Originally Posted by
4rings2turbos
Does the suspension light come on and stay on when the compressor turns off? They is a safety switch that cuts the compressor's power until the key is cycled if the temp on the compressor gets too hot or it runs for too long. If the compressor is too weak to fill the holding tank before it reaches the safety shutoff temp or timeout then it would give the symptoms you speak of.
-is the compressor loud?
-have you tried running the compressor, when it stops, cycling the key and trying again?
compressor isn't loud at all. The previous owner put a new arnott comp about 7k miles ago so should still be good.
Since the front end is pretty much on the ground, as soon as I start the car. The jack mode light blinks and comp kicks on, 2 minutes later it shuts off. I'm surprise that the comp doesn't kick back on after cooling down or whatever it is that its doing. I will try cycling the key....
