Results 1 to 7 of 7
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    Audi A4 B8 Sound System Upgrade to B&O?
    Im not sure if this topic has been covered before, there were some other forums that talked about a "sound system" but I don't want to go with an aftermarket upgrade.
    So im looking to upgrade my Subwoofer (Rear deck) and Amplifier with B&O quality parts. Buy the amp used from an S4 and such and then buy the B&O subwoofer new.
    Questions: Did anyone do this upgrade? Does the B&O Amp connect straight to the basic (Non B&O amp)? I really don't want to spend $600 bucks or so and then find out that it doesn't even hook up.
    Thanks.
    Jul 16 2008
    Finland
    Not possible without retrofitting the whole system. The B&O uses 14 speakers instead of 10 and the impedances are different. There's also a mic in the dome light for active volume control, which the ASS system doesn't have.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    I wonder if it's possible to replace the OE sub with an aftermarket one (yes I know you said you didn't want to go that route) but in the stock location for a cleaner look. I've seen write ups for B&O sub replacement but never the standard system.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    May 22 2013
    Southern ME
    Quote Originally Posted by Project Quattro View Post
    At least a few in the B&O Sub upgrade thread did it to non-B&O systems. It needs to be wired differently for the different impedance but can still be done. I have one in hand to add to my non-B&O once the weather gets nicer.
    Feb 13 2004
    Silicon Valley, CA
    Skip B&O, its junk. Quite a few of us with the 2011 and older gutted that system.
    See my build thread. Corey_Can is another who gutted and has a good build thread on it.
    Kevin - Moderator, Audizine
    Mar 15 2012
    Quote Originally Posted by TDIaholic View Post
    That sucks, i had in mind to keep the stock system and just do a better oem amp, in this case B&O amp. In my B5 S4 i upgraded the stock amp to an A8 D3 amp and it helped alot, much louder and cleaner sound.
    Now im wondering if its possible to put the B&O sub into the basic sub? Just a little more bass.
    Jul 16 2008
    Finland
    There's really no point as the difference is minimal and the B&O sub is 8Ohm instead of 2Ohm in the ASS. Your best bet is to go for a nice, sensitive aftermarket sub in the stock location. Check the thread linked above, it's been discussed to death before.
