Results 1 to 31 of 31
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    S4 vs A4 Clutch Differences
    Perhaps its information overload, or maybe is the nyquil. What is the difference between the s4 and a4 clutches. To be more direct, will the s4 clutch options fit the a4. I feel like Im missing something. On certain sites and places they are listed for both cars, while on other sites they only offer s4 options. I think I read before that the A4 just has to upgrade to an S4 Flywheel to use an S4 clutch. Anyone confirm or clarify that? Seeing as everyone is looking for clutches right now..
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    I've been looking for the same answer for months, but haven't found the specs for the diameter and such. The FW looks identical on both and the transmission seems to be the same, but I never found anything concrete.
    Apr 02 2015
    Rochester NY
    Quote Originally Posted by Dub_prime View Post
    Thats basically where Im at I know the A4 has a 240mm clutch but whether the s4 does I have no idea. I do know of people running large stage clutches for example APR I just dont know the spec differences. For example Arin posted what their demo car is running for Clutch components LWFW/Disc/PP and the part numbers. When I find the corresponding items on say ECS the part numbers are slightly different. I dont know if thats because of a difference in transmission between both cars, or just ECS. Im 98% sure If I buy an S4 FW the clutch works. Just not sure if I say, kept the a4 fw that a s4 clutch would mate. Just looking for clarity before I get balls deep into the job just to find holes that dont align or something.
    Apr 02 2015
    Rochester NY
    After going to Clutch Masters site directly. There does appear to be a large difference in S4 and A4 Flywheel. Most notably a weight difference of 12lbs between the two. However CM does have several options for our car specifically. While this doesn't answer my question directly it does offer options I hadn't seen yet. Although the s4 has way more options for comparison sake.
    Aug 28 2012
    NSW Australia
    A quick check on the Sachs website shows the same Audi part numbers for S4 clutch and A4 clutch
    http://www.sachsperformance.com/Sach...5067_5136.html
    http://www.sachsperformance.com/Sach...5067_5573.html
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    The plot thickens
    Sent from ....
    B8.5 S-line prestige
    #fourringarmy
    Aug 28 2012
    NSW Australia
    I've got the Sachs performance clutch in with a LUK dual mass flywheel. No fitting issues. Feels just like stock but with 530nm of clamping.
    Aug 28 2012
    NSW Australia
    My bad the only part number that matches between S4 and A4 is the throw out bearing
    Apr 02 2015
    Rochester NY
    Quote Originally Posted by roxta View Post
    I know they have a different flywheel and weight, also different clutch diameter. Im not sure exactly what size the S4 is, but know the A4 is 240mm. What I'm more curious about is whether the S4 Flywheel and Clutch will line up on the A4. I believe yes, but... Im beginning to doubt it.
    Feb 26 2008
    none
    BALTIMORE
    All made for the a4 right?
    Sent from ....
    #fourringarmy
    Sep 10 2012
    Bham AL
    Maybe the whole S4 assembly would work?
    Apr 02 2015
    Rochester NY
    This is what I believe to be true. The only differences Im aware of in the actual transmission is slightly different gearing naturally, but I believe the housing and hardware to be the same. To note, I have never seen them side by side. That was the literal point of this thread, has anyone put an s4 clutch in their car..
    Apr 02 2015
    Rochester NY
    Im going to go out on a limb after a few days of scouring and comparing and say it cannot be done... Or more so doesn't need to be done. There is certainly less clutch options for the A4 and Flywheel, but there is enough to provide a good comparison and value. So in short, it may be able to be done but unless you get a good deal on a used s4 clutch or second hand, I cannot see a reason to do it. All options I have seen are comparable in clamping force and flywheel options appear a bit lighter (I assume because its smaller only) although I think a bit of weight would make starts a bit easier on this smaller engine.
    Aug 28 2012
    NSW Australia
    Quote Originally Posted by Mr.Audi View Post
    Sent from ....
    Yes that's correct
    May 07 2014
    Yes that's correct
    Do you have links to what exactly you ordered?
    2010 A4 2.0t quattro 6mt
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    That's 390 Ft Ibs, are you going to Stage III and if so do you think that will be enough?
    B8.5 S4 DSG | APR UC/TCU | APR Intercooler System | APR Intake | Bilstein PSS10s | Ethanol Sensor
    Aug 28 2012
    NSW Australia
    Quote Originally Posted by zokissima View Post
    One clutch is for the LUK flywheel and the other is for the Sachs flywheel. Though when I quizzed them they said they only make the one for LUK.
