Results 1 to 30 of 30
    Active Member Two Rings mfallon's Avatar
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    B6 A4 1.8t engine swap question
    I have a 2005 Audi A4 Quattro Avant. It has a blown 1.8t AMB motor in it. I found a wrecked 2001 Audi A4 Quattro with an AWM motor in it that runs fine. My question is this: Can I swap a B5 AWM 1.8t into my B6 A4?
    I was hoping to just swap the motor, wiring harness, and ecu out of the wrecked B5 and put it into my car. Would this work? My car has a 6spd tranny in it and the B5 has a 5 spd tranny. Would I need to swap trannys as well? Or could I get by with just the engine, harness, and ecu?
    Also, is there anything else I should be aware of before I check out the B5 A4 today?
    Jun 08 2008
    Calgary AB Canada
    Why would you want to swap all of the B5 wiring and electrical? Just swap the motor and be done with it. Keep all of the B6 electrical components. 6 speed can stay.
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Well I was having electrical issues previous to the engine blowing. And I have just confirmed that it has a bad ecu. So just to be safe I was thinking about swapping everything...
    So could I just swap the engine and ecu and keep my harness? I'm not sure if everything is plug n play between the two motors?
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Also, the b5 AWM ecu has APR stage 1 software on it. That wouldn't affect anything being put into my car with the 6spd tranny would it? Or anything else for that matter?
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    ECU will likely not be able to recognize a 6 speed manual transmission as the older 1.8T engine never had one. You'll also have immobilizer issues. There's plenty of used 1.8T AMB engines, wire harnesses, and ECUs out there. For ECUs, you would want to make sure the ECU is the same year as your car for easier integration. I would skip the B5.
    USP CLUB MEMBER #34
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Thanks for the info! Can anyone verify this?
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    I am pretty sure an 01 AWM harness and an AMB harness are exactly the same assuming they are both manual trans. Like said above swapping the ecu will be difficult because of the immobilizer. Your best bet would be to use the AMB ecu and the AMB harness and swap in the AWM engine.
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Okay, I think after getting all the feedback I will just hold out and try and find a b6 to swap from.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Why would you swap everything? Just swap the motor and be done.
    Harnesses are different- b5's use tranny for speedo, b6's use wheels.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Is that the only difference?
    So I would be able to use the wheels still for my sensor and just wouldn't plug into the speed sensor on the tranny correct?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by mfallon View Post
    lol, b6's use the hub at the wheels for speedo, not some special wheel contraption thing.
    2000 S4- Working?
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    So nothing would change for plugging into my wheels for speedo. What other differences are there? Are all of the connectors going to match up with the b5 motor? Anything I would have to do to make this work? Motor is going to run fine off of my b6 ecu?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Just put the motor in. The long block only. You will be fine.
    2000 S4- Working?
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Have you done a similar swap?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    No, I haven't.
    But one thing no one has mentioned yet is if your car is a manual, the motor has to come from a manual.
    2000 S4- Working?
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Yes I am aware of that. Mine is a 6spd manual transmission. The b5 I'm looking at is a 5spd manual transmission.
    And I'm only asking if you've done a swap like this is because I'm still making payments on mine with the blown motor . So money is a little tight and I want to be 100% sure it will work and that I'm aware of everything before I spend any money..
    Has anyone actually done this swap???
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It isn't a "swap." It is motor for motor.
    2000 S4- Working?
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Technically I am swapping one motor for another...
    But I'm not here to argue symantics. Just looking for answers.
    Jun 08 2008
    Calgary AB Canada
    Any 06a 1.8t long block will fit, whether it's from a Jetta, golf, Passat or a4. Use all the original accessories. Ecu doesn't care about 5 vs 6 speed at long as they're both from a manual car.
    I swapped an 06a shortock from a Jetta into my car and mated it to a AMB head from a b5 a4. Works just fine.
    Stock. For now...
    Aug 26 2005
    The ECU is coded for manual trans, there is no coding difference between 5 or 6 speed trans. 6 speed trans are installed in originally 5 speed cars using the same ECU. Don't try and use a B5 engine harness in a B6. Just use the existing B6 harness. A B5 engine will run fine on the B6 ECU.
    Vorsprung durch Technik
    Jul 28 2015
    2004 Pontiac GTO
    Cleveland, OH
    Thanks, that info is most helpful. I'll think if over and let you know which route I go.
    Aug 26 2005
    The B5 AWM ECU is irrelevant since you must use the B6 8E0 ECU, the B5 8D0 ECU cannot be used in your B6.
    If you need to obtain a used replacement ECU, PN 8E0 919 518 AF or AK, You can use an ECU from a Manual Trans A4 or an Auto trans A4, if an Auto trans, the ECU must be recoded to manual trans.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Just read through this and NO you cant use the B5 harness and ECU. If you need those components I have both for sale.
    Sent from my LGL33L using Tapatalk
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Jan 24 2010
    Paramus,NJ USA
    Ok so since I'm in the middle of the very same project let me give you some tips..The awm engine I am using came out of a automatic Passat.So depending no on where you got your engine from here are the differences.Intake and vacuum hoses under the intake are layed out differently so you either cap the unused hoses or swap over the intake with all the hoses,fuel rail and so on from the Amb that's what I did if you do not the air intake tem sensor is different FYI.Crank pulleys are different swap right over.oil pans are different,not sure how n the oil pump pick up I didn't get that far.Also awm the thermostat is different. And the block is not machined to accept the map controlled thermostat you will need to carefully dremel out some material on the block or modify the thermostat housing The awm doesnt have a j plug.Swap it over.Coolant hoses and lines use from Amb.If your awm came from an automatic and your car is stick you will need to install a bearing in the crank.Awm valve cover has 1 extra vent port at the rear this you can plug or swap over the fitting from a Amb valve cover.accessories bracket needs to be swapped over from Amb.Everythng else is the same.I still need t check if I need to swap over oil pump pickup or not.Hope this helps.
    Ziddy Autowerks
    Jan 24 2010
    Paramus,NJ USA
    engine does not have to come from a manual car this was only true for AEB engine code.
    Quote Originally Posted by redline380 View Post
    No, I haven't.
    Ziddy Autowerks
    Jan 12 2016
    del
    I have an amb from a b6 for sale. It's still in car but I'm going to pull it once I get a sale. Pm me if you are interested. I'm in Delaware.
    Cris
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    I'm curious how the MAP controlled thermostat will be addressed?
    The opening in the AWM block has to be modified to accommodate the depth/diameter of the AMB thermostat. I would like to see this, I have a couple 06A blocks floating around that id like to repurpose for my B6.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by csosnowski View Post
    I didnt modify mine. Just snugged the thermostat up until it seated. There was about 1/8" gap between the housing and block. Never had issues. Be sure to use loctite
    Stock. For now...
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Quote Originally Posted by onceover View Post
    That's the stuff I like to hear!
    Junior Member Two Rings
    Aug 17 2017
    Two 99 A4 1.8t manual conversion in progress
    Dayton NV
    Post Complete it?
    Just wondering if you ever completed this swap and have any notes or issues with it if it was completed?
