca
    Good info here guys, thanks all!
    Nov 06 2013
    Livermore, CA
    Is the test with the oil cap the only way to determine if the PCV is failing? I'm getting smoke at startup but also when I pull away from a long stop light.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Physical inspection is the best way to determine if your PCV is bad.
    The smoke is black, correct? You may have issues elsewhere but ensuring a properly functioning PCV is a good start.
    Jan 27 2013
    Having it installed tomorrow, and keep you posted on differences in performance/consumption/behavior.
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by AWD Addict View Post
    Sometimes I have heard a whirling noise like a leaf or stick stuck in the wind coming from the PCV valve while driving. Usually the radio and heat/AC has to be off to hear it though.
    Jan 27 2013
    So new one installed today. I know the oil cap test is relevant now as it used to stall right away once removed. Now bogged down for a second and then stabilizes and runs smooth. Cool, will watch the oil consumption and see if cold starts are less smoky. Reference point for me; is 1 quart per 5k. I will update.
    Oct 11 2007
    Suburbia
    So it bogs but then sputters back to normal idle? Hmm then I suspect mine is not done for, but on it's way out...
    Jan 27 2013
    Yeah huge difference for me. Just a small hesitation/bogged down for a second and then perfect. Less suction too. Before crazy suction and then car completely died in a second.
    Feb 24 2010
    And have never been happier
    It looks like it's my turn to have this replaced now. I have a lot of suction when oil cap is removed at cold idle. Car bogged quite a bit once cap is removed but it didn't stall.
    Is this really less than an hour of a job? Do you have any lessons learned or gotchas from this? Thanks!
    Switched to Tesla and have never been happier. No more shady mechanic bills and excuses - oil top off before an oil change is normal or dealing with outdated forums that have image size limitations. And no more dealing with vendors that do not provide horsepower numbers but sell you random things by labeling them as performance parts. No more dealing with the Audi dealership and having to buy custom Audi specific tools. Wow. I can't believe I lived through all of this. Money pit.
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    got to try this test!
    @seattle squash, how much time did your mechanic charge to change the PCV?
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    Quote Originally Posted by wednesday View Post
    LOL. throttlebody off, all pcv hoses, purgevalve with hoses, SAI hose removed, throttle boot, misc hoses, slightly easier with the jhm coolant bypass. and the btch is the oil drain hoses squeeze clamped on. good luck.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Jan 27 2013
    Quote Originally Posted by MattboyR32 View Post
    He charged me $100 (an hour or less), well worth it to me, especially with a cluster of a back!
    May 29 2007
    any other work done at the same time? carbon clean? flap work, etc?
    Nov 28 2006
    Wow. Ok cool. I did the oil cap test and the engine really struggles to get back to idle. It's going on the list of stuff to do at next service.
    Jan 27 2013
    Quote Originally Posted by your daddy View Post
    No just PCV, CC about 7.5k ago, flaps intact but coded out to be safe, Intake plates removed when new intake manifold "spacer" was added.
    Veteran Member Three Rings dturn37's Avatar
    Jun 06 2014
    Chicago IL
    Wouldn't this throw a CEL or a fault code if it was faulty or going bad? I was under the impression the only real way to test for a vacuum leak or a faulty PCV valve was to run a smoke test. I've always had some suction when pulling the oil cap off at idle and it would struggle but never stall. Would this also hurt gas mileage too?
    CAPRISTO EXHAUST, KW V3 COILOVERS, EURO HEADLIGHTS, R8 ALCANTARA STEERING WHEEL.
    Feb 24 2010
    What was your before/after impression once PCV was replaced?
    Jan 27 2013
    Less smoke for sure, especially on cold-start. Within a month or so I will update on oil consumption, once I have a good point of comparison.
    Jan 27 2013
    So its been 2500k and would say that I am about 40% less in oil consumption based on my dip stick reading. So pretty happy to see that, and mine was pretty bad/failed. Just wanted to update upon check yesterday. I am never getting the oil dash warning but used to be a quite a bit lower on the dip stick at this point. Same oil, same driving style etc.
