Results 1 to 35 of 35
    Feb 20 2015
    Sydney
    Audi S5 error codes
    Hi guys
    After a full respray to the car and changed shocks and springs I am getting the below errors...
    Any help?
    Sunday,14,February,2016,16:54:34:14675
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 15.7.3.0
    Data version: 20151216
    Ross-Tech: Home
    VIN: WAUZZZ8T08A036984 License Plate:
    Mileage: 98840km-61416mi Repair Order:
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47 52
    53 55 56 77
    VIN: WAUZZZ8T08A036984 Mileage: 98840km-61416miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CAUB) Labels: None
    Part No SW: 8T0 907 560 EM HW: 8T0 907 560
    Component: V.7 JHM H10 0003
    Revision: 76H10---
    Coding: 01140003180F0120
    Shop #: WSC 06325 000 00000
    VCID: 0919A994A000117626-805C
    6 Faults Found:
    005489 - Left Engine Mount Solenoid Valve (N144)
    P1571 - 001 - Short to Plus
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 98733 km
    Time Indication: 0
    Date: 2016.01.25
    Time: 14:32:22
    Freeze Frame:
    RPM: 607 /min
    Load: 29.4 %
    Speed: 0.0 km/h
    Temperature: 93.0∞C
    Temperature: 57.0∞C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.716 V
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 001 - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98739 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 30.0∞C
    Temperature: 30.0∞C
    Voltage: 11.176 V
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98739 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 30.0∞C
    Temperature: 30.0∞C
    Voltage: 11.176 V
    P1653 - 008 - - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98739 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 30.0∞C
    Temperature: 30.0∞C
    Voltage: 11.176 V
    049472 - Body Control Module (Central Electric)
    U0140 - 008 - No Communications - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 98740 km
    Time Indication: 0
    Date: 2016.02.05
    Time: 11:44:54
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 28.0∞C
    Temperature: 29.0∞C
    Absolute Pres.: 1010.0 mbar
    Voltage: 9.017 V
    049508 - No Communications with HVAC Control Module (J301)
    U0164 - 008 - - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 98836 km
    Time Indication: 0
    Date: 2016.02.14
    Time: 12:46:06
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 48.0∞C
    Temperature: 45.0∞C
    Voltage: 11.049 V
    Readiness: 0100 0000
    Feb 20 2015
    Sydney
    I clear the codes and I rescan the car straight away and they are there
    I clear them again, took the car for a spin l rescan it and still there...
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    How old is your car and the battery in it? I wonder if those codes aren't thrown due to a weak battery, especially the intermittent ones.
    Guesses here:
    P1653 are you having parking brake issues? Washed and left the car immobile for a while?
    P1571 bare wire shorting?
    U0140 battery would be my guess
    Don't forget that certain cleared codes need a certain distance and or time traveled to reset. Case in point on my Touaregs a SRI reset needs at least 300 miles before the SRI interval displays anything after a reset.
    Measure the battery at rest and under load, especially the latter. If it falls below 9.5 volts when cranking it's time to change it.
    Keep us posted
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Feb 20 2015
    Sydney
    The car was sitting in the panel beater for 4 and a half months and wasnt moving much and battery was down to 25%. Also the parking brake switch was removed the change the center console. Maybe the battery is causing it? I ve noticed too that the volts are a bit low. P1571 the mount is gone and I have to change it.
    Quote Originally Posted by ak_siberian View Post
    Guesses here:
    Keep us posted
    siberian
    Jan 30 2015
    Given the above, the battery would be my first stop. Weak batteries cause all kinds of gremlins to surface.
    siberian
    Feb 20 2015
    Sydney
    Thanks buddy
    Should I recharge the battery or get a new one?
    I can't tell how old it is as I got the car used last year
    Jan 30 2015
    The battery should have a date on it but as I don't know how old your S5 is I don't know. But a new battery if it's older than 5 years is a good idea especially since it sat for 5 months. Keep us posted
    siberian
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Get a new battery.
    Feb 20 2015
    Sydney
    Thanks
    What do you recommend? Audi stealer battery or aftermarket?
    My Audi is 2008 model
    Thanks
    Jan 30 2015
    I would assume it's never been changed, so get a new one asap. If you can get a Varta Down Under that would be my choice and don't go to the stealer
    siberian
    Feb 20 2015
    Sydney
    Thanks buddy
    Any specific type?
