Results 1 to 20 of 20
    Established Member Two Rings AshevilleS4's Avatar
    Dec 10 2015
    Melbourne Florida
    Looking for the best Boost Gauge.
    Looking for a bad ass boost gauge that will not only do the job but also look awesome. Classy. No euro-rice please
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Check out podi gauges then. I highly recommended their products.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    yeah podi
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    Podi is all good unless you plan on going over 30 psi. I have a Podi mechanical right now, but will be need to upgrade due to that limitation.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I like my AEM boost gauge the display is clear and the color sweep on the outside if the gauge works well.
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by mauromj View Post
    I agree with you. However, for the money [up to 30 psi] it's a very attractive and useful product.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    The one you can play snake on is teh awesomeness!!
    http://www.turbozentrum.de/fis-control/
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Nov 30 2010
    los angeles
    i rock an AEM. Really looks good.
    Defi, STE PPD, O.CT and the one mentioned by zillarob i think are pretty sick as well.
    Nov 16 2010
    WetSide, WA
    I have the PPD, O.CT, and tablet running visual logger (req psi, act psi, map, wbo2) when I am extra b5s4 paranoid
    They are all neato eye candy, but an analog needle sweeping is by far the easiest to keep track of out of the corner of your eye.
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    I had the awe on many of my s4s and it was fine then on the current one I went with podi digital and I like it.
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2000 S4 Nogaro Sedan Stage 3 WMS-Current
    2001 S4 Sil Sedan ASP Stage 3-SOLD
    2002 S4 Pearl White Avant Stock-SOLD
    2000 S4 Nogaro Sedan EPL Stage III-SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III-SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s-SOLD
    2001.5 Nogaro Sedan AWE Stage III-SOLD (x2)
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast-SOLD
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    If you want stealth...in da mirror
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by zillarob View Post
    Do you have any info on that tablet setup/mount anywhere? I was looking at doing something similar
    Also op, I have an awe boost gauge and Podi AFR and would recommend either. I picked them because they match the stock gauges pretty well (red with white needle).
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Nov 16 2010
    WetSide, WA
    Tablet is a dell venue 8 pro. Got it off ebay for $80 new/refurb. There were a bunch.
    http://www.ebay.com/itm/Dell-Venue-8...item41a496a747
    Mount is this jaws of death contraption that locks into (and prob destroys) the cd slot on the radio.
    I never use the cd player so dont care and havent tried it since. It might have lived through it though
    http://www.amazon.com/Ppyple-Univers.../dp/B00C31MF0W
    Could be a little sturdier, but works just fine.
    I use a vcds hex can cable to run vcds, nefmoto, and visual logger/me7logger.
    Setup google drive to sync everything to my pc inside so logs are waiting for me by the time I get inside.
    Have an acer iconia android tablet that I put there for waze and pandora on road trips.
    Drove halfway across the country and back like this last summer. Surprised I didnt get a big ass phone bill for tethering it to my iphone.
    I really dont know how I didnt get a nastygram for this
    Jul 04 2012
    Woodbridge, VA
    Stealth, replaces clock area, boost and A/F
    Veteran Member Three Rings Spoorguy's Avatar
    Mar 26 2015
    Rheinland Pfalz, Germany
    Quote Originally Posted by vavJETTAw36 View Post
    dang that's clean I haven't seen that yet. I have an AWE vent, I like it and it does the job. Very simple and it looks good and clean since it goes very well with he OEM red indication lights. I would love to go PODI though, I hear a lot of good things especially the digital aspect of it
    2002 B5 S4 (Sedan), GIAC stage 1, vinyl wrapped dark gloss grey - SOLD
    2010 B8 S4 Unitronic DP | AWE Tuning- Touring w/ Non Res DPs | Merc Racing HX | Airlift 3P - SOLD
    Feb 21 2012
    MB S55 - (607hp/671tq), Suzuki GSXR 1000
    Chico/CA
    I currently have the awe vent but will be moving to defi racer gauge (DF06503) as it goes to 30psi and I like how it looks when all power is turned off.
    2000 Laser Red Stage III+
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    innovate SCG-1 does boost( and boost control) and AFR.
    also does peak boost recall which is sweet
    has the ability to drop you down to wg pressure based on afr if you hook up the solenoid which is nice if you run meth and such
    I've had a podi stepper before this, it was nice but meh, it made noise and I dont think it was nearly as accurate as the innovate and didn't match perfectly .
    i will miss the warning feature which turns the gauge from white to red when you hit a set boost...still a nice unit
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Quote Originally Posted by Racin2redline View Post
    Damn, if this came in red i would be all over it.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    more infoooo
    White 07 Q7
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by audacity View Post
    more infoooo
    Made by zadatech in the UK. Just google them you'll find more info on it.
