Results 1 to 40 of 52
    Junior Member Two Rings
    Mar 04 2015
    Atlanta, GA
    My car only likes OEM coil packs?! Aftermarket ones keep causing misfires.
    Hey guys,
    About 2 months ago, I had a coil pack go out, so I went ahead and replaced all 4 of them with some non-OEM coils purchased from O'Reilly Autoparts. They were only $26 each, so it seemed like a good deal. Two weeks ago, my car started misfiring with the dreaded "blinking" CEL, and because I had JUST replaced my coil packs, I didn't think it was that, so I replaced my spark plugs and the issue persisted.
    I got my car towed to my local mechanic, and they confirmed that one of the coil packs had corrosion inside of it, and replaced it for me. I paid them $280 (price included towing and diagnostic, plus parts/labor). Less than a week later, the SAME coil pack that they supposedly replaced went out again. Once again, I had to pay to get the car towed back to the mechanic so they could warranty out the bad coil pack.
    They ended up swapping out all my coil packs for the OEM ones, which are not only 1" shorter in length, but also nearly completely coated in rubber. He basically said that being an Audi, they tend to be picky with certain aftermarket parts, in this case, the coil packs. Is this true? My car is driving like a dream now, but I am concerned that I may have some sort of underlying issue that may be causing me to keep going through coil packs.
    Thanks in advance for any insight.
    Dec 06 2012
    Tacoma WA
    I think your just going to have to wait and see unfortunately but from what I have read here on the forums even the OEM coilpacks have issues here and there even with the revised version. My number 4 coilpack went out Friday night and I knew right away OEM was the only choice I would make based off of what Ive read on the forum.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Do not buy aftermarket coils packs!
    Jan 06 2009
    Your aftermarket coils cost most than oem from the dealership. I would not use those after market garbage coils.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jun 27 2011
    Jesus. $280 for replace four $20 coil packs that literally takes 5 minutes? Mechanics run such a racket...
    Also, only buy OEM coil packs. I know a guy, a stancebro really, whose name is similar to Jimmy who bought his coil packs at AutoZone or something because they had an unlimited warranty. He must have brought them back, no joke, 6 separate times to be replaced. And the worst part is you can't drive your car when your coils are dead. So he was essentially stranded. Yet still insisted it was a good deal because he got them replaced a bunch for free. "6 sets of coil packs would have cost a billion dollars" he said.
    Except it's a false economy because the single set of OEM coils with no warranty would have only cost $80 and would have lasted years and years without failure. Sometimes people get suckered into buying a product because they equate having a warranty with reliability. The warranty is marketing and you fell for it. The reliability comes from buy OEM coils.
    I've run a set of OEM b7 coils in my b6 for 4 years straight before I sold it with zero issues. I also have run a set of OEM coils in my b7 for 3 years straight with zero issues.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Red ones from Genuine Audi PArts---picked em up for $14 each. That was a ahwile ago. Bought an extra--its in the trunk ......waiting..........
    Jul 18 2012
    New York
    I had to buy a coil from autozone once... Was stuck and had no other choice. But got the red packs from Hugh (europarts) now for awhile.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Hugh@EuropaParts View Post
    +1^ seems pretty self explanatory, and since OE ones are what $8 more, why wouldn't you buy OE?!
    Stage 1 more than you RS3
    Mar 04 2015
    Atlanta, GA
    Well when you're broken down on the side of the road, but in walking distance of an O'Reilly, gotta get up and running ASAP! ;)
    Jun 27 2011
    Quote Originally Posted by MattPethel View Post
    Indeed. In a pinch you gotta do what you gotta do.
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    I've been running the red top oem coils since April of 2013 and have had zero issues with them over 57k miles. The first 10k I was APR stage 1 and the last 48k I had a built motor with my K0R and Maestro tuning by myself. I think running good plugs and an appropriate gap plays a big part in how well your coils hold up. I'm running NGK BKR8EIX plugs with a 0.028" gap.
    -Adam
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Again, OEM Audi or dud!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    The giveaway is that the coilpacks were shorter than the OEM. Can't imagine that being good
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    I got the red set when they were $14 a pop too. I took one of my working factory packs put in a box with the T-screwdriver needed, and tucked it into the compartment with my XM unit in the trunk.
