Top 4 Reasons To Get VAS5054A:
1. Software Version: ODIS V2.0/V2.02
2. Support Multi-Language: English, Japanese, Portuguese, Romanian, Korean, Dutch, Polish, Turkish, Spanish, French, Italian, Croatian, Danish, German, Swedish, Finnish, Slovenian, Czech, Russian, Greek, Chinese
3. Bluetooth Version (Bluetooth Connection Password: 082145725)
4. Support Car models: VW, Audi, Seat, Skoda, Bentley and Lamborghini
VAS 5054A Specification:
The vehicle protocols are handled directly in the VAS 5054A.
This ensures fast response times and a reliable real-time behavior independently of the PC operating system. Every time a connection is established, the VAS 5054A software is identified with the version installed on the application PC. The VAS 5054A thus automatically adopts any new features provided after a new software version has been installed on the application PC.The diagnostic application and the associated Diagnostic Base System are installed on the application PC.
The diagnostic base system can access the VAS 5054A via Bluetooth or USB.Access via Bluetooth: After a connection to the VAS 5054A has been set up, the Bluetooth software provides a virtual serial COM port (Bluetooth Serial Port Profile). The Diagnostic Base System uses this COM port to communicate with the VAS 5054A.You need to specify this port when you install the diagnostic application.Access via USB: You can also connect the VAS 5054A to the application PC by using the supplied USB cable. Windows detects the VAS 5054A through Plug and Play, and automatically installs the drivers copied when you installed the diagnostic application. Setup of the VAS 5054A is then complete and the device is ready for use by the diagnostic application.
VAS 5054A Package List:
1pc x VAS 5054A Main unit
1pc x USB Cable
1pc x USB Bluetooth Adapter
2pcs x CD Software
1pc x Carry Case
For more info pls click here: http://www.oobbdd.com/wholesale/VAS-5054A-Bluetooth-ODIS-V2.0-V2.02--VW-Audi-Bentley-Lamborghini-Diagnostic-Tool-with-OKI-Chip-Multi-languages.html.
List Date: 1/27/2016
For more info, click here to view the original listing: VAS 5054A Bluetooth ODIS V2.0/V2.02 VW Audi Bentley Lamborghini Diagnostic Tool with OKI Chip Multi-languages
This item is no longer available.