    Aug 28 2012
    NSW Australia
    Quote Originally Posted by englishbay View Post
    I'm waiting to see pricing on the EFR kit and a torque curve. If there is a big gap below 3000rpm in torque then I'm out and will go with K04. I don't want lag. Since there is no info on torque yet for stage 3 I don't know if 530nm is enough. But the clutch feels just like stock no extra effort in engagement which is what I want in a daily.
    Veteran Member Four Rings bermudakid's Avatar
    Nov 02 2010
    Santa Barbara
    In for an answer, I asked last near and never found out.
    2011 A4 6MT - APR Stage II - Bang & Olufsen Aftermarket Sub - Eurocode HFC + Alu Kruez - 034 Trans Mount - S4 Brakes
    "Forget the "line" Get the real S"
    Instagram TPR.Visuals
    B6 Totalled - RIP
    Aug 28 2012
    NSW Australia
    Also I couldn't wait any longer to find out if 530nm is enough as I had to pull the trigger on a rebuild and to save on labour I changed the flywheel and clutch at the same time.
    Oct 26 2012
    St. Louis, MO
    @ParadigmTony
    What flywheel options have you found? Besides the stock dual mass, I can only find JHM, ECS, Eurocode and Clutch Masters. All of them are near $1000, which sucks because you could get a full B7 stage 2 clutch and lightweight flywheel kit for $980.
    Right now, I am leaning towards the ECS flywheel to match up with the Spec Stage 2+ clutch kit. The Spec kit arrives tomorrow and I only today realized that our flywheels are not able to be resurfaced.
    Apr 02 2015
    Rochester NY
    That is pretty much the definitive list. Although Southbend has one as well. The thing with a LWFW is they are typically designed to be paired with their configuration. Clamping force, friction surface, mass etc. The ECS is interestingly just hey here ya go. To be honest Spec is a shit shit company. Although some have had good luck with them, I never have, and that rings true for most everyone I know. There figures or specs are almost always at least 10-15% off minimum. Likely not a problem if you're only running K04 etc. The stock dual mass cannot be resurfaced, but adversely claims to not need to be. (somehow) In theory they advocate replacing it with a new clutch, or as most dealers do, just put a new clutch on it.. Our clutch kits are ridiculously audi taxed. Its unreal. I had an exedy triple plate on my evo that was cheaper than my stage 3 sprung hub single plate EC Clutch.. Im actually really interested in the Southbend kit. But no matter what one you decide you're talking a max of a couple hundred bucks difference. I wish someone would just come out and blow the competitive market out.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by ParadigmTony View Post
    poop.
    I've seen a lot of mixed comments on replacing the flywheel or not. If reusing the stock one is fine, I'd rather save the $1000.
    Apr 02 2015
    Rochester NY
    Quote Originally Posted by blbroo View Post
    poop.
    Its a 50/50 chance really. The labor is so intensive that it only really makes sense to do it all and not risk it. However its another 1000 damn dollars! I know people replace without resurface. I know my dealer doesn't resurface or replace the FW so I can only assume. However they are putting a stock clutch surface on a stock FW. Ehhh I dont know.
    Oct 26 2012
    St. Louis, MO
    I'm just going to replace the stock dual mass LUK. DMF141
    It's $589 on rockauto, and around $1000 on most of the audi part websites. Audi tax shit.
    Senior Member Two Rings jorte014's Avatar
    Apr 16 2013
    Mercedes-Benz ML 350
    Coral Springs, Florida
    What's the consensus on Eurocode? I'm looking to replace my shot to sh*t clutch and flywheel with this kit. Those torque capacity numbers seem a little too high to be true?.
    http://www.uspmotorsports.com/Audi--...L-Stage-2.html
    2014 S4 6MT - Milano Red | Premium Plus | Black Optic | Bang&Olufsen
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by jorte014 View Post
    From what I have read, the life on the Eurocode clutch is REALLY short.
    Apr 16 2013
    Seriously?? Foo. What about southbend? I guess i'll just probably end up doing what you're doing if that's the case. Get a southbend or clutchmasters and just get an OEM flywheel.
    Oct 26 2012
    St. Louis, MO
    I hear nothing but good things about South Bend. After learning more about single mass clutches, I don't want to deal with the chatter and extra touchiness.
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Someone call Four Season Tuning... they will give a definitive answer to this question.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
