Results 1 to 19 of 19
    Sep 02 2014
    Columbus, Ohio
    No Engine Cover -> Ruined Hood?
    So I went to the dealership to ask about what I thought was a leak but turned out to not be an issue. The mechanic asked why I didn't have the engine cover on and I explained that the plastic kinda looks shitty to me, but he explained that its actually a heat sync. He said that he's seen people leave it off and actually end up having their hoods warp or have paint issues. Has anyone here seen or had that issue?
    2015 A4 Prestige 6MT Brilliant Black | AFE Luft-Technik Intake | CTS Turbo Test Pipe and Down Pipe | GFB DV+
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Quote Originally Posted by tnargert View Post
    Imo, if you are experiencing enough heat under your hood to make the paint blister, you have bigger problems, and that plastic cover is not going to dissipate the heat fast enough. Does the cover channel air flow in any way?
    Eurosport Tuning at it's Finest
    Dec 07 2009
    East Coast
    Hood warping....c'mon now. I've seen some crazy BAT setups that have tens of thousands of miles racked up and no warping. Like someone mentioned above, if your hood warps from such heat, you've got bigger issues than a warped hood.
    Forget the B8, keep the V8!
    Jul 16 2008
    Finland
    The engine cover is there mostly for aesthetics and sound insulation.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    Request a different tech to work on your car. That comment alone is cause for alarm as he has no bloody clue what he talking about.
    Sent from my SM-G900W8 using Tapatalk
    Established Member Two Rings 99r6's Avatar
    Dec 03 2015
    Wichita
    Noob tech. If the temperatures got hot enough to warp the hood, then it'd be hot enough to melt the plastic.
    2011 A4 B8, 1985 E30 (M50 Turbo), 2002 Ram 1500 (Lifted + 35"s), 2015 Grom
    Aug 15 2014
    if this is the type of common sense we have working at dealers then I'm never having my car serviced there. don't these techs go to audi school or something?
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Loooooooool. The plastic would melt before a hood would warp.
    Common sense here.
    2016 S3
    Instagram- @Thisisastickup
    Mar 29 2014
    Hampshire, UK
    Don't dismiss the mechanics comments out of hand.
    The lack of engine cover wont necessarily warp your hood, but it can cause the paint to blister/discolour giving you the paint issues the OP referred to.
    On the S/RS/6/7 models, the engine cover has a significant heatsink built into its underside. Given the heat output of the engine, and the high mounting position of the twin turbos I have no doubt that if running stationary (or just stopped from a long run) the heat soak from the turbo and connecting pipes would be well capable of causing paint damage if left uncovered.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Dec 03 2015
    Wichita
    Quote Originally Posted by jkwelsh View Post
    Agreed, but the engine cover as a plastic "heat sink"...
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    But we are talking about an A4 with just an aesthetic PLASTIC engine cover. Plus the engine cover doesnt cover really any part of the exhaust that would really get hot. It basically just sits on top of the valve cover and intake.
    2024 RS3 Kemora Gray
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by integroid View Post
    The plastic intake, that is. And it sits over the plastic topped coils.
    Stay classy.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Sep 09 2010
    Destin, FL
    The only reason I want my cover back on is because the engine is ugly and I hate looking at it. Other than that the cover doesn't do too much.
    Jan 10 2007
    VA
    Yep. Techs are trained to be mechanics...to perform service and repairs to Audi vehicles. They aren't supposed to be automotive engineers that truly understand how everything works mechanically.
    Quote Originally Posted by Shimmy View Post
    Senior Member Two Rings shayan_a4's Avatar
    Jul 12 2014
    2014 VW GTI and 2014 mercedes SL550 2014 b8.5 audi a4, c7 A6
    woodland hills
    ive been running without my engine cover for some time now, and my hood isnt warped lol
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    ^ Same
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Sep 01 2012
    Edmonton
    Thats the best dealership to go too, everyone should try to find a shop where they have such smart Mechanics.....Numpty.
    Oh Oh better call IE and tell them they need to make a engine cover cause with their IM you cant put one.
    2018 RS3 Panther Black
    Sep 02 2014
    Columbus, Ohio
    Lol everyone thanks for the responses. Looks like I'm gonna let my 2.0 go commando
    Veteran Member Three Rings 2010b8a4apr2's Avatar
    Jul 31 2013
    navarre fl
    ive had mine off for 20k miles roughly? no issues what so ever
    2010 Audi A4 Quattro Prestige 290awhp/315awtq
