Results 1 to 7 of 7
    Established Member Two Rings valida4's Avatar
    Mar 03 2010
    New York, NY
    01134 - Alarm Horn (H12) -- Where is this located?
    So I've been living without the chirp/beep sound (the one you hear when you lock the car) for almost a year now. I scanned for fault codes and got the following:
    Code:
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 2
                        Fault Frequency: 81
                        Reset counter: 166
                        Mileage: 52879 km
                        Time Indication: 0
                        Date: 2015.03.30
                        Time: 09:16:42
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 166
                        Mileage: 52879 km
                        Time Indication: 0
                        Date: 2015.03.30
                        Time: 17:00:14
    I remembered seeing somewhere in the forums that it may be caused by a faulty door actuator that wouldn't lock a particular door but I've checked and all my doors lock fine, including the trunk and the gas. I was thinking of buying a replacement Alarm Horn but I cant seem to find out where this is located in the car?
    Anyone else replaced their Alarm Horn?
    2010 Phantom Black Pearl A4 2.0 6MT :: Premium+ :: Nav :: Sports Package :: H&R Spacers :: S-Line Stone Guards :: APR Stage 2+ :: Podi :: aFe
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    Might not be the same but on mk5 it's in the passenger side Fender liner. Just remove the liner at the top and its tucked under fender
    Mar 03 2010
    New York, NY
    So I bought a used part off ebay to replace my original alarm horn siren with matching part number:
    The part is actually located in the engine bay, underneath the cabin air intake / plenum cover attached to a bracket:
    Removing the old item took a little bit of wiggling around but it didnt' take long with a simple wrench. The old alarm siren had some stain coming out of the middle, by the bolt. However, after connecting the new part the alarm chirp still didn't work. Lights flashed normally, just no sound from the alarm. I considered that the new part just may be faulty as well, but with no way to test it I couldn't be sure. I checked all the fuses--both sides and the trunk and everything looked fine. Cleared all DTCs and re-scanned the car, this time with only 1 fault instead of 2:
    Code:
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0326
       Revision: 00002001    Serial number: 0123694821
       Coding: 0106063A007A444400B0013200000000
       Shop #: WSC 02391 823 56573
       VCID: 78F4EABE34895DDC
       Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
    1 Fault Found
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 74
                        Mileage: 65094 km
                        Time Indication: 0
                        Date: 2016.02.20
                        Time: 14:45:51
    One thing I did notice though is that the drain was blocked and totally covered with leaves. One assumption led me to think that water had maybe accumulated and destroyed both the siren and the wiring harness. Again, I have no way of testing this. The day the alarm chirp died it had been raining pretty hard. Maybe the wires got corroded when water built up.
    Another theory is maybe it had something to do with a PODI boost gauge install the week before it died. Had it done at a local reputable shop that also did all the APR flashes for the car. I noticed that the gauge was tapped into Conv. Electronics in the driver side fusebox which is maybe where the alarm was also connected. I couldn't find any reference in the manual as to which fuse the siren was connected to so again I can't be sure.
    Running out of things to check and might just have to bring it to a shop/audi dealer to get it looked at.
    Feb 27 2017
    New York -- Puerto Rico
    Quote Originally Posted by valida4 View Post
    Code:
    1 Fault Found
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 74
                        Mileage: 65094 km
                        Time Indication: 0
                        Date: 2016.02.20
                        Time: 14:45:51
    Hi there,
    I know the post was from a while back. I currently bought an old model b8 a4 and I'm facing the same issue you had good Sir. The car lost the beep sound and the sirens won't work either. I also thought replacing the alarm would fix the issue but as soon as switch the to the alarm I bought on eBay it also didn't work.
    After all this year's were you able to find a solution?
    Thank you in advance
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    OP......For what it's worth.... you have a far bigger problem. That's the filthiest engine bay I've seen on these forums. All that filth is interfering with your alarm horn.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Feb 27 2017
    Quote Originally Posted by Crucible35 View Post
    Funny thing is, this is exatcly how I also got it from the guy who sold it to me :(
    Senior Member Three Rings slacktide's Avatar
    Mar 01 2015
    Seattle WA
    So, sorry for the the necropost but here is the deal - These alarms have a built in 7.2v Ni-Mh battery so that if the thieves disconnect the main car battery, the alarm will continue to sound. The problem is that eventually the built-in Ni-Mh battery fails, explodes and spews corrosive electrolyte all over the PCB. Once this happens the alarm is really not repairable. It seems like this will eventually happen to ALL of these alarms past the 10 year mark or so - I shuffled through a bunch at a parts yard before I found one that was working. If you catch it while it is still working, you can split the case and do a battery-ectomy, or if you really want to, connect a new externally mounted Ni-Mh battery. I used a hacksaw to make a shallow cut around the perimeter of the alarm casing at the seam where it was originally glued together. I'm thinking about trying a generic 7.2v one I found on ebay, soldering it in with the wire leads and velcroing it outside the case.
    Link to pics: https://www.a2oc.net/community/index...acement.35824/ Mine was way worse than this inside.
    1993 Audi 90 Quattro 2.8 5MT - Sold with 245,000 miles on it.
    2002 Audi A4 Avant Quattro 3.0 6MT - Retired commuter, Dog Car, Costco runner, Snowmobile.
    2014 Audi S4 Quattro Sport Diff 6MT - Daily Driver. CR-15, Chipwerke, minor cosmetic mods. Eventually I'll get around to the audio build.
