Results 1 to 17 of 17
    Jun 15 2014
    Redondo Beach
    Audi B7 A4 S-line Tiptronic Acceleration mis-shifting, not shifting correctly HELP!
    So just yesterday I was driving my car and everything was great, then I decided to basically gun it off of a red light and once my car got to 2-3rd gear weird shit started to happen.
    It would like redline then not shift, as if the clutch was disengaged then not allowing the gears to shift. My car made a couple of harsh clunks and I slowed down then it shifted correctly.
    I can make the problem happen at anytime by flooring it, then once my RMPs get about 3500 my car stops accelerating but my engine is still revving up. I am not sure what the problem is, It sounds like from other posts I've read it might be a TC or PCV but I'm not sure, I am well out of warranty and I really want to try and rule out all options before going to Audi. My RPMs do jump slightly when cruising like motioned in this post http://www.audizine.com/forum/showth...w-speeds/page4
    Any help would be greatly appreciated I hope its nothing too serious. If it is I'm selling this damn thing.
    Oct 24 2015
    Perth, WA
    Possible torque converter module. Do you get any codes?
    My respray thread
    Jun 15 2014
    Redondo Beach
    Nope, No codes and no warning lights on my dash board...
    Oct 24 2015
    Perth, WA
    Thats strange. Any sign of leaks around the CVT housing.
    My respray thread
    Jun 15 2014
    Redondo Beach
    Not that I can tell, I'm looking at taking my car into the dealership later this week to see what they say... I can't figure out whats wrong for the life of me. All of my builds have been recently changed so I'm not sure where this issue is coming from.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Okedokey View Post
    You sure he has a CVT or a regular 6 spd auto tip
    Apr 24 2014
    CO
    Quote Originally Posted by audihur View Post
    good luck. no one can troubleshoot these transmissions. I suspect the dealer will just tell you to rebuild it for a huge amount of cash.
    Jun 15 2014
    Redondo Beach
    I have tip tropic with paddle shifters.
    Update: there is now a solid check engine light now and I don't have my vag com with me to check the error codes.
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Personally I would take it to a good transmission shop. Never hurts to have the fluid changed. Most dealers and even indy shops know little to nothing about transmissions. Find a dedicated transmission shop who is familiar with the ZF-6HP.
    Dec 14 2011
    Chagrin Falls, Ohio
    Is your car Quattro?
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by audihere06 View Post
    Yup. Most transmissions are 'plug and play' and all they have to do is drop it in, reconnect. Dealers get their 'rebuilt' transmissions from various sources. Again, O.P., is your car Front-Trak or Quattro, and what year and miles???
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Jun 15 2014
    Redondo Beach
    It is Quattro, and it has 117000 miles and from 06'
    Oct 09 2007
    Miele S7
    If your transmission drives fine under normal acceleration with no slippage, my bet would be the Torque Converter since flooring it would produce torque. Common issue with Tips if read up on it here.
    Jun 15 2014
    Redondo Beach
    It doesn't drive fine under normal acceleration that's the bugger, the issue is only further confounded when I floor it. But even when I accelerate normally it shifts very strangely.
    Nov 11 2013
    Charlotte NC
    Some people will tell you not to flush it after a certain amount of miles as it can cause the transmission to fail. On the other hand, would you just not change your oil anymore if you went over the milage interval? No of course not you would change it asap. As transmission fluid breaks down, automatics can start acting very strange. It also could be some sort of sensor, low fluid, TCM, or anything. If nothing else go to your local auto parts store and get what codes they can read. Finding someone willing and able to work on ZF transmissions can be challenging sometimes.
    Jun 15 2014
    Redondo Beach
    Hey guys, finally got word back from my mechanic. It is a high and low pressure fuel pump issue. When accelerating quickly the high flow fuel pump would not engage so the engine would go into a safe mode and not allow a proper acceleration. Thank god its not that damn TC. Thank you everyone for your help!
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    If it was a trans ----used is the best bet from www.car-part.com or if ya really want to invest and keep the car for a long time. There are plenty of ZF rebuilders. The key is to determine if its a valve body issue (mechatronics unit) or a physical clutch discs and friction plates?
    Thats where a really good shop can go a long way to determine which it is.
    As for fluid changed causing probs---thats BS---I havent seen ONE instance of people on this board claiming that a fluid change caused their issues. Usually the fluid change comes after there are issues and by then is too late!!
