Results 1 to 12 of 12
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Oil Filter Housing Leak?
    Recently just sprung a leak on the driver side of the engine block. Is it a common thing that the gaskets start to let go on the oil filter housing? Also, what parts (gaskets) would be needed to perform this service?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Its common ppl tend to overtighten the filter housing and crack it. Its cheap plastic. Either you cracked it, stripped a thread, and or possibly the gasket isnt seated properly.
    Personally, I went with an aluminum oil filter housing after a constant battle with overtightening my plastic one and leaking.
    Go to ECS. Theyll have part numbers and housings
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jan 23 2013
    Chicago
    You have misunderstood me. I meant the whole assembly not only the part the oil filter goes into.
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    It's pretty common for those gaskets go. You need 2 gaskets one for oil cooler and 1 for oil filter housing adapter.
    Sent from my SM-G900T using Tapatalk
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by Denio24 View Post
    I see. When you kept talking about oil filter "housings", one might assume you meant the housing.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jun 17 2013
    jersey city nj
    Mar 24 2013
    Oakdale, CT
    Yes it's common as the car gets older for these gaskets to develop leaks. It's maybe an hour or two worth of work to change them out and they aren't expensive. No big deal.
    -Adam
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Its a nasty job. Be sure to drain coolant and oil first and beware of coolant getting into oil pan when removing the filter housing.
    Established Member Two Rings B7Lee's Avatar
    Jun 01 2008
    B8.5 S4 - previously B7 S4
    Boston, MA
    Small leak under driver side leaking off belly pan. My oil was changed 1000 miles ago. Does this seem like a cracked oil filter housing cover? Or is that short sighted?
    Sent from my Pixel 3 using Tapatalk
    05.5 Quartz Gray S4- MaD StUfF yoooO.
    Feb 15 2016
    Cambridge,Ontario
    Usually oil filter housing causes leaks that run down the lock. You can see the leaks around the cooler.
    As others have mentioned get the housing not the gaskets as the housing warps.
    Its not a bad job just finicky. Although I would not want to do it with an ailing back. Or in winter.
    Sent from my SM-G973W using Audizine mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 01 2008
    Boston, MA
    Thanks. Looks like ECS only offers the cover/cap/billett to the oil filter housing.
    If I have this whole housing replaced https://www.europaparts.com/oil-filt...6e115405k.html .
    Is that a common leak around the 3.0 engines? Or is there another common part that fails on the driverside??
    Sorry I didn't follow the leak "down the lock vs. cooler". Idk if my photo was helpful in that way.
    Feb 15 2016
    Cambridge,Ontario
    Sorry meant leak down the block. Sorry again as I didnt realize you had a 6. 90 % here have the 4 cyl 2.0T
    But yeah that's plastic just like the 2.0t so I would not bother with just gaskets
    1976 Yamaha XS 360
