Results 1 to 7 of 7
    Active Member Two Rings B5Mark's Avatar
    Jan 15 2016
    Colorado
    Computer not communicating with Instrument Cluster
    My S4 has a problem where it cranks but doesn't start. So I took it in to get a vagcom and we got that the computer isn't communicating with the instrument cluster.
    Im going to try to get the Vagcom fault code soon. is it as simple as replacing the ECU because its not the original, or do i have to give an arm and a leg to fix it?
    Aug 06 2008
    Canadia
    Sometimes a bad abs module can cause communication errors, for example I can't connect to the ecu unless I unplug the abs module in the engine bay.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    If you have just replaced the ECU you may have re-coding to do http://s4wiki.com/wiki/Cluster_recode
    Jan 15 2016
    Colorado
    would the instrument cluster make it so the car can't start because its not communicating with the ecu
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by B5Mark View Post
    It shouldn't. These cars can drive without the cluster.
    2001 Corvette (C5) Z06
    Jan 15 2016
    Colorado
    Quote Originally Posted by MetalMan View Post
    so would it be something in between the cluster and the ecu? wiring?
    I hooked it up to vagcom.. Im not getting anything big but communication with cluster to the ecu.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If you can com with ecu, it should start.
    No immo on s4 and they run just fine with the cluster totally removed from the car.
    I think I would check coding first, and then the basics, like rpm while cranking, unplug maf, fuel, the usual suspects.
    You say the com code is the only biggy, what are the others? Sometimes they dont seem like a big deal, but can point you in the right direction.
    Post an autoscan or something.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
