Results 1 to 16 of 16
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    any one have pictures of jack points 2015 S4
    photos?
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    No photos, but they are very easy to spot. You will literally see an upside down triangle pointing at the jack point; about 8" of the pinch weld will be exposed.
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Pinch welds are the only recommended location.
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Also shown in the manual.
    Mike
    Aug 22 2014
    bloomfield,ct
    do you need any special pad on the jack or lift?
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jygesq View Post
    It is recommended to use a pinch weld jack pad adaptor to preserve the structure and coating of the pinch weld. The most popular one I've seen in my searches is from PureMS.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I've been bad recently... I've been jacking it up on the high density foam that covers the pinch welds. Then I'll place my jack stands on the exposed pinch weld. There is just not enough space for me to jack it up and set a jack stand on the exposed pinch weld. You could buy a special jack/jack stand combo, but I'm too cheap for that. Surprisingly the high density foam rebounds back to it original shape and it acts to protect my pinch welds from getting all knackered up. You should try it out if you're feeling brave!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Mar 21 2015
    Quote Originally Posted by fitzydude View Post
    I do the same with no issues.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Do you know which all in one jack will work on S4? I searched online but all I found looked too high for a sedan/coupe.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I just had my wheels off this weekend for brake pads/rotors replacement. I use a hockey puck with a slot cut just deep enough to hold the pinch weld on top of the jack saddle. I place the jack at the very end of where the pinch weld begins, and that leaves just enough room to put my ECS Jackstand right next to it, still on the weld. I cut up an old all weather floor mat and use that to protect the weld from the jackstand.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    Hey guys,
    I'm trying to rotate my tires front to back with my Harbor Freight jack and jackstands. I'm trying to use the 4 bottom pinch welds, but i don't have enough room to use a jack, then put stands underneath of them. How are you guys putting on jackstands?
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Mar 21 2015
    Quote Originally Posted by skiracerblah View Post
    Hey guys,
    Did you read the whole thread? Post 7 and 8
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by sacandagaD View Post
    I was using a hockey puck with groove cut into it for a while, but noticed on the last go-round that a crack had started to form in the puck, apparently from the crushing force of the pinch weld on the bottom of the groove. I've decided to bite the $25 bullet and order one of the PureMS jack pad adaptors and be done with it.
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by SteveYem View Post
    I bought the Pure MS Jack pad. Had no idea how massive and thick it was. My jack isn't "low profile" so with the pure ms jack pad on it i can't get it to clear the pinch weld. Waste of $20+ and shipping for me. My car is lowered on H&R OE's. I was disappointed. Jack fits with room to
    Spare without the pure ms pad.
    Probably should buy a new jack from harbor Freight eventually. Any recommendations?
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    This is what I use, pinch weld area with jack pad adapter. The adapter uses the pinch weld as the guide (deeper groove), and most of the load is distributed on the flat surface around the adapter (as to not crush the pinch weld). You're welcome.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    http://youtu.be/JIiWyAaNxcs
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