    And I guess I have to do some coding after?
    Jan 30 2015
    Type? Whatever the Varta model is for your vehicle. No coding once you clear everything that's pending
    siberian
    Feb 20 2015
    Sydney
    Sorry my mistake I wasn't clear. I mean any specific varta model?
    I don't have to do any coding via vcds?
    Serial numbers etc?
    Thanks
    Jan 30 2015
    Whatever model works for your car. No coding necessary afaik
    siberian
    Feb 20 2015
    Sydney
    Thanks buddy
    I am between varta h3 and varta g14
    Do you or anyone else know which one will be suitable?
    G14 has some price difference from the H3
    Aug 07 2014
    Stanwood, Wa.
    Buy a GOOD battery, don,t skimp.
    Jan 30 2015
    Depends on what your CCA and AH requirements are and of course the size that will fit (and your wallet)
    siberian
    Jan 30 2015
    Quote Originally Posted by new2s5 View Post
    Which is why I suggested a Varta. Alas we can't find any in the US the closest is Interstate but maybe they sell Varta in Australia
    siberian
    Feb 20 2015
    Sydney
    Sorry H13 and G14 are both varta
    So I guess they are good? Both will fit on the car
    Mar 21 2015
    siberian
    I would if I were you
    http://www.audizine.com/forum/showth...-battery-S4-B8
    Jan 30 2015
    I stand corrected... sheesh... coding a new battery but I had to code a dimmable LED switch in the house who'd have thought you'd need to code a dimmer switch... Good catch 14S4GWM
    Jnin, pick the one that gives you the power you need since both fit.
    siberian
    Feb 20 2015
    Sydney
    Geez looks like there is a lot of conversation around batteries!
    Thanks guys
    Feb 20 2015
    Sydney
    One last thing
    Can I disconnect the battery and leave the car without power for a few minutes and then replace the battery to clear any codes or not?
    Will I need to do any adaptation after that to any of the systems in the car?
    Jan 30 2015
    No you can't clear codes in a ROM by cutting power.
    Now go buy a battery :)
    siberian
    Feb 20 2015
    Sydney
    Hahaha.
    I will :-)
    I am checking prices
    siberian
    Jan 30 2015
    Good, let us know if that fixes the issue(s)
    siberian
    Feb 20 2015
    Sydney
    Will do buddy
    Thanks a lot for your help!
    siberian
    Feb 20 2015
    Sydney
    Will do buddy
    siberian
    Junior Member Two Rings ryangphoto's Avatar
    Jan 07 2016
    Tampa, FL
    Did this fix it?
    Ryan G
    Mar 21 2015
    Quote Originally Posted by ryangphoto View Post
    Did this fix it?
    Ryan G
    It was just yesterday.
    Feb 20 2015
    Sydney
    No not yet
    I will go and get the battery on Saturday
    In the meantime I drove around on Sunday and battery went up to 35-40%. Left the car yesterday and this morning(here is Tuesday) I checked the battery and it was still 35-40% so I guess it holds charge. I didn't try to start it up though. I am thinking of removing the battery and charge it overnight.
    Will that affect any of the settings in the car like hidden menu etc? Or I will just lose time and date only?
    Did this fix it?
    Ryan G
    Feb 20 2015
    Sydney
    Well this car is driving me crazy
    First things first battery is from 2008 so needs to be replaced regardless
    Battery had 40% so I said lets scan the car and see if the errors are there
    Scanned and no errors were coming up!
    Anyway battery lasted for less than 10 mins and died. So I removed it from the car and I jump started it. All good I didn't lose anything else rather than time,date. Then I rescanned it and other than the power supply terminal p1602 error which is because I removed the battery
    I ve got a 01206 signal for duration of ignition off time on the hvac...
    Feb 20 2015
    Sydney
    Any ideas or will it go away by itself like the others?
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    You need to replace the battery before you do anymore scans! Constantly scanning a car with a dead battery is pointless. Fix the problem before you try rectifying faults.
    Feb 20 2015
    Sydney
    Yeah I know
    I just wanted to see what errors I will get. That error must go away by it self from what I have read on the net. Its a common issue after battery replacement
    Quote Originally Posted by JamesRS5 View Post
