Results 1 to 12 of 12
    Established Member Two Rings tekmo's Avatar
    Dec 08 2011
    B9 Audi Sound System vs B&O
    Did anyone have an opportunity to listen to Audi Sound System 10 Speaker in B9 A4 yet? Wanted to see if anyone has any opinions on it.
    B&O is not available as a stand alone option in Canada and requires a $4,000 upgrade to Technik package. I know B&O is good, but hoping that Audi Sound System will not disappoint.
    Established Member Two Rings Flat's Avatar
    Sep 21 2009
    Finland
    I have B&O on my car, and it is small disappointment. Bass is missing, no separate adjustments to sub. Sound is clear and very satisfying on certain mucis types, but sometimes not. 3D sound is also ok for certain music types, but more or less it is marketing trick. Compared to my previous aftermarket setup, this is not so good.
    Veteran Member Three Rings Im-AUDI-here's Avatar
    Jun 19 2013
    A bike
    Long Beach, CA
    I had the regular Audi Concert system in my 8.5 A4 and that thing sounded like crap. The B&O system is much better in terms of sound quality but neither will sound better than a quality aftermarket setup.
    2016 SQ5 Premium+ - Glacier White Metallic
    2013 A4 Premium - Scuba Blue - (Gone but not forgotten)
    Dec 08 2011
    Not sure what "Audi Concert System" is in US. Is that different from Audi Sound System in Canada? I have Audi Sound System 180 watt with 10 speakers in my '15 8V A3 right now and it sounds good to me.
    Jun 19 2013
    A bike
    Long Beach, CA
    Quote Originally Posted by tekmo View Post
    I could have the name wrong. It was the basic, non-B&O system that came with the MY '13 A4.
    Dec 08 2011
    Quote Originally Posted by Im-AUDI-here View Post
    Did you have Subwoofer, Bass, Treble, Balance & GALA controls?
    Jun 19 2013
    A bike
    Long Beach, CA
    Had all of that but I could never dial it in to a point where it sounded good to my ears. The treble was either lacking or too harsh and the mid bass was too boomy and muddied the sound. Trying to tune the mid bass down ended up cutting the bass to the point where it sounded thin. Sound quality is subjective and I'm picky when it comes to audio systems so I was never happy with it. The B&O system is much better but also has its faults.
    Established Member Two Rings Stifens's Avatar
    Aug 19 2012
    Norway
    I would go for the B&O. I have the usual Audi Sound system in my A5. Sounds like crap. My cousin has B&O in his A5, and it's alot better in every aspect.
    2008 A5 Coupé 2.0T MT quattro
    Jun 26 2012
    Rockford, il
    I have the B&O in my S4 and it's absolutely pathetic (bass mostly), I added a aftermarket sub woofer to it to make it more enjoyable. In my opinion 4k isn't worth it, unless it's better than the B8. I had the Bose in my A6 C6 years ago and that was far superior to the B&O. Save some money up front and replace the speakers with components for a couple of hundred and add a Sub, it will be way less than 1k and far better than B&O.
    Established Member Two Rings jgreer3746's Avatar
    Nov 29 2012
    Herndon, VA
    The B&O in the B8/B8.5 platform was only 505 watts. The new B9 B&O system has 755 watts. Although I have not heard this one live, I'm pretty sure the bass response will be much better than what the B8/8.5 had. I say this because the B&O system in my S3 has 705 watts and has much better low end than my B8.5 S5 B&O had, so most of that additional power must have gone to the sub.
    2018 Audi SQ5 Prestige Mythos/Magma
    Work at AoA HQ
    (any comments here are my own and not on behalf of the company)
    Sold -2013 S4, Roc-Euro Intake, H&R OE Sport, ECS 5mm/8mm spacers, Vag-Com, Plasti-Dipped Grill and Rear Valence
    Instagram - greer_cars
    Sep 21 2009
    Finland
    just quick update.
    It seems that system is getting better after 50 hours of listening. Bass is much better than at the beginnig. Ok, weather is also much warmer than one month ago ( - 20 C degrees vs + 3 C ), this must have some kind of effect to sound quality. As a summary, I love it ! 3D sound is also very nice. If you turn it off, you can notice the difference right away.,and most obviously, you turn it on again.
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    Audi Concert is the best damn sounding stock audio I've ever heard, and I've tested and listened to a lot of cars. You'll actually get better bass response/ control over your lower end if you choose to go with Audi Concert. Where Audi Concert will fall short of B&O though, is in the treble range which will provide your clarity in your music and give you that more immersive listening experience. So there you have it, that's the true difference between the two. And yes, there are more differences but those are the two most notable ones that you should base your decision off of.