    This way I have a factory grade spare on the road AND have the tool to swap it...
    Mar 04 2015
    Atlanta, GA
    Here's a pic the mechanic gave me.
    The one on the left is aftermarket. The one on the right is OEM.
    Oct 24 2015
    Perth, WA
    Theyre both OEM, the one on the right is a B revision (06H905115B) and the one on the left an F revision (07K905715F).
    My respray thread
    Feb 24 2004
    Minneapolis
    ^^^Good picture^^^
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Mar 04 2015
    Atlanta, GA
    Quote Originally Posted by Okedokey View Post
    The one on the left is the aftermarket one I bought from O'Reilly.
    Sent from my LG-D851 using Tapatalk
    Mar 04 2015
    Atlanta, GA
    My question is why there would be a length difference, and what sort of issues can come from using a longer pack?
    My mechanic claims that the extra length was causing it to "arc against the cylinder head". Sounds like b.s. jargon to me, but I'm not a mechanic by any means.
    Jun 27 2011
    There shouldn't be extra length. If there is it's the wrong coil pack for your car. The b6 coils are about 3/4" shorter than the b7 ones.
    Also your mechanic doesn't know what he's talking about. I've always used metal bodied coils and never had any issues whatsoever. If it's arcing against the head then you've got much more major issues...
    I currently run those 07K coils in my b7 and had them in my b6 for 3 years with absolutely zero issues.
    Now it's possible that aftermarket one really is too long, in which case it's junk and you should ditch it asap. If it's a real 07k coil then it should be the proper length and I'll seat snugly in the valve cover detents.
    -CP
    2017 Q7 3.0t
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by B72011 View Post
    Yup, got me six when that deal went on.
    Sent from my SM-N900P using Tapatalk
    Waiapasi2006
    Nov 16 2006
    Skokie, IL
    Give us the aftermarket part number. Maybe the number is off by a digit or letter. Should be on the box if you still have it.
    Mar 04 2015
    Atlanta, GA
    Quote Originally Posted by Sanjman View Post
    From O'Reilly: "Import Direct" - IDI 23-0157
    From AutoZone: "Duralast" - C1627
    Nov 30 2015
    New York
    Talk about timing. I almost bought the coil pack from autozone today since I didn't want to wait till Monday to buy the OEM at the dealership. Wanted to take my baby snow drifting but I guess good thing they weren't in Stock
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Senior Member Two Rings DavidAAG's Avatar
    May 05 2011
    Breinigsville, PA
    Where did you buy your plugs and coils from. I'm looking to get some.
    Jun 27 2011
    ^^ I got mine on Amazon from a VW dealer new for $18/ea
    -CP
    2017 Q7 3.0t
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by DavidAAG View Post
    I bought mine from Europaparts, but lots of places sell them for reasonable prices.
    -Adam
    May 05 2011
    Breinigsville, PA
    Thanks Aluthman.
    Feb 15 2016
    Cambridge,Ontario
    i am getting somewhat confused with all the terms ..
    is the following not true ?
    OE= Original equipment , usually bought from a dealer with Vendor stamp. ( 4 rings or VAG stamping )
    OEM = Original equipment manufacturer, Bosch for example, but not necessarily to OE standards and will NOT carry Vendor stamp.
    Aftermarket = Built by alternate vendor to " fit" as original , bot necessarily to any standard.
    So when you guys say from Audi I think you mean OE part no ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 27 2011
    The terms OE and OEM tend to be misused. Not sure why. Actually I think I misuse them too...
    -CP
    2017 Q7 3.0t
    Oct 09 2007
    Miele S7
    'Genuine' is the keyword - Genuine Audi, Genuine BMW, Genuine Toyota, Genuine Volvo, etc...
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by 80sGuy View Post
    actually be very careful there.
    I actually know of a company called " genuine parts" . It is perfectly legal , you can get tripped up when you see genuine parts in the add and they are in fact after market parts form the "genuine parts" company , be carful of that one.
