Results 1 to 11 of 11
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    Tfsi purge valve ticking
    Hello guys, finally have figured out what this odd my loud ticking noise was coming from my car . Turns out it's the purge valve but I'm sure if it needs replacing. No engine codes but it's rather annoying at idle sometimes. Anyone else expirence this ?
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    Quote Originally Posted by mahunik View Post
    can you post a quick vid of the ticking noise youre getting? i think i have some as well when idle then goes away as soon as you hit the gas pedal.
    thanks!
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Senior Member Two Rings Davidx1994's Avatar
    Feb 02 2015
    2019 Macan, 2015 Jetta TDI, 2009 A4 Avant
    Plainville, CT
    I think I have this too.. It's a ticking that's not consistent with the engine, and when I blip the throttle it goes away too. I wouldn't call it loud, but definitely noticeable.
    Sent from my iPhone 6S using Tapatalk
    Veteran Member Three Rings mannyjfk's Avatar
    Dec 17 2010
    Mercedes Benz C Class
    Jersey City NJ
    +1
    Dec 06 2015
    This video is not by me and its showing a vw tsi engine but the sound is 100% identical
    https://www.youtube.com/watch?v=QiAo7OfeAsQ
    Dec 06 2015
    Also this sound icomes and goes, sometimes when the engine is full temp and hot it will go away. but perhapes it a sign the valve is about to go. When my PCV was failing I didnt get a code until I had weird symptoms for a week along with noises.
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    My allroad has made this ticking noise on and off since day 1. I have 92,000 miles on it and has the newest PCV revision. It doesn't have anything to do with the PCV and is totally normal. Just about every car with a high pressure direct injection set up will make this noise now and then. It's very common on the 2.0T TFSI engines and is not a sign that anything is wrong
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I have that noise too
    My 2009 A4 Prem+ Build thread
    Jan 15 2014
    Boston, MA
    All of my Audi loaner cars made this noise, and my old GLK350 made this noise as well. It's normal
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    I'm running a catch can with no PCV and I still have that noise. It's always been there.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Jun 26 2009
    Bremerton WA
    The easiest way to hear the purge valve is on a cold start. When the coolant temp is below a certain threshold the ECU is in cold loop mode and running off of baseline maps. The O2 sensor isn't in play yet. So fueling is based off of only MAF and boost pressure sensor. The purge solenoid would cause an overich condition that the ECU wouldn't be able to monitor yet. Once in warm mode the O2 can adjust fueling and the purge valve is cycled to remove gas vapor from the evap canister and pulsed so it doesn't draw too much vacuum. This is when you will hear it start (and feel if you touch it) clicking.
    VMR 710's, APR software, Eurocode HFC
