Results 1 to 19 of 19
    Sep 14 2005
    NC
    Best street coilovers??
    Any opinions?? Not trying to spend more than $1400
    Established Member Two Rings JaredB5s4's Avatar
    Jan 12 2016
    Kitchener Ontario Canada
    I would try to find some used h/r ones they are a amazing ride
    Jan 12 2016
    I think I might be able to find some used if you contact me
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    In my years of riding on coilovers for the VW/Audi chassis, I have used the following:
    - KSport
    - Koni
    - H&R
    - Bilstein
    - KW
    - Solowwerks
    "Best" street coilovers is very subject so you'll get varied opinions. In my experience, I believe Bilstein's bar none, are the "best" coilovers you can get for under $2K. Sure, you can buy more expensive ones, but it becomes an ROI debate at that point.
    Based on your requirements: 1- Bilstein (used ones since new are over 2k), 2- tie between Koni and H&R (because the Konis are adjustable rebound/dampening, H&Rs are not), then the rest...
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    I'll agree with zcspec. All listed are great. I've had H&R before and they were great. Stasis, which were fine on the track, but not-so-great on the street. I have Bilstein PSS9s and I think compete with systems twice their price and have a great all-around capability to them. I'm running those now.
    Aug 24 2014
    Newport Beach, CA
    I did exhaustive research and digging before I bought my H&R premium coilovers from a forum member. They were brand new and I paid under a grand shipped, I also replaced all the control arms, 034 upper strut mounts, and hardware at the same time. If you don't know when the control arms were last replaced, I recommend doing this at the same time along with the 034 density line upper strut mounts.
    I have them set pretty low, and they are amazing. Great ride handling balance, well damped, and have a proven history of being reliable. I can't see how they can be beat for a street setup, especially for the price I got them for honestly, it transformed the car from my old worn out Konis.
    2024 M3 Comp xDrive
    Jan 12 2016
    Barely used like new*
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    I vote Vogtlands. I love them, ask anyone who knows me, they will tell you I sound like a broken record. You don't need to spend a lot of money to get decent stuff, but there is also a lot of crap out there.
    http://cleanaudi.com/2013/04/30/vogt...ilover-review/
    http://cleanaudi.com/2014/09/24/solo...ver-review-p1/
    http://cleanaudi.com/2014/10/18/solo...ver-review-p2/
    http://cleanaudi.com/2015/03/04/solo...ver-review-p3/
    http://cleanaudi.com/2014/02/05/st-coilover-review/
    If we are being completely honest, I would avoid the solowerks, we have been less pleased with them as time has passed. (About 10k on them now)
    Sts are fine, no real complaints.
    Only real problem I have had with Vogtlands was a bit of noise after I installed a set on a B7 (Installer error)
    H&R is good stuff, running some springs on a C6 and they are great. Im probs going to test of set of Bilstein pss9s next.
    Megan is now also making crap for us, no idea how good they are, would avoid FK products. also JOM
    If you have to ask about Raceland, I will know you haven't done your homework.
    Eurosport Tuning at it's Finest
    Sep 14 2005
    NC
    I was going to ask about sts.
    I ran hr/bilstein on my old s4. Not coilovers. It was too low for me. I'll keep doing research.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    I love my BCracing - So much better than my old ST's - and any spring/strut combo I've had. Be sure to check them out.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jan 12 2016
    Lmao racelands are soooo badddd
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Love my konis, have had st, bilstein, and some other brands in the past. Konis have 60k on em and no issues still look brand new
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Quote Originally Posted by Cgoon009 View Post
    Care to elaborate on this particular noise and what caused it?
    I'm down to either BC racing coilovers ($1400aud) or Vogtlands (around the same once i factor in exchange rate and shipping).
    2000 Achat S4
    Senior Member Two Rings Jay_Soprano's Avatar
    Nov 15 2010
    Audi A6 C6
    Orlando, FL
    +1 on the bilsteins... Running PSS9 now
    Jun 10 2010
    I've had Stasis S/S (Koni), Bilstein PSS9, and some older H&Rs.
    I think my favorites are PSS9s. Dampening is easy to set and they ride well. The Streetsports were nice, but dampening adjustment was difficult. The older H&Rs (no idea which version) were way too soft.
    Mar 02 2013
    DC
    Quote Originally Posted by jaychen View Post
    It was late in the install, I was torquing down the bolts. I did one and then did it again instead of the next bolt. So I had one loose bolt and one over tight bolt. It's a lesson in not working tired. I re checked it all and did it correctly and the problem was solved. That being said I think it's really important to make sure you torque the bushings bolts correctly and with load on the suspension.
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Currently running PSS9's, love them. Used to run the Bilstein Sport/H&R combo and it was okay, rode nice but the springs a bit too soft.
    I've driven a car with STs, not bad. H&R is a bit harsher in my opinion but nothing unbearable. They're nice. BC makes decent stuff. Although I haven't experienced them personally in a B5 S4, I've driven a WRX (quite hard) with BCs and loved them. Great bang for the buck.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Jun 08 2014
    Vancouver, Washington
    Mine came with H&R's.. not sure which model but they ride very well. Handle corners great, not too bumpy. For the 2 years I have owned the car I still have yet to replace my strut mounts so I have a great clunk on the drivers side blew my lower rear control arm bushing too so that sucks. Squeaks like a mofo.. plan to do suspension overhaul this summer. But yeah, I like my H&R's
    Aug 24 2014
    Newport Beach, CA
    Yeah, H&Rs (at least the premium version) are fairly stiff but still reasonably forgiving. You do feel every undulation, bump and crack and is definitely not floaty. My parents hate stiff and loud cars, and they didn't complain after taking them to LA once which has shit roads.
    2024 M3 Comp xDrive