    1976 Yamaha XS 360
    Oct 09 2007
    Miele S7
    They should be stamped with the appropriate brand/logo. If this 'genuine parts' company you speak of falls under all this then it is counterfeit. Genuine Audi parts should have VW/Audi stamped on them. Easiest way to be sure is to buy them from your local dealer, or online dealer such as https://audihendersonparts.com/ which I've yet to see anyone beat their prices & service.
    Feb 15 2016
    Cambridge,Ontario
    Not to get too off topic here ( and I apologize to OP for doing so ) but it is in fact not counterfeit. If you buy an aftermarket part from a company called " genuine parts" they are within all legal bounds. They never state anything about the origin of the parts. That is just the company name. If this website did not make it so difficult to upload pics I could show you a few screen shots of vendors I am talking about.
    oh I just did a copy and paste , not very pretty but you will see what I am talking about ... want to buy an original equipment crankcase valve ? look no further ... but wait ... read the whole thing.
    Part Number: OEA1977767 Manufacturer: Original Equipment
    Engine Crankcase Vent Valve
    brand
    stars
    Sale Price:
    $30.09
    List Price:
    $65.95
    Save:
    $35.86 (54 %)
    Qty:
    In Stock
    Leaves Warehouse Today
    FULL WARRANTY
    Share:
    0
    cart-btn cart-btn
    FREE SHIPPING on order over $100
    shipped from same warehouse
    Product Details
    Warehouse:
    A
    Product Notes:
    Gasket Serviced Separately - Pressure Regulating Valve
    Brand Description:
    Original Equipment is a brand of parts collected from suppliers all over world selling their OE and OE quality parts in effort to save money on quality parts.
    Weight:
    0.35 lb.
    Package Size:
    3.50 x 2.00 x 7.50 inches
    Interchange:
    W0133-1977767, W0133-1977767-OEA, W0133-1977767OEA, OEA W0133-1977767
    Fitment Note:
    To:12-16-05
    Production: -12/16/2005, Replacement of Hose with Check Valve is recommended
    Even though you may feel you are buying an OE part you are not going to find an Audi stamp anywhere on it. Point is buyer beware and read the fine print on parts.
    1976 Yamaha XS 360
    Aug 22 2010
    Piscataway, NJ
    Eldor makes the coil packs for our cars... we carry both the Genuine OEM (purchased directly from the dealer) and OEM (original equipment manufacturer - eldor)
    Feb 15 2016
    Cambridge,Ontario
    High Hugh , thanks for chipping in , isn't this confusing for the consumer ? wouldn't you be better served calling the part purchased directly from the dealer OE ? personally this is what would get my attention . I would expect to pay more obviously but would make it great.
    Lets face it you can get away with and OEM or even aftermarket / alternate vendor for some things , but there are others I would want an Audi part for and is worth paying the extra for in my mind as they tend to have a critical nature.
    coil, thermostat, cam follower, water pump , just to name a few I would personally want OE for.
    Would be great to combine these in one order , that's why I find it preferable to deal with vendors that can combine both in one order like yourselves .
    1976 Yamaha XS 360
    Senior Member Two Rings jamezz23's Avatar
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    I've bought after market and oem and they are exactly the same, they all suck and will go out. There is virtually no difference between from my expirence
    Jun 27 2011
    Quote Originally Posted by jamezz23 View Post
    I've only bought Audi branded could and never had issues.
    -CP
    2017 Q7 3.0t
    Aug 22 2010
    Piscataway, NJ
    The Genuine OEM coils that are purchased at the dealer and found on your car are made by eldor... we offer the eldor unit as well... it is literally the same exact part just not stamped with the AUDI / VW logo. The eldor units are marked as OEM (original equipment manufacturer). Anything that is AFTERMARKET will not be an eldor unit.
    TL;DR You end up paying $4.00 more per coil because it has a Audi / VW logo on it.
    Jun 27 2011
    My philosophy: coil packs are cheap, but also pretty damn critical to the proper working of the car. Get legit ones, don't mess around. Especially when you're only saving a few bucks when you buy off brand or aftermarket ones. A tow truck more than makes up the difference when you get stranded.
    Just like spark plugs, cheap out at your own peril.
    -CP
    2017 Q7 3.0t
