Results 1 to 19 of 19
    Sep 14 2005
    NC
    Anyone ever tried Porsche acid green...
    For brake caliper colors??
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    No, but from what I've seen they're quite trippy .
    Looks amazing though
    "Beep beeeep bloop boop" - R2D2
    Sep 14 2005
    NC
    Yeah someone has them on a cayenne s where I work out at and they look like a cool color. My car is silver so I think it's something different than traditional red or black
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    In before bobkat notices this thread
    2000 S4 - silver- RS4 OEM widebody racecar
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    Nope.
    not in Carbon Fiber
    not on badges
    not even in motion.
    Aug 09 2012
    2013 S4 phantom pearl
    IL
    Quote Originally Posted by bobkatkat View Post
    Nope.
    not in Carbon Fiber
    not on badges
    not even in motion.
    Sep 14 2005
    NC
    Awesome look. Did you have a shop do the color??
    Jun 07 2012
    Quote Originally Posted by ajee622 View Post
    When I did mine the 918 concept car just came out so there was no paint code for the Acid green that is on the real 918 and the Cayenne Hybrids calipers. There have been many Porsche colors that use the name "Acid Green" but at the time none were that green. Working with the printouts of the 918 and the paint supplier we just mixed and tweaked until i was happy.
    I think it is very close but hopefully there is a paint code now just in case I have to redo something.
    Sep 14 2005
    NC
    How much did they charge for it??
    Jun 07 2012
    For the paint? Standard high end automotive/industrial coating prices.
    Veteran Member Three Rings lo-lyfe's Avatar
    Mar 27 2012
    2006 tuned & lifted F350 6.0 Powerstroke, 1990 built Ford Bronco 5.0l 302, Built Stage 3 b5s4
    out on the farm, in the Mitten
    [/QUOTE]
    Less play more fabrication, please ;-)
    Stay tuned...
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    lol sweet vid.
    excellent showcase of the diff issue too. You notice how the car puts too much power to the fronts preventing you from turning in again without first correcting the slide? like after you've pitched it, you're in the power, you stop countersteering and actually steer into the turn, but the car refuses to point in further (without e-brake), and instead the car straightens out? See the 5 second mark of the video -- you can see it at multiple points but that's the first time and it's pretty obvious. Drives me nuts. Anybody tried a fix? realizing it's tranny swap status most likely. Most of the high performance AWD sports cars don't have this issue, and i'm 99.9% sure it's the early gen of torsen center diff causing it.
    Jul 28 2015
    Rochester, NY
    Great Video Bobkat
    Established Member Two Rings ur0drivr's Avatar
    Jun 11 2010
    Calgary, AB
    Quote Originally Posted by james 408 View Post
    lol sweet vid.
    Can't hope for any traction the way the lake was on that day...So I wouldn't judge the diff issue by using this Vid.
    And I've said it before Bob, love the video ;)
    Rod
    Driving
    2001.5 Audi S4 - Santorin Blue STAGE II+ JFonz Tuned
    Jun 07 2012
    lol sweet vid.
    Ya I understand what you are trying to get out of this video but this would not be a good example. I was out there with a jeep grand Cherokee and a e30 btw. The jeep could get around the track but if it missed a corner it was gone sliding 100-150 yards. The e30 could not run the track at all, 100% understeer 100% of the time. There is no traction anywhere other that a slight bit more where the track gets chewed up by cars with studded tires. You can stay on line if you are not trying to hoon it for the camera like I was. The only way to get around an ice track like this is to tap the e-brake or even drag it a bit. I can tell the rear is trying harder than the front by the sound and the spray. Keep in mid you have to have some traction to have a difference in traction. I will post some video of my jeep with both front and rear diffs locked trying to get going after a spin. Like a baby dear on roller-skates.
    You do bring up some good points and the glair ice may be a good testing ground to see just what is happening when. Could GPS a track then put some gopros on all the corners over lay accelerometer data.
    Jun 07 2012
    Quattro rules!! Jeep/ baby deer on roller-skates video
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    More Porsche Acid Green
    Nov 04 2013
    Palo Alto, CA
    apologies for the thread-jack attempt. love the color, again would recommend choosing 1 highlight color for the whole car though.
    ice is actually a perfect situation to test it. Ice, rain, or dry tarmac, the same effect occurs while drifting on all surfaces as the 2:1 or 4:1 ratios are not surpassed when all 4 are sliding. first 5 seconds of the jeep video, you're turned into the turn (opposite countersteering), the car continues to point. The audi won't do that, the circle will widen and the car will straighten (can usually get 1 full donut before it pulls straight again). This has been bugging me forever. not really a track issue most of the time, except when off throttle steps it out, then you countersteer too much/too early, and you try to steer the car back in. only way to prevent snap understeer in this situation is with an ebrake or to completely off-throttle and hope the wheels stop spinning in time. You can avoid this by just not Fing up the countersteer, but fact is, you should be able to adjust this dynamically throughout the corner.
    I've been wanting to hoon my buddies b7 rs4 to compare the 40-60 diff with our 50-50 default, but he thinks hooning is crazy and is akin to trying to bed his daughter. I've tried both evos and stis, neither has the problem. but like subaru foresters and the like have the same issue. it seems to be the performance center diffs.
    I've got tons of experience drifting the s4, you can manage around it by effectively overrotating the car before you try to drift it, and just not countersteering much and letting the power correct it. But it's not very dynamic and requires you to guess the right angle/throttle timing (much like trying to 4-wheel slide a FWD car). The e-brake of course works as long as you're not buried in abs (complaint #2, but lets leave abs out of this for the time being if we can).
    quattros great, but there's a reason the r8 uses a much different AWD system than our cars. Audi has continually modified the differential system with every new model since the b5.
    Jun 07 2012
    Yes sorry about hijacking the thread.
    One color is a must with these bright colors. Red calipers match the red badging. When I first did the Acid green it looked terrible with the red emblems. Exaggerated on a side view because I have the OEM DTM badges. I went matching acid green on everything an it looks way better.
    Side note maybe a instructional thread on how to drift the B5??
