Results 1 to 14 of 14
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Question Schwaben Scan Tool from ECS
    Curious to see if anyone has used this tool? Seems like a nicely priced option to Ross-Tech.
    https://www.ecstuning.com/Audi-B8_S4....0T/ES2996394/
    2016 S6
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    I don't think you can do any coding with it. Spend the extra $ and get a Ross-Tech. Better investment.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by new2s5 View Post
    There is one user review on ECS implying that it can be used for at least some VCDS tweaks in place of the RossTech cable, but it's not a positive confirmation that it can do 100% of what the RossTech VCDS software allows.
    SOLD 2015 Daytona Gray S4
    Active Member Two Rings JUICE A6's Avatar
    Mar 04 2015
    DETROIT MI
    So can you do the same shit good as the Ross teck as far as add mods onto your sweet ass ride. And as far as the price difference is not really that far off
    Sent from my LGMS395 using Tapatalk
    AKA mccoy540i
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    I was curious also about this VAG took as well.
    Sent from my mind
    Apr 05 2005
    Tampa, FL
    One of the bullet points is: Performs special functions, coding, security access
    That's why I am curious?!?! Hoping someone from ECS can chime in?
    Review:
    Including Parking Brake release for Changing Brake pads,Audi pads thickness , and adaptions that allow you to tweak your car for making the windows come down with the FOB Key. There is many more tweaks and things to do with this scanner Recommend this to people who don't want to pay 400$ for Ross-tech Wire. It doesn't require a computer and works excellent.
    2016 S6
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    I own one. Used it this past weekend, for the first time, to do a break job on my roommate's B8 A4 Avant. Worked wonderfully! I don't own a laptop, nor do I want to, so this was a great option for me.
    I'm also very curious if it does some coding. I did dig around a little in it and it appears there is some potential, but I didn't want to mess anything up without doing more research.
    Sep 15 2013
    MD
    *tool...geez
    Senior Member Three Rings usmc1994's Avatar
    Nov 11 2013
    2014 Audi S4, 2014 Audi A4, 2005 1/2 A4
    Home
    Just ordered mine yesterday along with led signal bulbs and reverse light bulbs
    Apr Stage 2, Stasis touring suspension, 20x9 Stance Wheels SC-8 with Michelin Pilots, AWE exhaust 102mm tips Vag Com, Alu Kreuz, Awe Boost Gauge
    Feb 05 2007
    Portland, OR
    Got in it today with my S4. Printed off the RossTech VCDS instructions and thought I'd see what I could do. Looks like I can get to where I need to go, but the instructions for the VCDS are a little different, like the number and functions relation (VCDS = 7. Coding vs Schwaben= 9 Coding). Also, once I got to the actual coding part the VCDS instructions say change byte 2 bit 2 to 0, for example, and I don't know what that means or which value to change in the Schwaben. It show a long list of numbers and letter with a few spaces in between it, I have no knowledge on coding or software. I'm wondering if it's possible to translate the VCDS instructions for the actual coding portion for the Schwaben?
    Mar 21 2015
    Or you can return it and get a Ross Tech cable like everybody else has and code everything properly with the help of 1 thread.
    Feb 05 2007
    Portland, OR
    Says the guy with Carista. I'm sure they heard it all when they started. "Just go with Ross-Tech. You're an idiot..."
    Feb 05 2007
    Portland, OR
    The Schwaben Scan Tool will do coding. After talking with a buddy who does coding and software stuff for a living I managed to translate the Ross-Tech/VCDS instructions. Started off with a simple one and turned off the warnings for the Nav while driving. Worked! More to come.
    Active Member Two Rings glaciermetallic's Avatar
    Dec 06 2016
    Colorado
    I messed with mine last night for about two hours. Using the sticky on long coding, every single one I tried I would go to save changes and it would pop a screen up listing "code rejected". I tried the remote operation of the windows with the key fob, disabling the "lights are on" warning, and the seatbelt chime. Each time I tried it wouldn't work. This is my first time messing with long coding, so I'm not sure if I was doing something wrong. I should have researched more and just done the Rosstech with being such a noob at it.
